[Qgis-user] using manageR
Kumaran Narayanaswamy
kumaran.narayanaswamy at kcubeconsulting.com
Sun Nov 14 20:00:46 PST 2010
Yeah R.exe should be in environment PATH variable.
Kumaran
--- On Sat, 11/13/10, Phil Morefield <philmorefield at yahoo.com> wrote:
Subject: Re: [Qgis-user] using manageR
To: fgraz at unam.na, qgis-user at lists.osgeo.org
Date: Saturday, November 13, 2010, 12:24 AM
Patrick-
This might be an issue with R 2.12. On my XP machine, prior version of R installed the "R.exe", among other important files, here:
C:/Program Files/R/R-2.11.1/bin
When I install 2.12.0, the same files go here instead:
C:/Program Files/R/R-2.12.0/bin/i386
My guess is manageR is looking for "R.exe" in the old default path.
Hope that helps.
Phil
Man brings all things to the test of himself, and this is notably true of lightning.
-Aldo Leopold
To: qgis-user at lists.osgeo.org
Sent: Fri, November 12, 2010 7:15:21 AM
Subject: [Qgis-user] using manageR
Hi all,
I have tried to get manageR to work on a windows XP box (R2.12 & QGIS
1.5/1.6)but don't seem to have any luck. To the best of my knowledge I have
all the necessary extensions installed in R (ade4, aspace, sp, spgrass6,
rgdal) adehabitat and have rpy2 installed.
When I tried using QGIS 1.5 manageR would tell me that it could not find the
r212.dll (I didn't write that error msg down...) but at least it tried...
With 1.6 extension does not respond at all (i.e. you click on its icon and
nothing happens).
I have tried uninstalling and re-installing R and qgis
but it's still not
working. Where would I need to look to find out if my installation is
sufficiently complete - and should be working. Is there a compatibility
issue between the versions of the software - or software and extensions?
Another thought - when I upgraded from R2.10 to R2.12 on an Ubuntu machine I
could also not access manageR anymore...
Any help would be welcome.
Patrick
Dr. F. Patrick Graz
Snr. Researcher,
Multidisciplinary Research Centre,
University of Namibia
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101114/b0dd9d48/attachment.html>
