[Qgis-user] Download points from Garmin GPS 60
Arthur Nanni arthur.nanni at gmail.com
Mon Nov 22 04:55:11 PST 2010
My lsmod
arthur at rgsg:~$ lsmod
Module                  Size  Used by
garmin_gps             14947  0
usbserial              33019  1 garmin_gps
2010/11/22 Arthur Nanni <arthur.nanni at gmail.com>
> Hi Albin,
>> Hello!
>> Please send more from the logfile, not only the lines with "garmin" in
>> them - there should be some important lines above those lines you sent...
> Follow.. (The GPS was physically connected, but the status on GPS screen
> is "Not connected")
> [    0.231992] libata version 3.00 loaded.
> [    0.232067] usbcore: registered new interface driver usbfs
> [    0.232078] usbcore: registered new interface driver hub
> [    0.232102] usbcore: registered new device driver usb
> [    0.232222] ACPI: WMI: Mapper loaded
> [    0.232224] PCI: Using ACPI for IRQ routing
> [    0.232453] NetLabel: Initializing
> [    0.232455] NetLabel:  domain hash size = 128
> [    0.232456] NetLabel:  protocols = UNLABELED CIPSOv4
> [    0.232470] NetLabel:  unlabeled traffic allowed by default
> [    0.232501] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
> [    0.232506] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
> [    0.236090] Switching to clocksource tsc
> [    0.237927] AppArmor: AppArmor Filesystem Enabled
> [    0.237939] pnp: PnP ACPI init
> [    0.237955] ACPI: bus type pnp registered
> [    0.256256] pnp: PnP ACPI: found 10 devices
> [    0.256258] ACPI: ACPI bus type pnp unregistered
> [    0.256263] PnPBIOS: Disabled by ACPI PNP
> [    0.256276] system 00:02: iomem range 0xfed00000-0xfed003ff has been
> reserved
> [    0.256284] system 00:04: ioport range 0x400-0x47f has been reserved
> [    0.256286] system 00:04: ioport range 0x480-0x48f has been reserved
> [    0.256289] system 00:04: ioport range 0xffff-0xffff has been reserved
> [    0.256292] system 00:04: ioport range 0xffff-0xffff has been reserved
> [    0.256294] system 00:04: ioport range 0x1000-0x107f has been reserved
> [    0.256297] system 00:04: ioport range 0x1180-0x11ff has been reserved
> [    0.256299] system 00:04: ioport range 0xfe00-0xfe00 has been reserved
> [    0.256306] system 00:08: iomem range 0xfed1c000-0xfed1ffff has been
> reserved
> [    0.256309] system 00:08: iomem range 0xfed10000-0xfed13fff has been
> reserved
> [    0.256312] system 00:08: iomem range 0xfed18000-0xfed18fff has been
> reserved
> [    0.256314] system 00:08: iomem range 0xfed19000-0xfed19fff has been
> reserved
> [    0.256317] system 00:08: iomem range 0xe0000000-0xefffffff has been
> reserved
> [    0.256319] system 00:08: iomem range 0xfed20000-0xfed3ffff has been
> reserved
> [    0.256322] system 00:08: iomem range 0xfed40000-0xfed44fff has been
> reserved
> [    0.256325] system 00:08: iomem range 0xfed45000-0xfed8ffff has been
> reserved
> [    0.291182] pci 0000:01:00.0: BAR 6: can't allocate mem resource
> [0xe0000000-0xdfffffff]
> [    0.291186] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
> [    0.291189] pci 0000:00:01.0:   IO window: 0x2000-0x2fff
> [    0.291194] pci 0000:00:01.0:   MEM window: 0xcc000000-0xceffffff
> [    0.291198] pci 0000:00:01.0:   PREFETCH window:
> 0x000000d0000000-0x000000dfffffff
> [    0.291203] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
> [    0.291206] pci 0000:00:1c.0:   IO window: 0x3000-0x3fff
> [    0.291213] pci 0000:00:1c.0:   MEM window: 0xf4000000-0xf5ffffff
> [    0.291218] pci 0000:00:1c.0:   PREFETCH window:
> 0x000000f0000000-0x000000f1ffffff
> [    0.291226] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:08
> [    0.291229] pci 0000:00:1c.1:   IO window: 0x5000-0x5fff
> [    0.291235] pci 0000:00:1c.1:   MEM window: 0x80000000-0x801fffff
> [    0.291240] pci 0000:00:1c.1:   PREFETCH window:
> 0x00000080200000-0x000000803fffff
> [    0.291248] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:0e
> [    0.291251] pci 0000:00:1c.2:   IO window: 0x6000-0x6fff
> [    0.291258] pci 0000:00:1c.2:   MEM window: 0xf2100000-0xf21fffff
> [    0.291262] pci 0000:00:1c.2:   PREFETCH window:
> 0x00000080400000-0x000000805fffff
> [    0.291271] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:14
