[Qgis-user] dbf file
Jürgen E. Fischer
jef at norbit.de
Sat Sep 25 08:20:00 PDT 2010
Hi Paul,
On Sat, 25. Sep 2010 at 16:45:21 +0200, Paul Lens wrote:
> As I understand, a dbf file created in QGIS is coded in UTF-8 (Unicode).
Not necessarily. You can set the encoding - e.g. if you create a new shape
file using "New Vector Layer" you can set the encoding of the new shapefile
when you in the filename dialog.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
