[Qgis-user] Help on SDA4PP plugin
Giovanni Manghi giovanni.manghi at gmail.com
Thu May 27 02:36:36 PDT 2010
Hi Hugo,
I stumbled in your same situation a few times and in my case the only
thing it worked was to remove R, QGIS, clean the system (remove locale
package/plugin directories) and reinstall. After that it all worked.
Cheers
-- Giovanni --
On Wed, 2010-05-26 at 18:47 +0100, Hugo wrote:
> Hello all,
> I was previously successful in installing sda4pp in another machine.
> Somehow i'm not able to replicate the installation.
> The system is the following:
> Win XP SP3
> QGIS 1.5 r13575M
> R 2.10.1
> GGOBI 2.1.8
> I've installed all packages required by the SDA4PP plugin in rgui
> through install.packages.
> When i start qgis and go to the SDA4PP menu -> Components/R packages
> it says that rgdal isn't installed. I have tried top remove the
> package and then install rgdal through the plugin menu in qgis and the
> result is the same.
> I have set environment variables for R and GGOBI.
> Does anyone have an idea on how to solve this issue????
> Thanks in advance,
> Hugo
> Hugo Martins
> FMV-UTL
> CIISA-Epidemiologia e Saúde Pública Veterinária
> Av. da Universidade Técnica
> 1300-477 Lisboa
> N 38°42'49.54", W 9°11'43.42"
> Qgis-user mailing list