> [    0.291274] pci 0000:00:1c.3:   IO window: 0x4000-0x4fff
> [    0.291281] pci 0000:00:1c.3:   MEM window: 0x80600000-0x809fffff
> [    0.291285] pci 0000:00:1c.3:   PREFETCH window:
> 0x000000f2000000-0x000000f20fffff
> [    0.291294] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:1a
> [    0.291297] pci 0000:00:1c.4:   IO window: 0x7000-0x7fff
> [    0.291303] pci 0000:00:1c.4:   MEM window: 0xf2200000-0xf22fffff
> [    0.291308] pci 0000:00:1c.4:   PREFETCH window: 0x80a00000-0x80bfffff
> [    0.291316] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:26
> [    0.291318] pci 0000:00:1e.0:   IO window: disabled
> [    0.291324] pci 0000:00:1e.0:   MEM window: disabled
> [    0.291329] pci 0000:00:1e.0:   PREFETCH window: disabled
> [    0.291346]   alloc irq_desc for 16 on node -1
> [    0.291348]   alloc kstat_irqs on node -1
> [    0.291355] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
> [    0.291359] pci 0000:00:01.0: setting latency timer to 64
> [    0.291369]   alloc irq_desc for 17 on node -1
> [    0.291371]   alloc kstat_irqs on node -1
> [    0.291374] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
> [    0.291379] pci 0000:00:1c.0: setting latency timer to 64
> [    0.291390] pci 0000:00:1c.1: PCI INT B -> GSI 16 (level, low) -> IRQ 16
> [    0.291394] pci 0000:00:1c.1: setting latency timer to 64
> [    0.291404]   alloc irq_desc for 18 on node -1
> [    0.291406]   alloc kstat_irqs on node -1
> [    0.291409] pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
> [    0.291414] pci 0000:00:1c.2: setting latency timer to 64
> [    0.291423]   alloc irq_desc for 19 on node -1
> [    0.291425]   alloc kstat_irqs on node -1
> [    0.291428] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
> [    0.291433] pci 0000:00:1c.3: setting latency timer to 64
> [    0.291453] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
> [    0.291459] pci 0000:00:1c.4: setting latency timer to 64
> [    0.291467] pci 0000:00:1e.0: setting latency timer to 64
> [    0.291471] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
> [    0.291474] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
> [    0.291476] pci_bus 0000:01: resource 0 io:  [0x2000-0x2fff]
> [    0.291479] pci_bus 0000:01: resource 1 mem: [0xcc000000-0xceffffff]
> [    0.291481] pci_bus 0000:01: resource 2 pref mem [0xd0000000-0xdfffffff]
> [    0.291484] pci_bus 0000:02: resource 0 io:  [0x3000-0x3fff]
> [    0.291486] pci_bus 0000:02: resource 1 mem: [0xf4000000-0xf5ffffff]
> [    0.291489] pci_bus 0000:02: resource 2 pref mem [0xf0000000-0xf1ffffff]
> [    0.291491] pci_bus 0000:08: resource 0 io:  [0x5000-0x5fff]
> [    0.291493] pci_bus 0000:08: resource 1 mem: [0x80000000-0x801fffff]
> [    0.291496] pci_bus 0000:08: resource 2 pref mem [0x80200000-0x803fffff]
> [    0.291498] pci_bus 0000:0e: resource 0 io:  [0x6000-0x6fff]
> [    0.291501] pci_bus 0000:0e: resource 1 mem: [0xf2100000-0xf21fffff]
> [    0.291503] pci_bus 0000:0e: resource 2 pref mem [0x80400000-0x805fffff]
> [    0.291505] pci_bus 0000:14: resource 0 io:  [0x4000-0x4fff]
> [    0.291508] pci_bus 0000:14: resource 1 mem: [0x80600000-0x809fffff]
> [    0.291510] pci_bus 0000:14: resource 2 pref mem [0xf2000000-0xf20fffff]
> [    0.291512] pci_bus 0000:1a: resource 0 io:  [0x7000-0x7fff]
> [    0.291515] pci_bus 0000:1a: resource 1 mem: [0xf2200000-0xf22fffff]
> [    0.291517] pci_bus 0000:1a: resource 2 pref mem [0x80a00000-0x80bfffff]
> [    0.291520] pci_bus 0000:26: resource 3 io:  [0x00-0xffff]
> [    0.291522] pci_bus 0000:26: resource 4 mem: [0x000000-0xffffffff]
> [    0.291562] NET: Registered protocol family 2
> [    0.291659] IP route cache hash table entries: 32768 (order: 5, 131072
> bytes)
> [    0.291969] TCP established hash table entries: 131072 (order: 8,
> 1048576 bytes)
> [    0.292425] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
> [    0.292677] TCP: Hash tables configured (established 131072 bind 65536)
> [    0.292679] TCP reno registered
> [    0.292764] NET: Registered protocol family 1
> [    0.292963] pci 0000:01:00.0: Boot video device
> [    0.292996] Simple Boot Flag at 0x36 set to 0x1
> [    0.293149] cpufreq-nforce2: No nForce2 chipset.
