[Qgis-user] Qgis crash on start up under OS X
Anne Ghisla a.ghisla at gmail.com
Tue Nov 30 00:37:04 PST 2010
On Mon, 2010-11-29 at 18:31 -0600, William Kyngesburye wrote:
> See if you have a crashlog for QGIS.  Check Console.app and look in ~/Library/Logs/CrashReporter.
> On Nov 29, 2010, at 4:20 PM, Kurt Springs wrote:
> > Hi
> > I just installed Qgis 1.6 on my mac and it is crashing on start up.  Qgis 1.5 was working fine.  I have been getting this message on start up:
> > Unable to load the plugin: Unable to load required package rpy2.
> > Please ensure that both R, and the corresponding version of Rpy2 are correctly installed.
Hi Kurt, all,
this error message is likely raised by HomeRange_plugin.
You can start qgis with all plugins disabled
qgis --noplugins
(see qgis --help for more options)
and then, in the plugin manager, disable HomeRange plugin.
Restart QGIS normally, it should not crash anymore.
To re-enable the plugin you need to install/upgrade rpy2 according to
your R version. Another plugin that needs R is manageR, usually if one
works, the other works too.
let us know!
Anne
> > But I was getting this with 1.5 as well.
> > I tried it on my laptop where I don't get the message, and it is still quitting on startup.
> > Any idea what's wrong, and how to correct it?
> > Thanks
> > Kurt
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101130/be111d3b/attachment.sig>
