[Qgis-user] Download points from Garmin GPS 60
Arthur Nanni arthur.nanni at gmail.com
Mon Nov 22 04:52:30 PST 2010
Hi Albin,
> Hello!
> Please send more from the logfile, not only the lines with "garmin" in them
> - there should be some important lines above those lines you sent...
Follow.. (The GPS was physically connected, but the status on GPS screen is
"Not connected")
[    0.231992] libata version 3.00 loaded.
[    0.232067] usbcore: registered new interface driver usbfs
[    0.232078] usbcore: registered new interface driver hub
[    0.232102] usbcore: registered new device driver usb
[    0.232222] ACPI: WMI: Mapper loaded
[    0.232224] PCI: Using ACPI for IRQ routing
[    0.232453] NetLabel: Initializing
[    0.232455] NetLabel:  domain hash size = 128
[    0.232456] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.232470] NetLabel:  unlabeled traffic allowed by default
[    0.232501] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[    0.232506] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[    0.236090] Switching to clocksource tsc
[    0.237927] AppArmor: AppArmor Filesystem Enabled
[    0.237939] pnp: PnP ACPI init
[    0.237955] ACPI: bus type pnp registered
[    0.256256] pnp: PnP ACPI: found 10 devices
[    0.256258] ACPI: ACPI bus type pnp unregistered
[    0.256263] PnPBIOS: Disabled by ACPI PNP
[    0.256276] system 00:02: iomem range 0xfed00000-0xfed003ff has been
reserved
[    0.256284] system 00:04: ioport range 0x400-0x47f has been reserved
[    0.256286] system 00:04: ioport range 0x480-0x48f has been reserved
[    0.256289] system 00:04: ioport range 0xffff-0xffff has been reserved
[    0.256292] system 00:04: ioport range 0xffff-0xffff has been reserved
[    0.256294] system 00:04: ioport range 0x1000-0x107f has been reserved
[    0.256297] system 00:04: ioport range 0x1180-0x11ff has been reserved
[    0.256299] system 00:04: ioport range 0xfe00-0xfe00 has been reserved
[    0.256306] system 00:08: iomem range 0xfed1c000-0xfed1ffff has been
reserved
[    0.256309] system 00:08: iomem range 0xfed10000-0xfed13fff has been
reserved
[    0.256312] system 00:08: iomem range 0xfed18000-0xfed18fff has been
reserved
[    0.256314] system 00:08: iomem range 0xfed19000-0xfed19fff has been
reserved
[    0.256317] system 00:08: iomem range 0xe0000000-0xefffffff has been
reserved
[    0.256319] system 00:08: iomem range 0xfed20000-0xfed3ffff has been
reserved
[    0.256322] system 00:08: iomem range 0xfed40000-0xfed44fff has been
reserved
[    0.256325] system 00:08: iomem range 0xfed45000-0xfed8ffff has been
reserved
[    0.291182] pci 0000:01:00.0: BAR 6: can't allocate mem resource
[0xe0000000-0xdfffffff]
[    0.291186] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[    0.291189] pci 0000:00:01.0:   IO window: 0x2000-0x2fff
[    0.291194] pci 0000:00:01.0:   MEM window: 0xcc000000-0xceffffff
[    0.291198] pci 0000:00:01.0:   PREFETCH window:
0x000000d0000000-0x000000dfffffff
[    0.291203] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[    0.291206] pci 0000:00:1c.0:   IO window: 0x3000-0x3fff
[    0.291213] pci 0000:00:1c.0:   MEM window: 0xf4000000-0xf5ffffff
[    0.291218] pci 0000:00:1c.0:   PREFETCH window:
0x000000f0000000-0x000000f1ffffff
[    0.291226] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:08
[    0.291229] pci 0000:00:1c.1:   IO window: 0x5000-0x5fff
[    0.291235] pci 0000:00:1c.1:   MEM window: 0x80000000-0x801fffff
[    0.291240] pci 0000:00:1c.1:   PREFETCH window:
0x00000080200000-0x000000803fffff
[    0.291248] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:0e
[    0.291251] pci 0000:00:1c.2:   IO window: 0x6000-0x6fff
[    0.291258] pci 0000:00:1c.2:   MEM window: 0xf2100000-0xf21fffff
[    0.291262] pci 0000:00:1c.2:   PREFETCH window:
0x00000080400000-0x000000805fffff
[    0.291271] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:14
[    0.291274] pci 0000:00:1c.3:   IO window: 0x4000-0x4fff