> [    0.293176] Scanning for low memory corruption every 60 seconds
> [    0.293306] audit: initializing netlink socket (disabled)
> [    0.293315] type=2000 audit(1290426910.291:1): initialized
> [    0.302485] highmem bounce pool size: 64 pages
> [    0.302490] HugeTLB registered 4 MB page size, pre-allocated 0 pages
> [    0.303912] VFS: Disk quotas dquot_6.5.2
> [    0.303965] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
> [    0.304493] fuse init (API version 7.13)
> [    0.304572] msgmni has been set to 1681
> [    0.304769] alg: No test for stdrng (krng)
> [    0.304816] Block layer SCSI generic (bsg) driver version 0.4 loaded
> (major 253)
> [    0.304819] io scheduler noop registered
> [    0.304821] io scheduler anticipatory registered
> [    0.304822] io scheduler deadline registered
> [    0.304858] io scheduler cfq registered (default)
> [    0.305009]   alloc irq_desc for 24 on node -1
> [    0.305011]   alloc kstat_irqs on node -1
> [    0.305019] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
> [    0.305026] pcieport 0000:00:01.0: setting latency timer to 64
> [    0.305155]   alloc irq_desc for 25 on node -1
> [    0.305156]   alloc kstat_irqs on node -1
> [    0.305165] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
> [    0.305176] pcieport 0000:00:1c.0: setting latency timer to 64
> [    0.305327]   alloc irq_desc for 26 on node -1
> [    0.305329]   alloc kstat_irqs on node -1
> [    0.305338] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
> [    0.305349] pcieport 0000:00:1c.1: setting latency timer to 64
> [    0.305501]   alloc irq_desc for 27 on node -1
> [    0.305502]   alloc kstat_irqs on node -1
> [    0.305511] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
> [    0.305522] pcieport 0000:00:1c.2: setting latency timer to 64
> [    0.305675]   alloc irq_desc for 28 on node -1
> [    0.305676]   alloc kstat_irqs on node -1
> [    0.305685] pcieport 0000:00:1c.3: irq 28 for MSI/MSI-X
> [    0.305696] pcieport 0000:00:1c.3: setting latency timer to 64
> [    0.305850]   alloc irq_desc for 29 on node -1
> [    0.305852]   alloc kstat_irqs on node -1
> [    0.305860] pcieport 0000:00:1c.4: irq 29 for MSI/MSI-X
> [    0.305871] pcieport 0000:00:1c.4: setting latency timer to 64
> [    0.305972] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
> [    0.306158] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
> [    0.307319] ACPI: AC Adapter [ACAD] (on-line)
> [    0.307390] input: Lid Switch as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
> [    0.307426] ACPI: Lid Switch [LID0]
> [    0.307472] input: Power Button as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
> [    0.307474] ACPI: Power Button [PWRB]
> [    0.307515] input: Power Button as
> /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
> [    0.307517] ACPI: Power Button [PWRF]
> [    0.308265] ACPI: SSDT 7fd1aca0 00223 (v01  PmRef  Cpu0Ist 00003000 INTL
> 20050624)
> [    0.308726] ACPI: SSDT 7fd19620 00549 (v01  PmRef  Cpu0Cst 00003001 INTL
> 20050624)
> [    0.310711] Monitor-Mwait will be used to enter C-1 state
> [    0.310737] Monitor-Mwait will be used to enter C-2 state
> [    0.310742] Marking TSC unstable due to TSC halts in idle
> [    0.310792] processor LNXCPU:00: registered as cooling_device0
> [    0.311198] ACPI: SSDT 7fd1aa20 001CF (v01  PmRef    ApIst 00003000 INTL
> 20050624)
> [    0.311552] ACPI: SSDT 7fd1af20 0008D (v01  PmRef    ApCst 00003000 INTL
> 20050624)
> [    0.312064] Switching to clocksource hpet
> [    0.315762] processor LNXCPU:01: registered as cooling_device1
> [    0.338249] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
> [    0.339506] brd: module loaded
> [    0.339932] loop: module loaded
> [    0.340033] input: Macintosh mouse button emulation as
> /devices/virtual/input/input3
> [    0.340419] Fixed MDIO Bus: probed
> [    0.340452] PPP generic driver version 2.4.2
> [    0.340482] tun: Universal TUN/TAP device driver, 1.6
> [    0.340484] tun: (C) 1999-2004 Max Krasnyansky <maxk at qualcomm.com>
> [    0.340553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
> [    0.340578] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 19 (level, low) ->
> IRQ 19
> [    0.340595] ehci_hcd 0000:00:1a.7: setting latency timer to 64
> [    0.340599] ehci_hcd 0000:00:1a.7: EHCI Host Controller
> [    0.340626] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus
> number 1
> [    0.340655] ehci_hcd 0000:00:1a.7: debug port 1
> [    0.344538] ehci_hcd 0000:00:1a.7: cache line size of 32 is not
> supported
> [    0.344556] ehci_hcd 0000:00:1a.7: irq 19, io mem 0xf2504800
> [    0.348490] isapnp: Scanning for PnP cards...
