[Qgis-user] Qgis freezes with grass vector edit
Giovanni Manghi giovanni.manghi at gmail.com
Thu Nov 18 03:44:03 PST 2010
Hi Pablo,
do the same happens if you edit the vectors directly into GRASS?
cheers
-- Giovanni --
On Thu, 2010-11-18 at 09:39 -0200, Pablo Carreira wrote:
> Hi,
> I'm experiencing a problem.
> QGIS freezes when I edit GRASS vectors. It works for a while (just a
> few clicks) then freezes.
> It is something related to the database, I've reached this conclusion
> because if I only move some vertices  there is no problem, but if I
> delete something or query the database the problem occurs.
> I've tried versions 1.5 and 1.6 from Osgeo4w.
> I've tried PG, DBF and SQLITE as storage.
> I've created new locations, mapsets and vectors.
> Nothing solved the problem.
> Some time ago, also with version 1.5, everything were working fine.
> Could it be some bug of the newest builds?
> Regards.
> Pablo Torres Carreira
> Qgis-user mailing list
