[Qgis-user] google layers plugin projection
maning sambale emmanuel.sambale at gmail.com
Wed May 26 16:28:52 PDT 2010
benoit,
Thanks!  EPSG:900913 is not available in the CRS in QGIS 1.4.  I tried
looking for it in spatialreference.org and the closest was
http://spatialreference.org/ref/sr-org/6627/ which I added as a custom
SRS my vector didn't match even with OTF enabled.
On Tue, May 25, 2010 at 8:04 PM, Benoit de Cabissole <benoit at exigesa.com> wrote:
> Maning,
> The way I'm doing it is to setup a new QGIS project using a default projection of EPSG:900913 (Google Mercator) and enable 'on the fly' projection. Then I open my shapefile (not raster), in whatever projection it is, and display and size it to the wanted window. Finally, I use the Google Layers plugin to retrieve and display a Google raster that fits the window.
> Work like a charm for me!
> Hope this helps!
> Benoit
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of maning sambale
>> Sent: Tuesday, 25 May 2010 09:21
>> To: qgis-user
>> Subject: [Qgis-user] google layers plugin projection
>> I am testing the google layers plugin.  I used the SR-ORG Projection
>> 6627 - Google Mercator  SRS parameters and enabled on-the-fly for
>> vectors.  A googlemap image appeared but it doesn't match with my
>> epsg:4326 shapefile.
>> Did I get the correct SRS?
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
cheers,
maning
