[Qgis-user] RE: Shapefile structure viewer and editor plugin
Benoit EXIGE benoit at exigesa.com
Fri Sep 10 23:33:44 PDT 2010
Hi Noli,
Thanks for your suggestion. I've thought about it but didn't implement
it because fTools does it already. So why not viewing the shapefile
produced by fTools? Easy and lazy reasoning from my side...
Another advantage of first using fTools to produce this info is that
the file viewed/edited in the plugin is second generation so that if
it gets damaged by the plugin you can safely return to the original
file.
BTW please do not save or save as multipolylines shapefiles, the
structure would get badly damaged! I'm working on a fix at the moment.
Cheers,
Benoit
Sent from my iPod
On 11 Sep 2010, at 3:36, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Benoit,
> I am searching for a plugin that calculates the area and perimeter of
> polygons of shapefiles and other vector layers e.g. spatialite
> I think there is none at the moment, if I am not mistaken.
> However, you can get the area and perimeter of the layer using fTools.
> Vector-> Geometry tools -> Export / Add Geometry Columns
> The resulting exported shapefile has Area and Perimeter columns in the
> attribute table.
> Probably it would be good to add this feature - Area and perimeter
> calculation in your Shapefile structure viewer and editor plugin.
> Thanks.
> Noli