[    0.291281] pci 0000:00:1c.3:   MEM window: 0x80600000-0x809fffff
[    0.291285] pci 0000:00:1c.3:   PREFETCH window:
0x000000f2000000-0x000000f20fffff
[    0.291294] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:1a
[    0.291297] pci 0000:00:1c.4:   IO window: 0x7000-0x7fff
[    0.291303] pci 0000:00:1c.4:   MEM window: 0xf2200000-0xf22fffff
[    0.291308] pci 0000:00:1c.4:   PREFETCH window: 0x80a00000-0x80bfffff
[    0.291316] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:26
[    0.291318] pci 0000:00:1e.0:   IO window: disabled
[    0.291324] pci 0000:00:1e.0:   MEM window: disabled
[    0.291329] pci 0000:00:1e.0:   PREFETCH window: disabled
[    0.291346]   alloc irq_desc for 16 on node -1
[    0.291348]   alloc kstat_irqs on node -1
[    0.291355] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.291359] pci 0000:00:01.0: setting latency timer to 64
[    0.291369]   alloc irq_desc for 17 on node -1
[    0.291371]   alloc kstat_irqs on node -1
[    0.291374] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.291379] pci 0000:00:1c.0: setting latency timer to 64
[    0.291390] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[    0.291394] pci 0000:00:1c.1: setting latency timer to 64
[    0.291404]   alloc irq_desc for 18 on node -1
[    0.291406]   alloc kstat_irqs on node -1
[    0.291409] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.291414] pci 0000:00:1c.2: setting latency timer to 64
[    0.291423]   alloc irq_desc for 19 on node -1
[    0.291425]   alloc kstat_irqs on node -1
[    0.291428] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[    0.291433] pci 0000:00:1c.3: setting latency timer to 64
[    0.291453] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    0.291459] pci 0000:00:1c.4: setting latency timer to 64
[    0.291467] pci 0000:00:1e.0: setting latency timer to 64
[    0.291471] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
[    0.291474] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[    0.291476] pci_bus 0000:01: resource 0 io:  [0x2000-0x2fff]
[    0.291479] pci_bus 0000:01: resource 1 mem: [0xcc000000-0xceffffff]
[    0.291481] pci_bus 0000:01: resource 2 pref mem [0xd0000000-0xdfffffff]
[    0.291484] pci_bus 0000:02: resource 0 io:  [0x3000-0x3fff]
[    0.291486] pci_bus 0000:02: resource 1 mem: [0xf4000000-0xf5ffffff]
[    0.291489] pci_bus 0000:02: resource 2 pref mem [0xf0000000-0xf1ffffff]
[    0.291491] pci_bus 0000:08: resource 0 io:  [0x5000-0x5fff]
[    0.291493] pci_bus 0000:08: resource 1 mem: [0x80000000-0x801fffff]
[    0.291496] pci_bus 0000:08: resource 2 pref mem [0x80200000-0x803fffff]
[    0.291498] pci_bus 0000:0e: resource 0 io:  [0x6000-0x6fff]
[    0.291501] pci_bus 0000:0e: resource 1 mem: [0xf2100000-0xf21fffff]
[    0.291503] pci_bus 0000:0e: resource 2 pref mem [0x80400000-0x805fffff]
[    0.291505] pci_bus 0000:14: resource 0 io:  [0x4000-0x4fff]
[    0.291508] pci_bus 0000:14: resource 1 mem: [0x80600000-0x809fffff]
[    0.291510] pci_bus 0000:14: resource 2 pref mem [0xf2000000-0xf20fffff]
[    0.291512] pci_bus 0000:1a: resource 0 io:  [0x7000-0x7fff]
[    0.291515] pci_bus 0000:1a: resource 1 mem: [0xf2200000-0xf22fffff]
[    0.291517] pci_bus 0000:1a: resource 2 pref mem [0x80a00000-0x80bfffff]
[    0.291520] pci_bus 0000:26: resource 3 io:  [0x00-0xffff]
[    0.291522] pci_bus 0000:26: resource 4 mem: [0x000000-0xffffffff]
[    0.291562] NET: Registered protocol family 2
[    0.291659] IP route cache hash table entries: 32768 (order: 5, 131072
bytes)
[    0.291969] TCP established hash table entries: 131072 (order: 8, 1048576
bytes)
[    0.292425] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.292677] TCP: Hash tables configured (established 131072 bind 65536)
[    0.292679] TCP reno registered
[    0.292764] NET: Registered protocol family 1
[    0.292963] pci 0000:01:00.0: Boot video device
[    0.292996] Simple Boot Flag at 0x36 set to 0x1
[    0.293149] cpufreq-nforce2: No nForce2 chipset.
