[Qgis-user] RE: Shapefile structure viewer and editor plugin
Alister Hood alister.hood at synergine.com
Mon Sep 6 00:10:10 PDT 2010
Yes, this file works with 0.0.5 in nightly QGIS (It still crashes 1.5).
Be warned - unless you choose to load a small selection the plugin takes
a long time to load this file, due to the large amount of information in
it :)
Alister
________________________________________________
Alister Hood
Consultant
Synergine Group Limited
Unit 105, 23 Edwin Street, Mt Eden
PO Box 8000 Symonds Street
Auckland 1150, New Zealand
Ph: +64 9 631 1777
DDI: +64 9 632 0223
Fax: +64 9 631 0070
Email: alister.hood at synergine.com
-----Original Message-----
From: Benoit de Cabissole [mailto:benoit at exigesa.com]
Sent: Monday, 6 September 2010 6:42 p.m.
To: Alister Hood; qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] RE: Shapefile structure viewer and editor
plugin
Hi Alister,
Interesting. It seems that your shapefile has an empty multipolyline in
it
or it contains a line with no point?
If you don't mind, yes, send me that shapefile.
A new version 0.0.5 has been put in the contributed repo that should
handle
this case.
I'm developing with the nightly builds (1.6 Trunk in OSGeo4W on XP) so
I'm
not so surprised it crashes V1.5 on error.
Thanks for reporting the error.
Benoit
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org]On Behalf Of Alister Hood
> Sent: Monday, 06 September 2010 01:34
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] RE: Shapefile structure viewer and editor plugin
> Hi Benoit,
> I have found a shape file that causes QGIS 1.5 to crash when I try to
> start your plugin.  In the nightly builds it doesn't crash QGIS, but
the
> plugin fails to start, with the error below.  I am on Windows XP.  I
can
> send you the shape file if you are interested.
> Regards,
> Alister
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File "C:/Documents and
> Settings/alister.hood/.qgis/python/plugins\bccSHPV\bccSHPV.py", line
> 193, in cdlgInit
>     dialog = cdlgSHPV(self.iface, theLayer, iType, bSelected)
> Settings/alister.hood/.qgis/python/plugins\bccSHPV\cdlgSHPV.py", line
> 111, in __init__
>     self.DoLine()
> 1088, in DoLine
>     x    = xm[0]
> IndexError: list index out of range
> Python version:
> 2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
> QGIS version:
> 1.6.0-Trunk Trunk, 14191
> Python path: ['C:\\Documents and
> Settings\\alister.hood\\.qgis\\python\\plugins\\elevation',
> 'C:/OSGeo4W/apps/qgis-dev/./python', 'C:/Documents and
> Settings/alister.hood/.qgis/python', 'C:/Documents and
> Settings/alister.hood/.qgis/python/plugins',
> 'C:/OSGeo4W/apps/qgis-dev/./python/plugins',
> 'C:\\OSGeo4W\\apps\\gdal-17\\pymod', 'H:\\',
> 'C:\\OSGeo4W\\bin\\python25.zip', 'C:\\OSGeo4W\\apps\\Python25\\DLLs',
> 'C:\\OSGeo4W\\apps\\Python25\\lib',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\plat-win',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\lib-tk',
> 'C:\\OSGeo4W\\apps\\qgis-dev\\bin', 'C:\\OSGeo4W\\apps\\Python25',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\win32',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\win32\\lib',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\Pythonwin',
> 'C:\\OSGeo4W\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode',
> 'C:\\Documents and
> Settings\\alister.hood\\.qgis\\python\\plugins\\cadtools\\tools',
> '~/.qgis/python',
> 'C:\\OSGeo4W\\apps\\qgis-dev\\python\\plugins\\fTools\\tools',
> '/usr/share/qgis/python/', '/usr/share/qgis/python/',
> '/usr/share/qgis/python']
> Qgis-user mailing list
