[Qgis-user] FILE .dwg and .cad
Noli Sicad nsicad at gmail.com
Fri Sep 3 19:36:09 PDT 2010
Beter news, there is even GRASS plugin / addon using LibreDWG
It imports dwg files as vector data. The plugin is in
grass-addons/vector/v.in.redwg
http://lists.gnu.org/archive/html/libredwg/2010-08/msg00007.html
I wonder if you can get this plugin and put it in the grass plugins for QGIS.
How does the QGIS Grass plugin works with GRASS plugin / addon?
Noli
On 9/4/10, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Good find, looks like that one has closed development and refers people
> now to http://www.gnu.org/software/libredwg/
> I suggest checking the GDAL tickets to see if there is something along
> these lines and if not put in an enhancement ticket to see if someone
> can get gdal to use this library.
> Thanks,
> Alex
> On 09/03/2010 06:08 PM, Noli Sicad wrote:
>> Alex, thanks for the correction.
>> This is a library to allow reading data from a DWG file.
>> http://libdwg.sourceforge.net/en/
>> Noli
>>> Careful reading of that page indicates the drive is "write-only" for
>>> DWG. There is no read for DWG. It also is not supplied by default, must
>>> be added like ECW and MrSid.
>>> DXF on the other hand is read/write under the default GDAL.
>>> At least according to what I see on those pages.
>>> Thanks,
>>> Alex
>>> On 09/03/2010 03:06 PM, Noli Sicad wrote:
>>>> I think read/write DWG and DXF formats is support in GDAL now, if I am
>>>> not mistaken
>>>> http://trac.osgeo.org/gdal/wiki/DxfDwg
>>>> http://mateusz.loskot.net/2006/01/03/writing-dwgdxf-files-with-ogr/
>>>> What it needs is QGIS plugin.
>>>> BTW, there is Dxf2shp (Dxf to shapefile) plugin available.
>>>> I hope this is clear enough to be undestood,  not to mention QGIS uses
>>>> GDAL.
>>>> Noli
>>>> On 9/4/10, Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
>>>>> Hi,
>>>>>> how to import to the data view from file extension dwg and extension
>>>>>> cad
>>>>> you cannot open the .dwg files, because the format is really a closed
>>>>> one.
>>>>> Surprisingly there is another popular open source gis software that can
>>>>> open this kind of files, maybe people that uses it can tell here how
>>>>> this is possible.
>>>>> Don't know about .cad ones.
>>>>> cheers
>>>>> -- Giovanni --
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