[    0.293176] Scanning for low memory corruption every 60 seconds
[    0.293306] audit: initializing netlink socket (disabled)
[    0.293315] type=2000 audit(1290426910.291:1): initialized
[    0.302485] highmem bounce pool size: 64 pages
[    0.302490] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.303912] VFS: Disk quotas dquot_6.5.2
[    0.303965] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.304493] fuse init (API version 7.13)
[    0.304572] msgmni has been set to 1681
[    0.304769] alg: No test for stdrng (krng)
[    0.304816] Block layer SCSI generic (bsg) driver version 0.4 loaded
(major 253)
[    0.304819] io scheduler noop registered
[    0.304821] io scheduler anticipatory registered
[    0.304822] io scheduler deadline registered
[    0.304858] io scheduler cfq registered (default)
[    0.305009]   alloc irq_desc for 24 on node -1
[    0.305011]   alloc kstat_irqs on node -1
[    0.305019] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
[    0.305026] pcieport 0000:00:01.0: setting latency timer to 64
[    0.305155]   alloc irq_desc for 25 on node -1
[    0.305156]   alloc kstat_irqs on node -1
[    0.305165] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
[    0.305176] pcieport 0000:00:1c.0: setting latency timer to 64
[    0.305327]   alloc irq_desc for 26 on node -1
[    0.305329]   alloc kstat_irqs on node -1
[    0.305338] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
[    0.305349] pcieport 0000:00:1c.1: setting latency timer to 64
[    0.305501]   alloc irq_desc for 27 on node -1
[    0.305502]   alloc kstat_irqs on node -1
[    0.305511] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
[    0.305522] pcieport 0000:00:1c.2: setting latency timer to 64
[    0.305675]   alloc irq_desc for 28 on node -1
[    0.305676]   alloc kstat_irqs on node -1
[    0.305685] pcieport 0000:00:1c.3: irq 28 for MSI/MSI-X
[    0.305696] pcieport 0000:00:1c.3: setting latency timer to 64
[    0.305850]   alloc irq_desc for 29 on node -1
[    0.305852]   alloc kstat_irqs on node -1
[    0.305860] pcieport 0000:00:1c.4: irq 29 for MSI/MSI-X
[    0.305871] pcieport 0000:00:1c.4: setting latency timer to 64
[    0.305972] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.306158] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.307319] ACPI: AC Adapter [ACAD] (on-line)
[    0.307390] input: Lid Switch as
/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.307426] ACPI: Lid Switch [LID0]
[    0.307472] input: Power Button as
/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.307474] ACPI: Power Button [PWRB]
[    0.307515] input: Power Button as
/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.307517] ACPI: Power Button [PWRF]
[    0.308265] ACPI: SSDT 7fd1aca0 00223 (v01  PmRef  Cpu0Ist 00003000 INTL
20050624)
[    0.308726] ACPI: SSDT 7fd19620 00549 (v01  PmRef  Cpu0Cst 00003001 INTL
20050624)
[    0.310711] Monitor-Mwait will be used to enter C-1 state
[    0.310737] Monitor-Mwait will be used to enter C-2 state
[    0.310742] Marking TSC unstable due to TSC halts in idle
[    0.310792] processor LNXCPU:00: registered as cooling_device0
[    0.311198] ACPI: SSDT 7fd1aa20 001CF (v01  PmRef    ApIst 00003000 INTL
20050624)
[    0.311552] ACPI: SSDT 7fd1af20 0008D (v01  PmRef    ApCst 00003000 INTL
20050624)
[    0.312064] Switching to clocksource hpet
[    0.315762] processor LNXCPU:01: registered as cooling_device1
[    0.338249] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.339506] brd: module loaded
[    0.339932] loop: module loaded
[    0.340033] input: Macintosh mouse button emulation as
/devices/virtual/input/input3
[    0.340419] Fixed MDIO Bus: probed
[    0.340452] PPP generic driver version 2.4.2
[    0.340482] tun: Universal TUN/TAP device driver, 1.6
[    0.340484] tun: (C) 1999-2004 Max Krasnyansky <maxk at qualcomm.com>
[    0.340553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.340578] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 19 (level, low) ->
IRQ 19
[    0.340595] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[    0.340599] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[    0.340626] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus
number 1
[    0.340655] ehci_hcd 0000:00:1a.7: debug port 1
[    0.344538] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported
[    0.344556] ehci_hcd 0000:00:1a.7: irq 19, io mem 0xf2504800
[    0.348490] isapnp: Scanning for PnP cards...
