[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
William Kyngesburye woklist at kyngchaos.com
Tue Sep 28 15:37:05 PDT 2010
I didn't know multiple paths could be used there (lack of documentation), though it makes sense.  Though pymod is not part of the problem, it's python itself.  So it should be:
/usr/bin:/Library/Frameworks/GDAL.framework/Versions/1.7/Programs/
Once Python is found in /usr/bin, the GDAL pymod will be in the python sys.path.
... and that works.
On Sep 28, 2010, at 5:03 PM, Giuseppe Sucameli wrote:
> Hi all,
> did you try to setup both python and pymods paths in the
> "path to GDAL binaries"? You must separate them by :
> /usr/bin:/Library/Frameworks/GDAL.framework/Versions/1.7/Python/
> Try and let me know.
> Cheers
> 2010/9/28 Pierre Chevalier Géologue <pierrechevaliergeol at free.fr>
> William Kyngesburye claviota:
> /usr/bin/python* should already exist, they are part of the system.  That's not the problem.
> Ok; I thought you may have some strange python installation. Sorry!
> The problem is that /usr/bin is NOT in the PATH in an OS X application.
> Hm. Mac OS X's are weird sorts of unices, aren't they? (BIG TROLL DETECTED!) ;)
> Applications have essentially no environment at all, but they do understand environment variables.  Applications are in their own world, so to speak.  There is a hidden mechanism for setting Application environment, but I don't want to spread that as it is cluncky to use (need 3rd party apps for a nice GUI front end), and is not well documented, if at all.
> You got your symlinking idea backwards, but it does give me an idea for a workaround:
> ln -s /usr/bin/python2.6 /Applications/Qgis.app/Contents/MacOS/bin/python
> This puts a symlink to the system python in the Qgis application bin, which should be in the PATH in the Qgis environment.
> Yes, it makes sense! So? Does it work?
> Funny: in DOS and windows (another strange kind of OS, next troll), the current directory of any executable is in the path. And in unices (at least the ones I know), the current directory (.) is never in the path... I never figured it out on a Mac.
> A stupid idea:
> Yes, it was...
> A+
> Pierre
> ____________________________________________________________________________
> Pierre Chevalier Géologue EI
>   Mesté Duran
>   32100 Condom
>  Tél+fax  :    09 75 27 45 62
>               05 62 28 06 83
>                06 37 80 33 64
>  Émail  :   pierrechevaliergeolCHEZfree.fr
>  icq#   :   10432285
>  skype  :   pierre.chevalier1967
>  http://pierremariechevalier.free.fr/pierre_chevalier_geologue
> Qgis-user mailing list
> Giuseppe Sucameli
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
- Marvin
