[Qgis-user] Re: QGIS 1.5 on Ubuntu 10.04 crashes
Agustin Lobo alobolistas at gmail.com
Thu Nov 4 02:05:52 PDT 2010
I can confirm that the crash problem was caused by the "Add Vector Layer..."
tool being with an empty field for Encoding by default. This is an
abnormal state,
very unusual, which in my case was caused by plugin "points2One":
after running the
plugin and selecting YES to Add layer to the TOC, QGIS crashes and remains with
the empty Encoding field by default in "Add Vector Layer...". If the
user does not realize the
empty field and proceeds not selecting an Encoding, QGIS crashes. QGIS
also crashes at
opening any project in which there is a vector layer to be added.
The problem is simply solved by using "Add Vector Layer..." once and
selecting an Encoding.
>From there on, "Add Vector Layer..." always has some Encoding by
default and QGIS does not crash.
According to the track, the crash problem has also been solved in
trunk and thus for future releases
of stable binaries (thanks Jef!).
It would be nice if the very useful plugin points2One could be fixed as well
More info in
http://trac.osgeo.org/qgis/ticket/2903
Thanks to all.
Agus
2010/11/3 Agustin Lobo <alobolistas at gmail.com>:
> Alex,
> It seems my problem is
> again
> I cannot tell for sure, as I will not have access to that machine
> until tomorow 5/11/2010,
> but it's most likely. If that's the problem, the crash  has been
> solved in trunk and for future releases.
> I'll report tomorrow again.
> Agus
> 2010/11/3 Alex Mandel <tech_dev at wildintellect.com>:
>> I've also been having issues on my 32 bit install (my 64 bit works fine)
>> from Ubuntugis repos, but a self compiled version works fine. I have not
>> been able to track down the issue but the last time I had something
>> similar it was a conflicting library somewhere in Qt. But that's really
>> just a guess to start.
>> Which binaries are you using?
>> Thanks,
>> Alex
>> On 11/02/2010 08:35 AM, Agustin Lobo wrote:
>>> Also, in case this provides any useful information,
>>> I've seen that my System Log has entries such as:
>>> Nov  2 16:07:11 delia kernel: [ 1011.502133] qgis.bin[2339]: segfault
>>> at 0 ip 00007f976722a2fd sp 00007fff3bc4b0d0 error 4 in
>>> libQtCore.so.4.6.2[7f976708d000+276000]
>>> Nov  2 16:10:09 delia kernel: [ 1188.912519] qgis.bin[3511] trap stack
>>> segment ip:7fd517ae02fd sp:7fff314d4230 error:0
>>> Nov  2 16:10:57 delia kernel: [ 1236.902324] qgis.bin[3567]: segfault
>>> at 0 ip 00007f3f8aa5c2fd sp 00007fffd885db00 error 4 in
>>> libQtCore.so.4.6.2[7f3f8a8bf000+276000]
>>> Nov  2 16:13:01 delia kernel: [ 1361.223289] qgis.bin[3591]: segfault
>>> at 0 ip 00007fa00adbc101 sp 00007fffe1ef3b00 error 4 in
>>> libQtCore.so.4.6.2[7fa00ac1f000+276000]
>>> Nov  2 16:14:12 delia kernel: [ 1431.700704] qgis.bin[3628]: segfault
>>> at 0 ip 00007f7b96395101 sp 00007fff7bd5ab00 error 4 in
>>> libQtCore.so.4.6.2[7f7b961f8000+276000]
>>> Nov  2 16:15:17 delia kernel: [ 1496.781699] qgis.bin[3649] trap stack
>>> segment ip:7fc37d98e2fd sp:7fff184bad90 error:0
>>> Nov  2 16:23:56 delia kernel: [ 2015.454881] qgis.bin[4979]: segfault
>>> at 0 ip 00007f2acc29b2fd sp 00007fff65323250 error 4 in
>>> libQtCore.so.4.6.2[7f2acc0fe000+276000]
>>> Agus
>>> 2010/11/2 Agustin Lobo <alobolistas at gmail.com>:
>>>> Hi,
>>>> After a crash while trying to load a vector layer, QGIS crashes all time:
>>>> the program starts, but as soon as I try to open any project or any layer or
>>>> to create a new layer, the program crashes with Segmentation Fault.
>>>> I've tried qgis --noplugins, same behavior.
>>>> I'm using ubuntu 10.04 and the binaries of 1.5 from ubuntugis/unstable
>>>> Any idea on what to do?
>>>> Thanks
>>>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
