[Qgis-user] Re: QGIS 1.5 on Ubuntu 10.04 crashes
Agustin Lobo
alobolistas at gmail.com
Wed Nov 3 01:39:40 PDT 2010
Alex,
It seems my problem is
http://trac.osgeo.org/qgis/ticket/2903
again
I cannot tell for sure, as I will not have access to that machine
until tomorow 5/11/2010,
but it's most likely. If that's the problem, the crash has been
solved in trunk and for future releases.
I'll report tomorrow again.
Agus
2010/11/3 Alex Mandel <tech_dev at wildintellect.com>:
> I've also been having issues on my 32 bit install (my 64 bit works fine)
> from Ubuntugis repos, but a self compiled version works fine. I have not
> been able to track down the issue but the last time I had something
> similar it was a conflicting library somewhere in Qt. But that's really
> just a guess to start.
> Which binaries are you using?
> Thanks,
> Alex
> On 11/02/2010 08:35 AM, Agustin Lobo wrote:
>> Also, in case this provides any useful information,
>> I've seen that my System Log has entries such as:
>> Nov 2 16:07:11 delia kernel: [ 1011.502133] qgis.bin[2339]: segfault
>> at 0 ip 00007f976722a2fd sp 00007fff3bc4b0d0 error 4 in
>> libQtCore.so.4.6.2[7f976708d000+276000]
>> Nov 2 16:10:09 delia kernel: [ 1188.912519] qgis.bin[3511] trap stack
>> segment ip:7fd517ae02fd sp:7fff314d4230 error:0
>> Nov 2 16:10:57 delia kernel: [ 1236.902324] qgis.bin[3567]: segfault
>> at 0 ip 00007f3f8aa5c2fd sp 00007fffd885db00 error 4 in
>> libQtCore.so.4.6.2[7f3f8a8bf000+276000]
>> Nov 2 16:13:01 delia kernel: [ 1361.223289] qgis.bin[3591]: segfault
>> at 0 ip 00007fa00adbc101 sp 00007fffe1ef3b00 error 4 in
>> libQtCore.so.4.6.2[7fa00ac1f000+276000]
>> Nov 2 16:14:12 delia kernel: [ 1431.700704] qgis.bin[3628]: segfault
>> at 0 ip 00007f7b96395101 sp 00007fff7bd5ab00 error 4 in
>> libQtCore.so.4.6.2[7f7b961f8000+276000]
>> Nov 2 16:15:17 delia kernel: [ 1496.781699] qgis.bin[3649] trap stack
>> segment ip:7fc37d98e2fd sp:7fff184bad90 error:0
>> Nov 2 16:23:56 delia kernel: [ 2015.454881] qgis.bin[4979]: segfault
>> at 0 ip 00007f2acc29b2fd sp 00007fff65323250 error 4 in
>> libQtCore.so.4.6.2[7f2acc0fe000+276000]
>> Agus
>> 2010/11/2 Agustin Lobo <alobolistas at gmail.com>:
>>> Hi,
>>> After a crash while trying to load a vector layer, QGIS crashes all time:
>>> the program starts, but as soon as I try to open any project or any layer or
>>> to create a new layer, the program crashes with Segmentation Fault.
>>> I've tried qgis --noplugins, same behavior.
>>> I'm using ubuntu 10.04 and the binaries of 1.5 from ubuntugis/unstable
>>> Any idea on what to do?
>>> Thanks
>>> Agus
> Qgis-user mailing list
