[Qgis-user] Lat/long grid in print composer with a Mercator map
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Sep 27 00:36:01 PDT 2010
Hi Julian
Yes, at the moment, it is not implemented to have the composer grid in a
different crs than the map system. Afaik the only possibility now is indeed to
create a grid shape, reproject and to add the labels manually (which
unfortunately is not really convenient if you move the print extent often).
Regards,
Marco
Am Montag, 27. September 2010, um 02.20:02 schrieb Julian Burgos:
> Dear QGIS friends,
> It is possible to add a lat/long grid in the print composer if the map is
> in Mercator projection? I know that I can create a vector grid in WGS 84,
> enable 'on the fly' transformation, and change the CRS to WGS 84/Mercator
> 41. But I´m trying to get latitude and longitude values along the margins.
> The grid option in the print composer will create labels in projected
> units. Any ideas?
> Thanks,
> Julian
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Webereistr. 66, CH-8134 Adliswil, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
