[Qgis-user] qgis segfault when resizing main windowRe:
Pierre Chevalier Géologue
pierrechevaliergeol at free.fr
Sat Sep 11 02:11:32 PDT 2010
Hello,
I did not come across the "segfault while resizing qgis problem" since I
disabled the "autosave" extension, a few weeks (months?) ago.
I'm not sure whether this extension was exactly the cause, but it worked.
I use qgis 1.5.0 on a debian lenny from , and trunk (r14209M) on a debian
squeeze, both work fine.
A+
Pierre
(under-soil scientist ;))
PS: I can't remember whether I mentioned on the list that my problem had
disappeared. Sorry for the noise, if any.
blavet claviota:
> Dear
> I'm really interested in using qgis and use it since 2 years without
> problems.
> I also recommend this software to the students that we have and they
> are happy with it,
> (they work often with MS Win, but also with GNU Linux or Mac OsX)
> I found Qgis very interesting because it is user friendly, and it
> can be used
> on many platforms and also is able to work with shapefiles.
> Since one year I'm also using GNU/Linux since and wish to go on
> with this system.
> I was happy with qgis 1.3 and GNU/Linux
> Unfortunately, like some other users (see below) i experiment a
> segfault while trying to resize qgis 1.4
> main windows when some layers are loaded
> for me this occurs since several weeks with vector layers, qgis 1.4
> and the following distributions :
> - up to date debian testing (squeeze) amd64
> - up to date ubuntu 10.04 on i386
> I still use Qgis and plan to use it in the future , then i hope that
> there is some solution for this issue.
> Kind regards
> D. Blavet
> Soil scientist
> Re: [Qgis-user] qgis segfault when resizing main window
> John C. Tull
> Fri, 07 May 2010 08:51:29 -0700
> Hi Pierre,
> This is an issue I have brought up in the past on irc, but apparently
> there is
> not a bug filed (I thought there was, but could not find it). I had
> believed
> this to be an issue exclusive to the Mac platform, but apparently not.
> I am not
> sure if this is qgis or qt, but it is a big problem. Please file a bug
> if you
> don't mind.
> http://trac.osgeo.org/qgis/newticket
> You might also see this bug, which I still experience.
> http://trac.osgeo.org/qgis/ticket/2483
> From what I can tell, a single raster image on the canvas causes bug
> 2483 to
> occur. The crash that you describe occurs when a single vector file is
> loaded.
> So, different issues depending on the source data type.
> Regards,
> John
> On May 6, 2010, at 7:48 AM, Pierre Chevalier Géologue wrote:
> > Hello,
> > I get regularly a segmentation fault when I resize the main qgis
> window, only
> > if there is some data displayed. My platform is a debian testing
> machine,
> > up-to-date, with the debian.gfoss.it repository.
> > Usually, when I work, I always have several windows of any kind
> open, and I
> > keep on moving and resizing windows, without any trouble, including
> qgis,
> > that I use very often.
> > Last week or so, I began to get some problems, qgis was crashing in
> some
> > cases. It got quite annoying. I was running qgis 1.4, then I
> switched to
> > 1.5. I secretly hoped that someone could have solved this bug, so I
> got the
> > source and compiled qgis from source (I had some trouble with sip
> and python,
> > but it got solved).
> > Now I am running version 1.5 revision 13427.
> > There is no special message from the xterm where I launched qgis from:
> > pie... at duran:~$ /usr/local/bin/qgis
> > Python support ENABLED :-)
> > /usr/lib/python2.5/site-packages/osgeo/gdal.py:99:
> > DeprecationWarning: gdal.py was placed in a namespace, it is now
> > available as osgeo.gdal
> > DeprecationWarning)
> > Loaded : Plugin Installer (package: plugin_installer)
> > Loaded : SelectPlus Menu (package: selectplus)
> > Loaded : Images to Shapefile (package: imagestoshape)
> > Loaded : PostGIS manager (package: postgis_manager)
> > Loaded : Azimuth and Distance Plugin (package: qgsAzimuth)
> > Loaded : autosave (package: autosave)
> > Loaded : ShowHideImg (package: imgshowhide)
> > Loaded : Elevation (package: elevation)
> > Erreur de segmentation
> > The last messages means translation fault, in French.
> > If there is no data loaded, nothing happens, I am able to resize the
> windows
> > in any direction. Whenever I load some data, then it crashes as
> soon as I
> > resize the window.
> > Has anyone got an idea? Known bug?
> > Thanks in advance.
> > A+
> > Pierre
> ____________________________________________________________________________
> > Pierre Chevalier Géologue EI
> > Mesté Duran
> > 32100 Condom
> > Tél+fax : 09 75 27 45 62
> > 05 62 28 06 83
> > 06 37 80 33 64
> > Émail : pierrechevaliergeolCHEZfree.fr
> > icq# : 10432285
> > skype : pierre.chevalier1967
> > http://pierremariechevalier.free.fr/pierre_chevalier_geologue
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> [Qgis-user] qgis segfault when resizing main window Pierre Chevalier
> Géologue
> Re: [Qgis-user] qgis segfault when resizing main window John C. Tull
> windowB052D20B-16B0-46BC-9982-7A4509D22E35 at gmail.com Reply via email to
> John C. Tull
Mesté Duran
32100 Condom
05 62 28 06 83
06 37 80 33 64
icq# : 10432285