> [    0.365602] ACPI: Battery Slot [BAT1] (battery present)
> [    0.397579] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
> [    0.397708] usb usb1: configuration #1 chosen from 1 choice
> [    0.397735] hub 1-0:1.0: USB hub found
> [    0.397744] hub 1-0:1.0: 6 ports detected
> [    0.397818]   alloc irq_desc for 23 on node -1
> [    0.397820]   alloc kstat_irqs on node -1
> [    0.397826] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) ->
> IRQ 23
> [    0.397849] ehci_hcd 0000:00:1d.7: setting latency timer to 64
> [    0.397852] ehci_hcd 0000:00:1d.7: EHCI Host Controller
> [    0.397884] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus
> number 2
> [    0.397913] ehci_hcd 0000:00:1d.7: debug port 1
> [    0.401791] ehci_hcd 0000:00:1d.7: cache line size of 32 is not
> supported
> [    0.401942] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf2504c00
> [    0.446413] Freeing initrd memory: 12255k freed
> [    0.449415] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
> [    0.449700] usb usb2: configuration #1 chosen from 1 choice
> [    0.449741] hub 2-0:1.0: USB hub found
> [    0.449765] hub 2-0:1.0: 6 ports detected
> [    0.449870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
> [    0.449904] uhci_hcd: USB Universal Host Controller Interface driver
> [    0.450014] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) ->
> IRQ 16
> [    0.450028] uhci_hcd 0000:00:1a.0: setting latency timer to 64
> [    0.450033] uhci_hcd 0000:00:1a.0: UHCI Host Controller
> [    0.450090] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus
> number 3
> [    0.450144] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
> [    0.450248] usb usb3: configuration #1 chosen from 1 choice
> [    0.450272] hub 3-0:1.0: USB hub found
> [    0.450282] hub 3-0:1.0: 2 ports detected
> [    0.450341]   alloc irq_desc for 21 on node -1
> [    0.450343]   alloc kstat_irqs on node -1
> [    0.450352] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) ->
> IRQ 21
> [    0.450359] uhci_hcd 0000:00:1a.1: setting latency timer to 64
> [    0.450363] uhci_hcd 0000:00:1a.1: UHCI Host Controller
> [    0.450398] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus
> number 4
> [    0.450433] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
> [    0.450550] usb usb4: configuration #1 chosen from 1 choice
> [    0.450574] hub 4-0:1.0: USB hub found
> [    0.450584] hub 4-0:1.0: 2 ports detected
> [    0.450658] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 19 (level, low) ->
> IRQ 19
> [    0.450666] uhci_hcd 0000:00:1a.2: setting latency timer to 64
> [    0.450669] uhci_hcd 0000:00:1a.2: UHCI Host Controller
> [    0.450703] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus
> number 5
> [    0.450732] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00001840
> [    0.450823] usb usb5: configuration #1 chosen from 1 choice
> [    0.450847] hub 5-0:1.0: USB hub found
> [    0.450855] hub 5-0:1.0: 2 ports detected
> [    0.450919] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) ->
> IRQ 23
> [    0.450927] uhci_hcd 0000:00:1d.0: setting latency timer to 64
> [    0.450930] uhci_hcd 0000:00:1d.0: UHCI Host Controller
> [    0.450963] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus
> number 6
> [    0.450992] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001860
> [    0.451103] usb usb6: configuration #1 chosen from 1 choice
> [    0.451127] hub 6-0:1.0: USB hub found
> [    0.451137] hub 6-0:1.0: 2 ports detected
> [    0.451194] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) ->
> IRQ 19
> [    0.451202] uhci_hcd 0000:00:1d.1: setting latency timer to 64
> [    0.451206] uhci_hcd 0000:00:1d.1: UHCI Host Controller
> [    0.451254] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus
> number 7
> [    0.451281] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001880
> [    0.451381] usb usb7: configuration #1 chosen from 1 choice
> [    0.451413] hub 7-0:1.0: USB hub found
> [    0.451421] hub 7-0:1.0: 2 ports detected
> [    0.451469] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) ->
> IRQ 18
> [    0.451476] uhci_hcd 0000:00:1d.2: setting latency timer to 64
> [    0.451480] uhci_hcd 0000:00:1d.2: UHCI Host Controller
> [    0.451512] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus
> number 8
> [    0.451560] uhci_hcd 0000:00:1d.2: irq 18, io base 0x000018a0
> [    0.451656] usb usb8: configuration #1 chosen from 1 choice
> [    0.451687] hub 8-0:1.0: USB hub found
> [    0.451696] hub 8-0:1.0: 2 ports detected
> [    0.451830] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at
> 0x60,0x64 irq 1,12
> [    0.536523] serio: i8042 KBD port at 0x60,0x64 irq 1
> [    0.536532] serio: i8042 AUX port at 0x60,0x64 irq 12
> [    0.536699] mice: PS/2 mouse device common for all mice
> [    0.538918] rtc_cmos 00:05: RTC can wake from S4
> [    0.538962] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
> [    0.538992] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet
> irqs
> [    0.539101] device-mapper: uevent: version 1.0.3
> [    0.541078] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised:
> dm-devel at redhat.com
> [    0.541142] device-mapper: multipath: version 1.1.0 loaded
> [    0.541145] device-mapper: multipath round-robin: version 1.0.0 loaded
> [    0.541253] EISA: Probing bus 0 at eisa.0
> [    0.541260] Cannot allocate resource for EISA slot 1
> [    0.541263] Cannot allocate resource for EISA slot 2
> [    0.541265] Cannot allocate resource for EISA slot 3
> [    0.541267] Cannot allocate resource for EISA slot 4
> [    0.541269] Cannot allocate resource for EISA slot 5
> [    0.541271] Cannot allocate resource for EISA slot 6
> [    0.541273] Cannot allocate resource for EISA slot 7
> [    0.541279] EISA: Detected 0 cards.
