[Qgis-user] Download points from Garmin GPS 60
Noli Sicad nsicad at gmail.com
Fri Nov 19 22:03:55 PST 2010
As mentioned by Bob, must install the garmin_gps driver / module.
In Terminal
sudo modprobe garmin_gps
I think to make gps working.
On 11/20/10, JC Notter <jc.notter at orange.fr> wrote:
> Hi,
> Maybe it's a problem of driver for your garmin not installed ??
> Regards
> JCN
> Le 19/11/2010 16:02, Arthur Nanni a écrit :
>> Via terminal and GPSBAbel
>> arthur at rgsg:~$ gpsbabel -w -i garmin -o gpx -f usb: -F
>> /home/arthur/documentos/wpt.gpx
>> Found no Garmin USB devices.
>> arthur at rgsg:~$
>> and...
>> arthur at rgsg:~$ gpsbabel -w -i garmin -o gpx -f /dev/ttyUSB0 -F
>> [ERROR] XSERIAL: Cannot open serial port '/dev/ttyUSB0': No such file
>> or directory
>> [ERROR] Cannot open serial port '/dev/ttyUSB0'
>> GARMIN:Can't init /dev/ttyUSB0
>> arthur at rgsg:~$
>> 2010/11/19 Arthur Nanni <arthur.nanni at gmail.com
>> <mailto:arthur.nanni at gmail.com>>
>>     Hi Giovanni,
>>     Tks for your attention.
>>     No advances. Look in https://sites.google.com/site/qgis150/
>>     The status in the GPS screen is connected. OK.
>>     Any more idea?
>>     2010/11/19 Giovanni Manghi <giovanni.manghi at gmail.com
>>     <mailto:giovanni.manghi at gmail.com>>
>>         Arthur,
>>         please try fill that "output file" field iwth an actual real path.
>>         cheers
>>         -- Giovanni --
>>         On Fri, 2010-11-19 at 09:24 -0200, Arthur Nanni wrote:
>>         > Hi Folks,
>>         > I tried this suggestions.
>>         > I am use "usb:" and " /dev/ttyUSB0" in the arguments line.
>>         > My problem can be viewed in link
>>         > I am using Ubuntu 10.04 with QGIS 1.5.0 and GPSBabel 1.3.6
>>         > Thanks in advance.
>>         > Arthur
>>         > 2010/11/19 M.E.Dodd <m.e.dodd at open.ac.uk
>>         <mailto:m.e.dodd at open.ac.uk>>
>>         >         Do you mean communicating in real time or just
>>         downloading
>>         >         after?  I also have Garmin 60 and no problems with
>>         downloading
>>         >         then loading into qgis using .gpx format (on windows)
>>         >         -----Original Message-----
>>         >         From: Giovanni Manghi
>>         [mailto:giovanni.manghi at gmail.com
>>         <mailto:giovanni.manghi at gmail.com>]
>>         >         Sent: 19 November 2010 08:45
>>         >         To: Arthur Nanni
>>         >         Cc: qgis-user at lists.osgeo.org
>>         <mailto:qgis-user at lists.osgeo.org>
>>         >         Subject: Re: [Qgis-user] Download points from Garmin
>>         GPS 60
>>         >         Hi,
>>         >         On Thu, 2010-11-18 at 22:36 -0200, Arthur Nanni wrote:
>>         > > Anybody knows how to download points from Garmin GPS 60 via
>>         >         USB?
>>         > > I tried any forms founded in google, but with no success.
>>         >         I have one and it works out of the box Under Ubuntu (and
>>         >         QGIS).
>>         >         cheers
>>         >         -- Giovanni --
>>         >         _______________________________________________
>>         >         Qgis-user mailing list
>>         > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         > http://lists.osgeo.org/mailman/listinfo/qgis-user
>>         >         The Open University is incorporated by Royal Charter (RC
>>         >         000391), an exempt charity in England & Wales and a
>>         charity
>>         >         registered in Scotland (SC 038302).
>>         > Arthur Nanni
>>         > Ubuntu 10.11!
>>         > É tempo de mudança. Seu computador mais rápido, divertido e
>>         fácil de
>>         > usar.
>>         > Clique para conhecer...
>>     Arthur Nanni
>>     Ubuntu 10.11!
>>     É tempo de mudança. Seu computador mais rápido, divertido e fácil
>>     de usar.
>>     Clique para conhecer... <http://www.ubuntu-br.org>
>> Arthur Nanni
>> Ubuntu 10.11!
>> É tempo de mudança. Seu computador mais rápido, divertido e fácil de usar.
