[Qgis-user] google layers plugin projection
Benoit de Cabissole benoit at exigesa.com
Tue May 25 05:04:39 PDT 2010
Maning,
The way I'm doing it is to setup a new QGIS project using a default projection of EPSG:900913 (Google Mercator) and enable 'on the fly' projection. Then I open my shapefile (not raster), in whatever projection it is, and display and size it to the wanted window. Finally, I use the Google Layers plugin to retrieve and display a Google raster that fits the window.
Work like a charm for me!
Hope this helps!
Benoit
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of maning sambale
> Sent: Tuesday, 25 May 2010 09:21
> To: qgis-user
> Subject: [Qgis-user] google layers plugin projection
> I am testing the google layers plugin.  I used the SR-ORG Projection
> 6627 - Google Mercator  SRS parameters and enabled on-the-fly for
> vectors.  A googlemap image appeared but it doesn't match with my
> epsg:4326 shapefile.
> http://spatialreference.org/ref/sr-org/6627/
> Did I get the correct SRS?
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Qgis-user mailing list