> [    0.541390] cpuidle: using governor ladder
> [    0.541468] cpuidle: using governor menu
> [    0.541886] TCP cubic registered
> [    0.542021] NET: Registered protocol family 10
> [    0.542445] lo: Disabled Privacy Extensions
> [    0.542757] NET: Registered protocol family 17
> [    0.543318] Using IPI No-Shortcut mode
> [    0.543379] PM: Resume from disk failed.
> [    0.543391] registered taskstats version 1
> [    0.544188]   Magic number: 2:740:934
> [    0.544270] rtc_cmos 00:05: setting system clock to 2010-11-22 11:55:11
> UTC (1290426911)
> [    0.544273] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
> [    0.544274] EDD information not available.
> [    0.570173] input: AT Translated Set 2 keyboard as
> /devices/platform/i8042/serio0/input/input4
> [    0.760080] isapnp: No Plug & Play device found
> [    0.760094] Freeing unused kernel memory: 656k freed
> [    0.760484] Write protecting the kernel text: 4684k
> [    0.760531] Write protecting the kernel read-only data: 1840k
> [    0.776785] udev: starting version 151
> [    0.870905] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
> [    0.870928] r8169 0000:14:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ
> 19
> [    0.870971] r8169 0000:14:00.0: setting latency timer to 64
> [    0.871028]   alloc irq_desc for 30 on node -1
> [    0.871030]   alloc kstat_irqs on node -1
> [    0.871045] r8169 0000:14:00.0: irq 30 for MSI/MSI-X
> [    0.871643] eth0: RTL8168c/8111c at 0xf80a0000, 00:26:22:13:ac:34, XID
> 1c4000c0 IRQ 30
> [    0.874993] Linux agpgart interface v0.103
> [    0.880048] b43-pci-bridge 0000:0e:00.0: PCI INT A -> GSI 18 (level,
> low) -> IRQ 18
> [    0.880067] b43-pci-bridge 0000:0e:00.0: setting latency timer to 64
> [    0.883673] ahci 0000:00:1f.2: version 3.0
> [    0.883687] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ
> 19
> [    0.883727]   alloc irq_desc for 31 on node -1
> [    0.883729]   alloc kstat_irqs on node -1
> [    0.883741] ahci 0000:00:1f.2: irq 31 for MSI/MSI-X
> [    0.883795] ahci: SSS flag set, parallel bus scan disabled
> [    0.883834] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 4 ports 3 Gbps
> 0x33 impl SATA mode
> [    0.883837] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio
> slum part ccc ems
> [    0.883842] ahci 0000:00:1f.2: setting latency timer to 64
> [    0.893226] acpi device:01: registered as cooling_device2
> [    0.893419] input: Video Bus as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input5
> [    0.893464] ACPI: Video Device [PEGP] (multi-head: yes  rom: no  post:
> no)
> [    0.905170] scsi0 : ahci
> [    0.905342] scsi1 : ahci
> [    0.905426] scsi2 : ahci
> [    0.905509] scsi3 : ahci
> [    0.905594] scsi4 : ahci
> [    0.905677] scsi5 : ahci
> [    0.905721] ata1: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504100 irq 31
> [    0.905725] ata2: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504180 irq 31
> [    0.905727] ata3: DUMMY
> [    0.905728] ata4: DUMMY
> [    0.905731] ata5: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504300 irq 31
> [    0.905735] ata6: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504380 irq 31
> [    0.940177] ssb: Sonics Silicon Backplane found on PCI device
> 0000:0e:00.0
> [    0.952051] usb 2-2: new high speed USB device using ehci_hcd and
> address 3
> [    1.085011] usb 2-2: configuration #1 chosen from 1 choice
> [    1.196073] usb 2-3: new high speed USB device using ehci_hcd and
> address 4
> [    1.224074] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
> [    1.231399] ata1.00: ATA-8: SAMSUNG HM320JI, 2SS00_03, max UDMA7
> [    1.231404] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth
> 31/32), AA
> [    1.238891] ata1.00: configured for UDMA/133
> [    1.252217] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG HM320JI
> 2SS0 PQ: 0 ANSI: 5
> [    1.252355] sd 0:0:0:0: Attached scsi generic sg0 type 0
> [    1.252442] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320
> GB/298 GiB)
> [    1.252482] sd 0:0:0:0: [sda] Write Protect is off
> [    1.252484] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
