[Qgis-user] Download points from Garmin GPS 60
Albin Blaschka albin.blaschka at standortsanalyse.net
Sun Nov 21 02:52:41 PST 2010
On 2010-11-20 22:59, Arthur Nanni wrote:
[snip]
> arthur at rgsg:~$ dmesg
> parts with garmin word
> [ 1990.240389] garmin_gps 5-2:1.0: Garmin GPS usb/tty converter detected
> [ 1990.240493] usb 5-2: Garmin GPS usb/tty converter now attached to ttyUSB0
> [ 1993.840078] hub 5-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
> [ 1993.840085] usb 5-2: USB disconnect, address 4
> [ 1993.840301] garmin_gps ttyUSB0: Garmin GPS usb/tty converter now
> disconnected from ttyUSB0
> [ 1993.840316] garmin_gps 5-2:1.0: device disconnected
> What wrong things I do?
> Is very important the correct to me run this procedure. It's a part of
> course program in my university.
Hello!
Please send more from the logfile, not only the lines with "garmin" in
them - there should be some important lines above those lines you sent...
Otherwise, I do not have any idea at the moment - your Garmin should be
available on /dev/ttyUSB0 - does this node exist? Otherwise maybe
consult on the console "man MAKEDEV" ... but here we are deep down in
your system, this should only be "Plan B" (BIG WARNING SIGN)
Has it worked before?
Albin
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
