[Qgis-user] Download points from Garmin GPS 60
Micha Silver micha at arava.co.il
Sat Nov 20 06:08:06 PST 2010
On 11/20/2010 08:03 AM, Noli Sicad wrote:
> As mentioned by Bob, must install the garmin_gps driver / module.
> In Terminal
> sudo modprobe garmin_gps
> I think to make gps working.
In my case, on Ubuntu 10.04, I have to *blacklist* the garmin_gps module
in order for gpsbabel to work.
i.e.:
micha at RMS:~/OSGeo$ grep garmin /etc/modprobe.d/blacklist.conf
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
If not, I get this error:
micha at RMS:~/OSGeo$ sudo modprobe garmin_gps
micha at RMS:~/OSGeo$ sudo lsmod | grep gps
garmin_gps 14947 0
usbserial 33019 2 garmin_gps,cp210x
micha at RMS:~/OSGeo$ gpsbabel -t -i garmin -o gpx -f USB: -F bike_tracks2.gpx
Claim interfaced failed: could not claim interface 0: Device or resource
busy
> On 11/20/10, JC Notter<jc.notter at orange.fr>  wrote:
>> Hi,
>> Maybe it's a problem of driver for your garmin not installed ??
>> Regards
>> JCN
>> Le 19/11/2010 16:02, Arthur Nanni a écrit :
>>> Via terminal and GPSBAbel
>>> arthur at rgsg:~$ gpsbabel -w -i garmin -o gpx -f usb: -F
>>> /home/arthur/documentos/wpt.gpx
>>> Found no Garmin USB devices.
>>> arthur at rgsg:~$
>>> and...
>>> arthur at rgsg:~$ gpsbabel -w -i garmin -o gpx -f /dev/ttyUSB0 -F
>>> [ERROR] XSERIAL: Cannot open serial port '/dev/ttyUSB0': No such file
>>> or directory
>>> [ERROR] Cannot open serial port '/dev/ttyUSB0'
>>> GARMIN:Can't init /dev/ttyUSB0
>>> arthur at rgsg:~$
>>> 2010/11/19 Arthur Nanni<arthur.nanni at gmail.com
>>> <mailto:arthur.nanni at gmail.com>>
>>>      Hi Giovanni,
>>>      Tks for your attention.
>>>      No advances. Look in https://sites.google.com/site/qgis150/
>>>      The status in the GPS screen is connected. OK.
>>>      Any more idea?
>>>      2010/11/19 Giovanni Manghi<giovanni.manghi at gmail.com
>>>      <mailto:giovanni.manghi at gmail.com>>
>>>          Arthur,
>>>          please try fill that "output file" field iwth an actual real path.
>>>          cheers
>>>          -- Giovanni --
>>>          On Fri, 2010-11-19 at 09:24 -0200, Arthur Nanni wrote:
>>>          >  Hi Folks,
>>>          >  I tried this suggestions.
>>>          >  I am use "usb:" and " /dev/ttyUSB0" in the arguments line.
>>>          >  My problem can be viewed in link
>>>          >  I am using Ubuntu 10.04 with QGIS 1.5.0 and GPSBabel 1.3.6
>>>          >  Thanks in advance.
>>>          >  Arthur
>>>          >  2010/11/19 M.E.Dodd<m.e.dodd at open.ac.uk
>>>          <mailto:m.e.dodd at open.ac.uk>>
>>>          >          Do you mean communicating in real time or just
>>>          downloading
>>>          >          after?  I also have Garmin 60 and no problems with
>>>          downloading
>>>          >          then loading into qgis using .gpx format (on windows)
>>>          >          -----Original Message-----
>>>          >          From: Giovanni Manghi
>>>          [mailto:giovanni.manghi at gmail.com
>>>          <mailto:giovanni.manghi at gmail.com>]
>>>          >          Sent: 19 November 2010 08:45
>>>          >          To: Arthur Nanni
>>>          >          Cc: qgis-user at lists.osgeo.org
>>>          <mailto:qgis-user at lists.osgeo.org>
>>>          >          Subject: Re: [Qgis-user] Download points from Garmin
>>>          GPS 60
>>>          >          Hi,
>>>          >          On Thu, 2010-11-18 at 22:36 -0200, Arthur Nanni wrote:
>>>          >  >  Anybody knows how to download points from Garmin GPS 60 via
>>>          >          USB?
>>>          >  >  I tried any forms founded in google, but with no success.
>>>          >          I have one and it works out of the box Under Ubuntu (and
>>>          >          QGIS).
>>>          >          cheers
>>>          >          -- Giovanni --
>>>          >          _______________________________________________
>>>          >          Qgis-user mailing list
>>>          >  Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>>>          >  http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>          >          The Open University is incorporated by Royal Charter (RC
>>>          >          000391), an exempt charity in England&  Wales and a
>>>          charity
>>>          >          registered in Scotland (SC 038302).
>>>          >  Arthur Nanni
>>>          >  Ubuntu 10.11!
>>>          >  É tempo de mudança. Seu computador mais rápido, divertido e
>>>          fácil de
>>>          >  usar.
>>>          >  Clique para conhecer...
>>>      Arthur Nanni
>>>      Ubuntu 10.11!
>>>      É tempo de mudança. Seu computador mais rápido, divertido e fácil
>>>      de usar.
>>>      Clique para conhecer...<http://www.ubuntu-br.org>
>>> Arthur Nanni
>>> Ubuntu 10.11!
>>> É tempo de mudança. Seu computador mais rápido, divertido e fácil de usar.
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
