[Qgis-user] RE: Shapefile structure viewer and editor plugin
Noli Sicad
nsicad at gmail.com
Fri Sep 10 18:36:40 PDT 2010
Hi Benoit,
I am searching for a plugin that calculates the area and perimeter of
polygons of shapefiles and other vector layers e.g. spatialite
I think there is none at the moment, if I am not mistaken.
However, you can get the area and perimeter of the layer using fTools.
Vector-> Geometry tools -> Export / Add Geometry Columns
The resulting exported shapefile has Area and Perimeter columns in the
attribute table.
Probably it would be good to add this feature - Area and perimeter
calculation in your Shapefile structure viewer and editor plugin.
Thanks.
Noli