[    0.365602] ACPI: Battery Slot [BAT1] (battery present)
[    0.397579] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    0.397708] usb usb1: configuration #1 chosen from 1 choice
[    0.397735] hub 1-0:1.0: USB hub found
[    0.397744] hub 1-0:1.0: 6 ports detected
[    0.397818]   alloc irq_desc for 23 on node -1
[    0.397820]   alloc kstat_irqs on node -1
[    0.397826] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) ->
IRQ 23
[    0.397849] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    0.397852] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    0.397884] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus
number 2
[    0.397913] ehci_hcd 0000:00:1d.7: debug port 1
[    0.401791] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[    0.401942] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf2504c00
[    0.446413] Freeing initrd memory: 12255k freed
[    0.449415] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    0.449700] usb usb2: configuration #1 chosen from 1 choice
[    0.449741] hub 2-0:1.0: USB hub found
[    0.449765] hub 2-0:1.0: 6 ports detected
[    0.449870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.449904] uhci_hcd: USB Universal Host Controller Interface driver
[    0.450014] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) ->
IRQ 16
[    0.450028] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[    0.450033] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    0.450090] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus
number 3
[    0.450144] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
[    0.450248] usb usb3: configuration #1 chosen from 1 choice
[    0.450272] hub 3-0:1.0: USB hub found
[    0.450282] hub 3-0:1.0: 2 ports detected
[    0.450341]   alloc irq_desc for 21 on node -1
[    0.450343]   alloc kstat_irqs on node -1
[    0.450352] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) ->
IRQ 21
[    0.450359] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[    0.450363] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    0.450398] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus
number 4
[    0.450433] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
[    0.450550] usb usb4: configuration #1 chosen from 1 choice
[    0.450574] hub 4-0:1.0: USB hub found
[    0.450584] hub 4-0:1.0: 2 ports detected
[    0.450658] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 19 (level, low) ->
IRQ 19
[    0.450666] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[    0.450669] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[    0.450703] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus
number 5
[    0.450732] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00001840
[    0.450823] usb usb5: configuration #1 chosen from 1 choice
[    0.450847] hub 5-0:1.0: USB hub found
[    0.450855] hub 5-0:1.0: 2 ports detected
[    0.450919] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) ->
IRQ 23
[    0.450927] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    0.450930] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    0.450963] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus
number 6
[    0.450992] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001860
[    0.451103] usb usb6: configuration #1 chosen from 1 choice
[    0.451127] hub 6-0:1.0: USB hub found
[    0.451137] hub 6-0:1.0: 2 ports detected
[    0.451194] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) ->
IRQ 19
[    0.451202] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    0.451206] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    0.451254] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus
number 7
[    0.451281] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001880
[    0.451381] usb usb7: configuration #1 chosen from 1 choice
[    0.451413] hub 7-0:1.0: USB hub found
[    0.451421] hub 7-0:1.0: 2 ports detected
[    0.451469] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) ->
IRQ 18
[    0.451476] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    0.451480] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    0.451512] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus
number 8
[    0.451560] uhci_hcd 0000:00:1d.2: irq 18, io base 0x000018a0
[    0.451656] usb usb8: configuration #1 chosen from 1 choice
[    0.451687] hub 8-0:1.0: USB hub found
[    0.451696] hub 8-0:1.0: 2 ports detected
[    0.451830] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64
irq 1,12
[    0.536523] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.536532] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.536699] mice: PS/2 mouse device common for all mice
[    0.538918] rtc_cmos 00:05: RTC can wake from S4
[    0.538962] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    0.538992] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.539101] device-mapper: uevent: version 1.0.3
[    0.541078] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised:
dm-devel at redhat.com
[    0.541142] device-mapper: multipath: version 1.1.0 loaded
[    0.541145] device-mapper: multipath round-robin: version 1.0.0 loaded
[    0.541253] EISA: Probing bus 0 at eisa.0
[    0.541260] Cannot allocate resource for EISA slot 1
[    0.541263] Cannot allocate resource for EISA slot 2
[    0.541265] Cannot allocate resource for EISA slot 3
[    0.541267] Cannot allocate resource for EISA slot 4
[    0.541269] Cannot allocate resource for EISA slot 5
[    0.541271] Cannot allocate resource for EISA slot 6
[    0.541273] Cannot allocate resource for EISA slot 7
[    0.541279] EISA: Detected 0 cards.
