[Qgis-user] FILE .dwg and .cad
Paolo Cavallini cavallini at faunalia.it
Tue Sep 7 00:10:15 PDT 2010
Il 06/09/2010 16:52, Duarte Carreira ha scritto:
> Andreas,
> But QGIS reads DGN files directly, I assume through OGR, and with all geometry types in a single layer. We can then filter each geometry type and save to shapefile. Can't QGIS work the same way with DWG theoretically? If/when OGR provides a dwg driver that is similar to the dgn driver, then I would assume this would work.
Hi Duarte.
Could you please share a DGN file with these characteristics, for further tests? You
could attach it to an appropriate ticket for future reference.
Thanks.
Paolo Cavallini: http://www.faunalia.it/pc