> [    1.252505] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled,
> doesn't support DPO or FUA
> [    1.252622]  sda: sda1 sda2 sda3 sda4
> [    1.293048] sd 0:0:0:0: [sda] Attached SCSI disk
> [    1.372618] usb 2-3: configuration #1 chosen from 1 choice
> [    1.612079] usb 3-1: new full speed USB device using uhci_hcd and
> address 2
> [    1.784325] usb 3-1: configuration #1 chosen from 1 choice
> [    1.976111] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
> [    1.989068] ata2.00: ATAPI: Optiarc DVD RW AD-7560S, SX03, max UDMA/100
> [    2.002507] ata2.00: configured for UDMA/100
> [    2.017130] scsi 1:0:0:0: CD-ROM            Optiarc  DVD RW AD-7560S
> SX03 PQ: 0 ANSI: 5
> [    2.022461] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2
> cdda tray
> [    2.022466] Uniform CD-ROM driver Revision: 3.20
> [    2.022622] sr 1:0:0:0: Attached scsi CD-ROM sr0
> [    2.022679] sr 1:0:0:0: Attached scsi generic sg1 type 5
> [    2.024097] usb 6-1: new low speed USB device using uhci_hcd and address
> 2
> [    2.199213] usb 6-1: configuration #1 chosen from 1 choice
> [    2.340102] ata5: SATA link down (SStatus 0 SControl 300)
> [    2.676123] ata6: SATA link down (SStatus 0 SControl 300)
> [    2.697011] usbcore: registered new interface driver hiddev
> [    2.711448] input: Darfon USB Optical Mous as
> /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input6
> [    2.711539] generic-usb 0003:0D62:A100.0001: input,hidraw0: USB HID
> v1.10 Mouse [Darfon USB Optical Mous] on usb-0000:00:1d.0-1/input0
> [    2.711563] usbcore: registered new interface driver usbhid
> [    2.711566] usbhid: v2.6:USB HID core driver
> [    3.177677] uvesafb: NVIDIA Corporation, G98 Board - 05686e90, Chip
> Rev   , OEM: NVIDIA, VBE v3.0
> [    3.214449] uvesafb: protected mode interface info at c000:c910
> [    3.214452] uvesafb: pmi: set display start = c00cc973, set palette =
> c00cc9ce
> [    3.214454] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7
> 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
> [    3.281553] uvesafb: VBIOS/hardware doesn't support DDC transfers
> [    3.281555] uvesafb: no monitor limits have been set, default refresh
> rate will be used
> [    3.281750] uvesafb: scrolling: ywrap using protected mode interface,
> yres_virtual=1600
> [    3.282729] uvesafb: framebuffer at 0xcd000000, mapped to 0xf8200000,
> using 8000k, total 14336k
> [    3.282732] fb0: VESA VGA frame buffer device
> [    3.729853] Console: switching to colour frame buffer device 160x50
> [    4.053631] EXT4-fs (sda1): mounted filesystem with ordered data mode
> [   14.872727] udev: starting version 151
> [   14.973411] vga16fb: initializing
> [   14.973415] vga16fb: mapped to 0xc00a0000
> [   14.973419] vga16fb: not registering due to another framebuffer present
> [   14.980197] Adding 4882424k swap on /dev/sda2.  Priority:-1 extents:1
> across:4882424k
> [   15.043608] lp: driver loaded but no devices found
> [   15.136206] nvidia: module license 'NVIDIA' taints kernel.
> [   15.136210] Disabling lock debugging due to kernel taint
> [   15.151011] type=1505 audit(1290426926.104:2):  operation="profile_load"
> pid=700 name="/sbin/dhclient3"
> [   15.151639] type=1505 audit(1290426926.104:3):  operation="profile_load"
> pid=700 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
> [   15.151972] type=1505 audit(1290426926.104:4):  operation="profile_load"
> pid=700 name="/usr/lib/connman/scripts/dhclient-script"
> [   15.446033] sdhci: Secure Digital Host Controller Interface driver
> [   15.446035] sdhci: Copyright(c) Pierre Ossman
> [   15.447249] sdhci-pci 0000:1a:00.0: SDHCI controller found [197b:2382]
> (rev 0)
> [   15.447271] sdhci-pci 0000:1a:00.0: PCI INT A -> GSI 16 (level, low) ->
> IRQ 16
> [   15.447313] sdhci-pci 0000:1a:00.0: setting latency timer to 64
> [   15.447346] Registered led device: mmc0::
> [   15.447379] mmc0: SDHCI controller on PCI [0000:1a:00.0] using ADMA
> [   15.448161] sdhci-pci 0000:1a:00.2: SDHCI controller found [197b:2381]
> (rev 0)
> [   15.448181] sdhci-pci 0000:1a:00.2: PCI INT A -> GSI 16 (level, low) ->
> IRQ 16
> [   15.448188] sdhci-pci 0000:1a:00.2: Refusing to bind to secondary
> interface.