[    0.541390] cpuidle: using governor ladder
[    0.541468] cpuidle: using governor menu
[    0.541886] TCP cubic registered
[    0.542021] NET: Registered protocol family 10
[    0.542445] lo: Disabled Privacy Extensions
[    0.542757] NET: Registered protocol family 17
[    0.543318] Using IPI No-Shortcut mode
[    0.543379] PM: Resume from disk failed.
[    0.543391] registered taskstats version 1
[    0.544188]   Magic number: 2:740:934
[    0.544270] rtc_cmos 00:05: setting system clock to 2010-11-22 11:55:11
UTC (1290426911)
[    0.544273] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.544274] EDD information not available.
[    0.570173] input: AT Translated Set 2 keyboard as
/devices/platform/i8042/serio0/input/input4
[    0.760080] isapnp: No Plug & Play device found
[    0.760094] Freeing unused kernel memory: 656k freed
[    0.760484] Write protecting the kernel text: 4684k
[    0.760531] Write protecting the kernel read-only data: 1840k
[    0.776785] udev: starting version 151
[    0.870905] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    0.870928] r8169 0000:14:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ
19
[    0.870971] r8169 0000:14:00.0: setting latency timer to 64
[    0.871028]   alloc irq_desc for 30 on node -1
[    0.871030]   alloc kstat_irqs on node -1
[    0.871045] r8169 0000:14:00.0: irq 30 for MSI/MSI-X
[    0.871643] eth0: RTL8168c/8111c at 0xf80a0000, 00:26:22:13:ac:34, XID
1c4000c0 IRQ 30
[    0.874993] Linux agpgart interface v0.103
[    0.880048] b43-pci-bridge 0000:0e:00.0: PCI INT A -> GSI 18 (level, low)
-> IRQ 18
[    0.880067] b43-pci-bridge 0000:0e:00.0: setting latency timer to 64
[    0.883673] ahci 0000:00:1f.2: version 3.0
[    0.883687] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.883727]   alloc irq_desc for 31 on node -1
[    0.883729]   alloc kstat_irqs on node -1
[    0.883741] ahci 0000:00:1f.2: irq 31 for MSI/MSI-X
[    0.883795] ahci: SSS flag set, parallel bus scan disabled
[    0.883834] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 4 ports 3 Gbps
0x33 impl SATA mode
[    0.883837] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio
slum part ccc ems
[    0.883842] ahci 0000:00:1f.2: setting latency timer to 64
[    0.893226] acpi device:01: registered as cooling_device2
[    0.893419] input: Video Bus as
/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input5
[    0.893464] ACPI: Video Device [PEGP] (multi-head: yes  rom: no  post:
no)
[    0.905170] scsi0 : ahci
[    0.905342] scsi1 : ahci
[    0.905426] scsi2 : ahci
[    0.905509] scsi3 : ahci
[    0.905594] scsi4 : ahci
[    0.905677] scsi5 : ahci
[    0.905721] ata1: SATA max UDMA/133 abar m2048 at 0xf2504000 port 0xf2504100
irq 31
[    0.905725] ata2: SATA max UDMA/133 abar m2048 at 0xf2504000 port 0xf2504180
irq 31
[    0.905727] ata3: DUMMY
[    0.905728] ata4: DUMMY
[    0.905731] ata5: SATA max UDMA/133 abar m2048 at 0xf2504000 port 0xf2504300
irq 31
[    0.905735] ata6: SATA max UDMA/133 abar m2048 at 0xf2504000 port 0xf2504380
irq 31
[    0.940177] ssb: Sonics Silicon Backplane found on PCI device
0000:0e:00.0
[    0.952051] usb 2-2: new high speed USB device using ehci_hcd and address
3
[    1.085011] usb 2-2: configuration #1 chosen from 1 choice
[    1.196073] usb 2-3: new high speed USB device using ehci_hcd and address
4
[    1.224074] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.231399] ata1.00: ATA-8: SAMSUNG HM320JI, 2SS00_03, max UDMA7
[    1.231404] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth
31/32), AA
[    1.238891] ata1.00: configured for UDMA/133
[    1.252217] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG HM320JI
2SS0 PQ: 0 ANSI: 5
[    1.252355] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.252442] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320
GB/298 GiB)
[    1.252482] sd 0:0:0:0: [sda] Write Protect is off
[    1.252484] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.252505] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled,
