[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
Giuseppe Sucameli
brush.tyler at gmail.com
Tue Sep 28 09:31:35 PDT 2010
Hi Sergio,
it seems that env was unable to find python.
Try to open a shell and write:
/usr/bin/env python --version
What's the output?
Cheers.
On Mon, Sep 27, 2010 at 10:35 AM, sergio sevillano <
sergiosevillano.mail at gmail.com> wrote:
> El 14/09/2010, a las 17:13, William Kyngesburye escribió:
> On Sep 14, 2010, at 9:55 AM, sergio sevillano wrote:
> El 14/09/2010, a las 14:52, William Kyngesburye escribió:
> What other GDAL tools have you used that work, besides gdal_contour?
> gdal_merge itself is a python program, while gdal_contour is a binary. It
> seems that an external python script is having problems finding python
> other .py won´t work either
> I get this also. I'm using the standard Qgis.
> My guess is that external python scripts aren't getting a shell environment
> so they can't find python, even though Qgis extensions run thru python.
> Those GDAL python scripts all have the standard shebang:
> #!/usr/bin/env python
> Someone with a better understanding of this needs to comment so I can try
> to figure out why the Mac build is not working (while from lack of reported
> problems it seems other systems work).
> i have tried to start all over
> as i had my system very messy (flink, darwin, several pythons...)
> so i formated my hdd and start with a clean OSX
> i have tried standalone Qgis and standard Qgis, neither worked.
> in the standalone i have followed instructions to tell Qgis where is GDAL
> is
> (inside the app) but the alias method did not worked
> i could not select the desktop alias into the app through the GdalTools
> config.
> when i try to merge dem files with the standard build, i get again:
> "env: python: No such file or directory"
> until someone with "better undersanding" comes
> i may try older versions or options, any hint?
> is there any older version of Qgis that works
> in an intel mac with SnowLeopard (OSX10.6.x)
> that has a working GDAL plugin ?
> William, i can do tester work if its useful to you,
> thanks for your builds
> i could have not get Qgis working at all without them.
> sergio
> Qgis-user mailing list
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100928/ef60c2f2/attachment.html>
