[Qgis-user] Re: QGIS 1.5 on Ubuntu 10.04 crashes
Agustin Lobo alobolistas at gmail.com
Sun Nov 7 22:55:39 PST 2010
Thanks, I've tested the plugin and the problem has been solved.
The reason the error was reported in [1]is that it was actually involving a
problem in qgis itself also, as there is no reason why qgis should
abruptly crash
just for having an empty field. It was also hard to actually realize
that the problem
was related to points2one, the first thing coming to my mind being
some installation
or even hardware problem.
Great this is solved in both sides now!
Agus
2010/11/5 Goyo <goyodiaz at gmail.com>:
> Points2One could show and empty encoding field under certain
> conditions (for example in a fresh qgis setup if no other tool which
> asks for an encoding is used before) and cause qgis to do the same.
> This has been fixed in release 0.2.6, yet available in the contributed
> repository.
> I noticed this problem was mentioned in the bug report [1] three
> months ago. Please report issues related to Points2One to qgis-user or
> the bug tracker [2].
> Cheers
> Goyo
> [1] http://trac.osgeo.org/qgis/ticket/2903
> [2] https://bugs.launchpad.net/points2one
> Qgis-user mailing list