doesn't support DPO or FUA
[    1.252622]  sda: sda1 sda2 sda3 sda4
[    1.293048] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.372618] usb 2-3: configuration #1 chosen from 1 choice
[    1.612079] usb 3-1: new full speed USB device using uhci_hcd and address
2
[    1.784325] usb 3-1: configuration #1 chosen from 1 choice
[    1.976111] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.989068] ata2.00: ATAPI: Optiarc DVD RW AD-7560S, SX03, max UDMA/100
[    2.002507] ata2.00: configured for UDMA/100
[    2.017130] scsi 1:0:0:0: CD-ROM            Optiarc  DVD RW AD-7560S
SX03 PQ: 0 ANSI: 5
[    2.022461] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2
cdda tray
[    2.022466] Uniform CD-ROM driver Revision: 3.20
[    2.022622] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.022679] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    2.024097] usb 6-1: new low speed USB device using uhci_hcd and address
2
[    2.199213] usb 6-1: configuration #1 chosen from 1 choice
[    2.340102] ata5: SATA link down (SStatus 0 SControl 300)
[    2.676123] ata6: SATA link down (SStatus 0 SControl 300)
[    2.697011] usbcore: registered new interface driver hiddev
[    2.711448] input: Darfon USB Optical Mous as
/devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input6
[    2.711539] generic-usb 0003:0D62:A100.0001: input,hidraw0: USB HID v1.10
Mouse [Darfon USB Optical Mous] on usb-0000:00:1d.0-1/input0
[    2.711563] usbcore: registered new interface driver usbhid
[    2.711566] usbhid: v2.6:USB HID core driver
[    3.177677] uvesafb: NVIDIA Corporation, G98 Board - 05686e90, Chip Rev
, OEM: NVIDIA, VBE v3.0
[    3.214449] uvesafb: protected mode interface info at c000:c910
[    3.214452] uvesafb: pmi: set display start = c00cc973, set palette =
c00cc9ce
[    3.214454] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8
3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
[    3.281553] uvesafb: VBIOS/hardware doesn't support DDC transfers
[    3.281555] uvesafb: no monitor limits have been set, default refresh
rate will be used
[    3.281750] uvesafb: scrolling: ywrap using protected mode interface,
yres_virtual=1600
[    3.282729] uvesafb: framebuffer at 0xcd000000, mapped to 0xf8200000,
using 8000k, total 14336k
[    3.282732] fb0: VESA VGA frame buffer device
[    3.729853] Console: switching to colour frame buffer device 160x50
[    4.053631] EXT4-fs (sda1): mounted filesystem with ordered data mode
[   14.872727] udev: starting version 151
[   14.973411] vga16fb: initializing
[   14.973415] vga16fb: mapped to 0xc00a0000
[   14.973419] vga16fb: not registering due to another framebuffer present
[   14.980197] Adding 4882424k swap on /dev/sda2.  Priority:-1 extents:1
across:4882424k
[   15.043608] lp: driver loaded but no devices found
[   15.136206] nvidia: module license 'NVIDIA' taints kernel.
[   15.136210] Disabling lock debugging due to kernel taint
[   15.151011] type=1505 audit(1290426926.104:2):  operation="profile_load"
pid=700 name="/sbin/dhclient3"
[   15.151639] type=1505 audit(1290426926.104:3):  operation="profile_load"
pid=700 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   15.151972] type=1505 audit(1290426926.104:4):  operation="profile_load"
pid=700 name="/usr/lib/connman/scripts/dhclient-script"
[   15.446033] sdhci: Secure Digital Host Controller Interface driver
[   15.446035] sdhci: Copyright(c) Pierre Ossman
[   15.447249] sdhci-pci 0000:1a:00.0: SDHCI controller found [197b:2382]
(rev 0)
[   15.447271] sdhci-pci 0000:1a:00.0: PCI INT A -> GSI 16 (level, low) ->
IRQ 16
[   15.447313] sdhci-pci 0000:1a:00.0: setting latency timer to 64
[   15.447346] Registered led device: mmc0::
[   15.447379] mmc0: SDHCI controller on PCI [0000:1a:00.0] using ADMA
[   15.448161] sdhci-pci 0000:1a:00.2: SDHCI controller found [197b:2381]
(rev 0)
[   15.448181] sdhci-pci 0000:1a:00.2: PCI INT A -> GSI 16 (level, low) ->
IRQ 16
[   15.448188] sdhci-pci 0000:1a:00.2: Refusing to bind to secondary
interface.
