[Qgis-user] Projection of Shapefile export
Micha Silver micha at arava.co.il
Mon Sep 20 00:01:24 PDT 2010
Brett Adams wrote:
>  Micha,
> Sorry but I can't get your suggestions to work. I tried this a couple
> of times but it fails every time.
> Settings->Options-CRS window is already set to "Prompt for CRS"
And when you next import the csv, does it indeed prompt for the CRS?
> Tried changing the global to AGD84 / AMG zone 51, when I reopen the
> window its set to AGD66 so this setting is not holding.
Weird. There's no permissions problems?
> When I reimport the the CSV file the default is still WGS84, despite
> the global been set to AGD84 (or is it AGD66, I can't be sure). Again
> I select AGD84.
> Layer > Properties > Specify CRS comes up as AGD66. Changed it to AGD84
> When I export the layer, I'm again asked to specify the projection, AGD84
> Exported *.prj file still has a datum of "D_unknown". Upon import of
> the shape file, my version of QGIS will now default this to AGD84
> however as the *.prj file is wrong it no good to anyone else.
Here's the prj that I'm getting:
PROJCS["UTM Zone 51, Southern Hemisphere",GEOGCS["Australian Natl & S.
Amer. 1969",DATUM["D_unknown",SPHEROID["aust_SA",6
378160,298.25]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["l
atitude_of_origin",0],PARAMETER["central_meridian",123],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000
],PARAMETER["false_northing",10000000],UNIT["Meter",1]]
What should it be? Even tho' it's called "D_unknown" all the parameters
seem to be there.
> The only real work around I have so far is to delete the *.prj file
> and then specify the projection on import.
> On 19/09/2010 2:35 PM, Micha Silver wrote:
>> Micha Silver wrote:
>>> Brett Adams wrote:
>>>> Micha,
>>>> I've attached csv data for importing and all shape files exported.
>>>> I've added comments into your prior email also.
>>> Hi Brett:
>>> I do indeed see a problem exporting to the AGD84 CRS. I get a
>>> "Latitude or Longitude exceeds limits" error. This happens when the
>>> global CRS is set to WGS84 (which is the default in QGIS). Attached
>>> is a screen shot of the error.
>>> Here's how to overcome the problem: Change your Global CRS to AGD84
>>> zone 51 (BTW, that's EPSG code 20351). This is done in the
>>> Settings->Options->CRS dialog window. Now re-import the csv file and
>>> then save as shapefile and you should be able to select the AGD84
>>> CRS and have it saved correctly.
>>> Alternatively, if you don't want to change the global CRS setting,
>>> you can select (in the same Settings->Options-CRS window) to "Prompt
>>> for CRS".  Then when you import the csv you'll be asked to specify
>>> the correct CRS for the points, You again select AGD84 and all
>>> should be well.
>>> Cheers,
>>> Micha
>> And just to complete the picture, Jurgen reminded me that in recent
>> versions there's a setting for each layer to set what CRS it is. This
>> is found in the Layer->properties window, General tab. Click on the
>> button "Specify CRS" and choose the correct coordinate system. You
>> can do this also for a delimited text file layer.  Then export to
>> shapefile works as you'd expect..
