Fwd: [Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
sergio sevillano
sergiosevillano.mail at gmail.com
Mon Sep 27 01:35:06 PDT 2010
> El 14/09/2010, a las 17:13, William Kyngesburye escribió:
>> On Sep 14, 2010, at 9:55 AM, sergio sevillano wrote:
>>> El 14/09/2010, a las 14:52, William Kyngesburye escribió:
>>>> What other GDAL tools have you used that work, besides gdal_contour? gdal_merge itself is a python program, while gdal_contour is a binary. It seems that an external python script is having problems finding python
>>> other .py won´t work either
>> I get this also. I'm using the standard Qgis.
>> My guess is that external python scripts aren't getting a shell environment so they can't find python, even though Qgis extensions run thru python. Those GDAL python scripts all have the standard shebang:
>> #!/usr/bin/env python
>> Someone with a better understanding of this needs to comment so I can try to figure out why the Mac build is not working (while from lack of reported problems it seems other systems work).
i have tried to start all over
as i had my system very messy (flink, darwin, several pythons...)
so i formated my hdd and start with a clean OSX
i have tried standalone Qgis and standard Qgis, neither worked.
in the standalone i have followed instructions to tell Qgis where is GDAL is
(inside the app) but the alias method did not worked
i could not select the desktop alias into the app through the GdalTools config.
when i try to merge dem files with the standard build, i get again:
"env: python: No such file or directory"
until someone with "better undersanding" comes
i may try older versions or options, any hint?
is there any older version of Qgis that works
in an intel mac with SnowLeopard (OSX10.6.x)
that has a working GDAL plugin ?
William, i can do tester work if its useful to you,
thanks for your builds
i could have not get Qgis working at all without them.
sergio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100927/768eb897/attachment.html>
