[Qgis-user] using manageR
Dr. F. Patrick Graz fgraz at unam.na
Sun Nov 14 22:13:48 PST 2010
Greetings, and thanks for the various responses I received.
It seems that the issue is with changes re R2.12. My earlier 2.10
installation, and that of Brad indicate that the previous versions of R and
QGis worked fine together. I changed the environment path RHOME vs R_HOME
(another change in R it seems) but that also didn't work.
So I would go along with the suggestion of Carson that the issue is with the
interaction via rpy2.  If I run into anything, I'll keep you posted.
Thanks again,
Patrick
From: Phil Morefield [mailto:philmorefield at yahoo.com]
Sent: Friday, November 12, 2010 8:54 PM
To: fgraz at unam.na; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] using manageR
Patrick-
This might be an issue with R 2.12. On my XP machine, prior version of R
installed the "R.exe", among other important files, here:
C:/Program Files/R/R-2.11.1/bin
When I install 2.12.0, the same files go here instead:
C:/Program Files/R/R-2.12.0/bin/i386
My guess is manageR is looking for "R.exe" in the old default path.
Hope that helps.
Phil
Dr. F. Patrick Graz
Snr. Researcher,
Multidisciplinary Research Centre,
University of Namibia
