[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
Giuseppe Sucameli brush.tyler at gmail.com
Tue Sep 28 15:03:10 PDT 2010
Hi all,
did you try to setup both python and pymods paths in the
"path to GDAL binaries"? You must separate them by :
/usr/bin:/Library/Frameworks/GDAL.framework/Versions/1.7/Python/
Try and let me know.
Cheers
2010/9/28 Pierre Chevalier Géologue <pierrechevaliergeol at free.fr>
> William Kyngesburye claviota:
>  /usr/bin/python* should already exist, they are part of the system.
>>  That's not the problem.
> Ok; I thought you may have some strange python installation. Sorry!
>  The problem is that /usr/bin is NOT in the PATH in an OS X application.
> Hm. Mac OS X's are weird sorts of unices, aren't they? (BIG TROLL
> DETECTED!) ;)
>  Applications have essentially no environment at all, but they do
>> understand environment variables.  Applications are in their own world, so
>> to speak.  There is a hidden mechanism for setting Application environment,
>> but I don't want to spread that as it is cluncky to use (need 3rd party apps
>> for a nice GUI front end), and is not well documented, if at all.
>> You got your symlinking idea backwards, but it does give me an idea for a
>> workaround:
>> ln -s /usr/bin/python2.6 /Applications/Qgis.app/Contents/MacOS/bin/python
>> This puts a symlink to the system python in the Qgis application bin,
>> which should be in the PATH in the Qgis environment.
> Yes, it makes sense! So? Does it work?
> Funny: in DOS and windows (another strange kind of OS, next troll), the
> current directory of any executable is in the path. And in unices (at least
> the ones I know), the current directory (.) is never in the path... I never
> figured it out on a Mac.
>  A stupid idea:
>> Yes, it was...
> A+
> Pierre
> ____________________________________________________________________________
> Pierre Chevalier Géologue EI
>   Mesté Duran
>   32100 Condom
>  Tél+fax  :    09 75 27 45 62
>               05 62 28 06 83
>                06 37 80 33 64
>  Émail  :   pierrechevaliergeolCHEZfree.fr
>  icq#   :   10432285
>  skype  :   pierre.chevalier1967
>  http://pierremariechevalier.free.fr/pierre_chevalier_geologue
> Qgis-user mailing list
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100929/f8d5f90a/attachment.html>
