[Qgis-user] Using GRASS in QGIS
Kim Besson kimbesson1981 at gmail.com
Tue May 25 01:03:42 PDT 2010
Hi Micha
What do you mean "gfunction"?
It was a typo. I meant function :).
> The functions that are implemented in the GRASS Toolbox appear in an xml
> file (on Linux it's /usr/share/qgis/grass/config/default.qgc) and the
> configuration of each module's GUI in QGIS is setup in a specific *.qgm file
> (also xml format) located in /usr/share/qgis/grass/modules/.
> In my case I'm using OSGEO QGIS installation. I can open and display
vectorial/rasters from GRASS location/mapsets but I cannot acess to GRASS
tools. Wasn't it suppose to have a few modules/GRASS functions already
available?
Thanks
Kim
>  2- Can I apply a GRASS function, already integrated in QGIS, to a dataset
> yhat is not in GRASS location/mapset?
> No. But the GRASS import functions are all available from the GRASS Toolbox
> in QGIS
So if I'm avoidining using the same Location/mapset structure, QGIS is not
an option?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100525/791ca6d5/attachment.html>
