[Qgis-user] GPS tracking tool
John C. Tull jctull at gmail.com
Wed Nov 24 08:25:18 PST 2010
I believe any device with a connectivity option (usb or serial) and nmea output will do. You will need to check the specs, but if you can get hold of a used Garmin device with an output option and a cable, you will be in good shape.
There are also units without displays if you won't be needing that. For example, http://goo.gl/jWvme , although I have not tried one of these myself.
Good luck,
John
On Nov 24, 2010, at 8:04 AM, Donnet , Sebastien wrote:
> Hi guys,
> do you know what type (brand, model) of hand-held GPS devices (reasonably price if possible) that are known to work with the Live GPS Tracking tool?
> ...looking to buy one. :)
> cheers,
> S.
> The information contained in this e-mail is intended only for the individual or entity to whom it is addressed.
> Its contents (including any attachments) may contain confidential and/or privileged information.
> If you are not an intended recipient you must not use, disclose, disseminate, copy or print its contents.
> If you receive this e-mail in error, please notify the sender by reply e-mail and delete and destroy the message.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101124/799eca07/attachment.html>