[   15.448195] sdhci-pci 0000:1a:00.2: PCI INT A disabled
[   15.448970] Bluetooth: Core ver 2.15
[   15.449012] NET: Registered protocol family 31
[   15.449014] Bluetooth: HCI device and connection manager initialized
[   15.449016] Bluetooth: HCI socket layer initialized
[   15.450974] Bluetooth: Generic Bluetooth USB driver ver 0.6
[   15.451644] usbcore: registered new interface driver btusb
[   15.461463] tpm_tis 00:09: 1.2 TPM (device-id 0xB, rev-id 16)
[   15.482654] cfg80211: Calling CRDA to update world regulatory domain
[   15.511604] b43-phy0: Broadcom 4311 WLAN found (core revision 10)
[   15.527812] jmb38x_ms 0000:1a:00.3: PCI INT A -> GSI 16 (level, low) ->
IRQ 16
[   15.527821] jmb38x_ms 0000:1a:00.3: setting latency timer to 64
[   15.620606]   alloc irq_desc for 22 on node -1
[   15.620609]   alloc kstat_irqs on node -1
[   15.620616] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) ->
IRQ 22
[   15.620656] HDA Intel 0000:00:1b.0: setting latency timer to 64
[   15.624732] phy0: Selected rate control algorithm 'minstrel'
[   15.625402] Registered led device: b43-phy0::tx
[   15.625418] Registered led device: b43-phy0::rx
[   15.625433] Registered led device: b43-phy0::radio
[   15.625490] Broadcom 43xx driver loaded [ Features: PL, Firmware-ID: FW13
[   15.640927] Linux video capture interface: v2.00
[   15.646360] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (064e:a115)
[   15.664573] input: USB 2.0 Camera as
/devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3:1.0/input/input7
[   15.664622] usbcore: registered new interface driver uvcvideo
[   15.664624] USB Video Class driver (v0.1.0)
[   15.681829] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ
16
[   15.681845] nvidia 0000:01:00.0: setting latency timer to 64
[   15.682019] NVRM: loading NVIDIA UNIX x86 Kernel Module  173.14.22  Sun
Nov  8 20:26:31 PST 2009
[   15.765402] hda_codec: ALC268: BIOS auto-probing.
[   15.765851] input: HDA Digital PCBeep as
/devices/pci0000:00/0000:00:1b.0/input/input8
[   15.902934] cfg80211: World regulatory domain updated:
[   15.902937]     (start_freq - end_freq @ bandwidth), (max_antenna_gain,
max_eirp)
[   15.902940]     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000
mBm)
[   15.902942]     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000
mBm)
[   15.902945]     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000
mBm)
[   15.902947]     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000
mBm)
[   15.902949]     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000
mBm)
[   16.592634] EXT4-fs (sda3): mounted filesystem with ordered data mode
[   16.672865] Synaptics Touchpad, model: 1, fw: 7.0, id: 0x1c0b1, caps:
0xd04711/0xa00000
[   16.784919] input: SynPS/2 Synaptics TouchPad as
/devices/platform/i8042/serio1/input/input9
[   17.993421] EXT4-fs (sda4): mounted filesystem with ordered data mode
[   18.181329] type=1505 audit(1290426929.135:5):  operation="profile_load"
pid=996 name="/usr/share/gdm/guest-session/Xsession"
[   18.189220] type=1505 audit(1290426929.143:6):
operation="profile_replace" pid=997 name="/sbin/dhclient3"
[   18.189845] type=1505 audit(1290426929.143:7):
[   18.190181] type=1505 audit(1290426929.143:8):
[   18.193576] type=1505 audit(1290426929.147:9):  operation="profile_load"
pid=999 name="/usr/bin/evince"
[   18.201745] type=1505 audit(1290426929.155:10):  operation="profile_load"
pid=999 name="/usr/bin/evince-previewer"
[   18.206655] type=1505 audit(1290426929.159:11):  operation="profile_load"
pid=999 name="/usr/bin/evince-thumbnailer"
[   18.236142] b43 ssb0:0: firmware: requesting b43/ucode5.fw
[   18.260896] b43 ssb0:0: firmware: requesting b43/pcm5.fw
[   18.263044] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
[   18.267744] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
[   18.388066] b43-phy0: Loading firmware version 410.2160 (2007-05-26
15:32:10)
[   18.476468] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   18.488531] r8169: eth0: link down