> [   15.448195] sdhci-pci 0000:1a:00.2: PCI INT A disabled
> [   15.448970] Bluetooth: Core ver 2.15
> [   15.449012] NET: Registered protocol family 31
> [   15.449014] Bluetooth: HCI device and connection manager initialized
> [   15.449016] Bluetooth: HCI socket layer initialized
> [   15.450974] Bluetooth: Generic Bluetooth USB driver ver 0.6
> [   15.451644] usbcore: registered new interface driver btusb
> [   15.461463] tpm_tis 00:09: 1.2 TPM (device-id 0xB, rev-id 16)
> [   15.482654] cfg80211: Calling CRDA to update world regulatory domain
> [   15.511604] b43-phy0: Broadcom 4311 WLAN found (core revision 10)
> [   15.527812] jmb38x_ms 0000:1a:00.3: PCI INT A -> GSI 16 (level, low) ->
> IRQ 16
> [   15.527821] jmb38x_ms 0000:1a:00.3: setting latency timer to 64
> [   15.620606]   alloc irq_desc for 22 on node -1
> [   15.620609]   alloc kstat_irqs on node -1
> [   15.620616] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) ->
> IRQ 22
> [   15.620656] HDA Intel 0000:00:1b.0: setting latency timer to 64
> [   15.624732] phy0: Selected rate control algorithm 'minstrel'
> [   15.625402] Registered led device: b43-phy0::tx
> [   15.625418] Registered led device: b43-phy0::rx
> [   15.625433] Registered led device: b43-phy0::radio
> [   15.625490] Broadcom 43xx driver loaded [ Features: PL, Firmware-ID:
> FW13 ]
> [   15.640927] Linux video capture interface: v2.00
> [   15.646360] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (064e:a115)
> [   15.664573] input: USB 2.0 Camera as
> /devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3:1.0/input/input7
> [   15.664622] usbcore: registered new interface driver uvcvideo
> [   15.664624] USB Video Class driver (v0.1.0)
> [   15.681829] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ
> 16
> [   15.681845] nvidia 0000:01:00.0: setting latency timer to 64
> [   15.682019] NVRM: loading NVIDIA UNIX x86 Kernel Module  173.14.22  Sun
> Nov  8 20:26:31 PST 2009
> [   15.765402] hda_codec: ALC268: BIOS auto-probing.
> [   15.765851] input: HDA Digital PCBeep as
> /devices/pci0000:00/0000:00:1b.0/input/input8
> [   15.902934] cfg80211: World regulatory domain updated:
> [   15.902937]     (start_freq - end_freq @ bandwidth), (max_antenna_gain,
> max_eirp)
> [   15.902940]     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000
> mBm)
> [   15.902942]     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000
> mBm)
> [   15.902945]     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000
> mBm)
> [   15.902947]     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000
> mBm)
> [   15.902949]     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000
> mBm)
> [   16.592634] EXT4-fs (sda3): mounted filesystem with ordered data mode
> [   16.672865] Synaptics Touchpad, model: 1, fw: 7.0, id: 0x1c0b1, caps:
> 0xd04711/0xa00000
> [   16.784919] input: SynPS/2 Synaptics TouchPad as
> /devices/platform/i8042/serio1/input/input9
> [   17.993421] EXT4-fs (sda4): mounted filesystem with ordered data mode
> [   18.181329] type=1505 audit(1290426929.135:5):  operation="profile_load"
> pid=996 name="/usr/share/gdm/guest-session/Xsession"
> [   18.189220] type=1505 audit(1290426929.143:6):
> operation="profile_replace" pid=997 name="/sbin/dhclient3"
> [   18.189845] type=1505 audit(1290426929.143:7):
> [   18.190181] type=1505 audit(1290426929.143:8):
> [   18.193576] type=1505 audit(1290426929.147:9):  operation="profile_load"
> pid=999 name="/usr/bin/evince"
> [   18.201745] type=1505 audit(1290426929.155:10):
> operation="profile_load" pid=999 name="/usr/bin/evince-previewer"
> [   18.206655] type=1505 audit(1290426929.159:11):
> operation="profile_load" pid=999 name="/usr/bin/evince-thumbnailer"
> [   18.236142] b43 ssb0:0: firmware: requesting b43/ucode5.fw
> [   18.260896] b43 ssb0:0: firmware: requesting b43/pcm5.fw
> [   18.263044] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
> [   18.267744] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
> [   18.388066] b43-phy0: Loading firmware version 410.2160 (2007-05-26
> 15:32:10)
> [   18.476468] ADDRCONF(NETDEV_UP): wlan0: link is not ready
> [   18.488531] r8169: eth0: link down
