[Qgis-user] Qgis crash on start up under OS X
Anne Ghisla
a.ghisla at gmail.com
Tue Nov 30 00:52:06 PST 2010
On Tue, 2010-11-30 at 09:37 +0100, Anne Ghisla wrote:
> On Mon, 2010-11-29 at 18:31 -0600, William Kyngesburye wrote:
> > See if you have a crashlog for QGIS. Check Console.app and look in ~/Library/Logs/CrashReporter.
> > On Nov 29, 2010, at 4:20 PM, Kurt Springs wrote:
> > > Hi
> > > I just installed Qgis 1.6 on my mac and it is crashing on start up. Qgis 1.5 was working fine. I have been getting this message on start up:
> > > Unable to load the plugin: Unable to load required package rpy2.
> > > Please ensure that both R, and the corresponding version of Rpy2 are correctly installed.
> Hi Kurt, all,
> this error message is likely raised by HomeRange_plugin.
> You can start qgis with all plugins disabled
> qgis --noplugins
> (see qgis --help for more options)
> and then, in the plugin manager, disable HomeRange plugin.
correction: it is already disabled.
Try to re-enable it and see if restarting qgis reproduces the crash.
If so, either uninstall the plugin, either ...
> ... install/upgrade rpy2 according to
> your R version. Another plugin that needs R is manageR, usually if one
> works, the other works too.
cheers
Anne
> > > But I was getting this with 1.5 as well.
> > > I tried it on my laptop where I don't get the message, and it is still quitting on startup.
> > > Any idea what's wrong, and how to correct it?
> > > Thanks
> > > Kurt
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> > Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
> > First Pogril: I don't know either. Wretched, isn't it?
> > -HitchHiker's Guide to the Galaxy
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101130/b5555bb3/attachment.sig>