[   18.488703] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   18.584189] Bluetooth: L2CAP ver 2.14
[   18.584194] Bluetooth: L2CAP socket layer initialized
[   18.594706] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.594710] Bluetooth: BNEP filters: protocol multicast
[   18.604915] Bridge firewalling registered
[   18.618044] Bluetooth: SCO (Voice Link) ver 0.6
[   18.618047] Bluetooth: SCO socket layer initialized
[   18.695144] ppdev: user-space parallel port driver
[   18.728069] Bluetooth: RFCOMM TTY layer initialized
[   18.728073] Bluetooth: RFCOMM socket layer initialized
[   18.728075] Bluetooth: RFCOMM ver 1.11
[   24.977053] CE: hpet increasing min_delta_ns to 15000 nsec
[   31.041054] CE: hpet increasing min_delta_ns to 22500 nsec
[   87.589113] wlan0: deauthenticating from 00:1a:3f:56:4c:04 by local
choice (reason=3)
[   87.589312] wlan0: direct probe to AP 00:1a:3f:56:4c:04 (try 1)
[   87.592234] wlan0: direct probe responded
[   87.592238] wlan0: authenticate with AP 00:1a:3f:56:4c:04 (try 1)
[   87.594011] wlan0: authenticated
[   87.594030] wlan0: associate with AP 00:1a:3f:56:4c:04 (try 1)
[   87.596144] wlan0: RX AssocResp from 00:1a:3f:56:4c:04 (capab=0x431
status=0 aid=2)
[   87.596147] wlan0: associated
[   87.596870] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   98.180138] wlan0: no IPv6 routers present
[ 1159.132175] usb 1-6: new high speed USB device using ehci_hcd and address
3
[ 1159.267639] usb 1-6: configuration #1 chosen from 1 choice
[ 1159.335800] Initializing USB Mass Storage driver...
[ 1159.336227] scsi6 : SCSI emulation for USB Mass Storage devices
[ 1159.336374] usbcore: registered new interface driver usb-storage
[ 1159.336379] USB Mass Storage support registered.
[ 1159.339824] usb-storage: device found at 3
[ 1159.339829] usb-storage: waiting for device to settle before scanning
[ 1164.336482] usb-storage: device scan complete
[ 1164.362239] scsi 6:0:0:0: Direct-Access     HP       v100w
PMAP PQ: 0 ANSI: 0 CCS
[ 1164.363057] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 1168.898439] sd 6:0:0:0: [sdb] 15667200 512-byte logical blocks: (8.02
GB/7.47 GiB)
[ 1168.899183] sd 6:0:0:0: [sdb] Write Protect is off
[ 1168.899189] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 1168.899193] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1168.903577] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1168.903584]  sdb: sdb1
[ 1168.925453] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1168.925461] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 2785.036180] usb 8-2: new full speed USB device using uhci_hcd and address
2
[ 2785.191356] usb 8-2: configuration #1 chosen from 1 choice
[ 2792.152240] hub 8-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[ 2792.152249] usb 8-2: USB disconnect, address 2
[ 2792.392068] usb 8-2: new full speed USB device using uhci_hcd and address
3
[ 2792.456153] hub 8-0:1.0: unable to enumerate USB device on port 2
[ 2792.834994] hub 8-0:1.0: unable to enumerate USB device on port 2
[ 2821.740079] hub 8-0:1.0: unable to enumerate USB device on port 2
arthur at rgsg:~$
There is a way to confirm what configuration files shoud be modified? If
yes, point me files please?
The GPS now not more appears with "connected" status, just "not connected".
tks for your patience.
Arthur
> Otherwise, I do not have any idea at the moment - your Garmin should be
> available on /dev/ttyUSB0 - does this node exist? Otherwise maybe consult on
> the console "man MAKEDEV" ... but here we are deep down in your system, this
> should only be "Plan B" (BIG WARNING SIGN)
> Has it worked before?
> Albin
> | Albin Blaschka, Mag.rer.nat.
> | Etrichstrasse 26, A-5020 Salzburg
> | * www.albinblaschka.info * www.thinkanimal.info *
> | - It's hard to live in the mountains, hard but not hopeless!
Arthur Nanni
Ubuntu 10.11!
É tempo de mudança. Seu computador mais rápido, divertido e fácil de usar.
Clique para conhecer... <http://www.ubuntu-br.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101122/05390288/attachment.html>