> [   18.488703] ADDRCONF(NETDEV_UP): eth0: link is not ready
> [   18.584189] Bluetooth: L2CAP ver 2.14
> [   18.584194] Bluetooth: L2CAP socket layer initialized
> [   18.594706] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
> [   18.594710] Bluetooth: BNEP filters: protocol multicast
> [   18.604915] Bridge firewalling registered
> [   18.618044] Bluetooth: SCO (Voice Link) ver 0.6
> [   18.618047] Bluetooth: SCO socket layer initialized
> [   18.695144] ppdev: user-space parallel port driver
> [   18.728069] Bluetooth: RFCOMM TTY layer initialized
> [   18.728073] Bluetooth: RFCOMM socket layer initialized
> [   18.728075] Bluetooth: RFCOMM ver 1.11
> [   24.977053] CE: hpet increasing min_delta_ns to 15000 nsec
> [   31.041054] CE: hpet increasing min_delta_ns to 22500 nsec
> [   87.589113] wlan0: deauthenticating from 00:1a:3f:56:4c:04 by local
> choice (reason=3)
> [   87.589312] wlan0: direct probe to AP 00:1a:3f:56:4c:04 (try 1)
> [   87.592234] wlan0: direct probe responded
> [   87.592238] wlan0: authenticate with AP 00:1a:3f:56:4c:04 (try 1)
> [   87.594011] wlan0: authenticated
> [   87.594030] wlan0: associate with AP 00:1a:3f:56:4c:04 (try 1)
> [   87.596144] wlan0: RX AssocResp from 00:1a:3f:56:4c:04 (capab=0x431
> status=0 aid=2)
> [   87.596147] wlan0: associated
> [   87.596870] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
> [   98.180138] wlan0: no IPv6 routers present
> [ 1159.132175] usb 1-6: new high speed USB device using ehci_hcd and
> address 3
> [ 1159.267639] usb 1-6: configuration #1 chosen from 1 choice
> [ 1159.335800] Initializing USB Mass Storage driver...
> [ 1159.336227] scsi6 : SCSI emulation for USB Mass Storage devices
> [ 1159.336374] usbcore: registered new interface driver usb-storage
> [ 1159.336379] USB Mass Storage support registered.
> [ 1159.339824] usb-storage: device found at 3
> [ 1159.339829] usb-storage: waiting for device to settle before scanning
> [ 1164.336482] usb-storage: device scan complete
> [ 1164.362239] scsi 6:0:0:0: Direct-Access     HP       v100w
> PMAP PQ: 0 ANSI: 0 CCS
> [ 1164.363057] sd 6:0:0:0: Attached scsi generic sg2 type 0
> [ 1168.898439] sd 6:0:0:0: [sdb] 15667200 512-byte logical blocks: (8.02
> GB/7.47 GiB)
> [ 1168.899183] sd 6:0:0:0: [sdb] Write Protect is off
> [ 1168.899189] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
> [ 1168.899193] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.903577] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.903584]  sdb: sdb1
> [ 1168.925453] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.925461] sd 6:0:0:0: [sdb] Attached SCSI removable disk
> [ 2785.036180] usb 8-2: new full speed USB device using uhci_hcd and
> address 2
> [ 2785.191356] usb 8-2: configuration #1 chosen from 1 choice
> [ 2792.152240] hub 8-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
> [ 2792.152249] usb 8-2: USB disconnect, address 2
> [ 2792.392068] usb 8-2: new full speed USB device using uhci_hcd and
> address 3
> [ 2792.456153] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2792.834994] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2821.740079] hub 8-0:1.0: unable to enumerate USB device on port 2
> arthur at rgsg:~$
> There is a way to confirm what configuration files shoud be modified? If
> yes, point me files please?
> The GPS now not more appears with "connected" status, just "not connected".
> tks for your patience.
> Arthur
>> Otherwise, I do not have any idea at the moment - your Garmin should be
>> available on /dev/ttyUSB0 - does this node exist? Otherwise maybe consult on
>> the console "man MAKEDEV" ... but here we are deep down in your system, this
>> should only be "Plan B" (BIG WARNING SIGN)
>> Has it worked before?
>> Albin
>> | Albin Blaschka, Mag.rer.nat.
>> | Etrichstrasse 26, A-5020 Salzburg
>> | * www.albinblaschka.info * www.thinkanimal.info *
>> | - It's hard to live in the mountains, hard but not hopeless!
> Arthur Nanni
> Ubuntu 10.11!
> É tempo de mudança. Seu computador mais rápido, divertido e fácil de usar.
> Clique para conhecer... <http://www.ubuntu-br.org>
Arthur Nanni
Ubuntu 10.11!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101122/612fe121/attachment.html>
