[Qgis-user] Re: Projection of Shapefile export
Giovanni Manghi giovanni.manghi at gmail.com
Thu Sep 23 00:29:06 PDT 2010
> But I can't make the parameters stick in the CRS of a vector file using the
> override facility. Any ideas?
if you use the +nadgrids parameter you must also include also the
+wktext parameter
example:
+proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111112 +k=1
+x_0=200000 +y_0=300000 +ellps=intl +units=m +no_defs
+nadgrids=ptLX_e89.gsb +wktext
also, if you are reprojecting to a projected crs, the target crs must
include the +towgs84 parameter
example:
+proj=tmerc +lat_0=39.6682583333474 +lon_0=-8.133108333465099 +k=1
+x_0=0 +y_0=0 +ellps=GRS80 +units=m +no_defs +towgs84=0,0,0
The annoying thing is that every tool that allows reproject vectors
(example "save as...") does only let choose the target crs, so you first
have to save the vector in what need to be your source crs.
On the other hand the warp tool in the "raster" menu let the user choose
the source crs, so the transformation can be done in just one step.
cheers
-- Giovanni --
