[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
Giuseppe Sucameli
brush.tyler at gmail.com
Tue Sep 28 16:25:28 PDT 2010
Hi William,
On Wed, Sep 29, 2010 at 12:37 AM, William Kyngesburye <woklist at kyngchaos.com
> wrote:
> I didn't know multiple paths could be used there (lack of documentation),
> though it makes sense.
even though I'm the GdalTools maintainer, I either didn't know
we could use multiple paths.
I looked within the code to discover the trick :-)
Though pymod is not part of the problem, it's python itself. So it should
> be:
> /usr/bin:/Library/Frameworks/GDAL.framework/Versions/1.7/Programs/
> Once Python is found in /usr/bin, the GDAL pymod will be in the python
> sys.path.
I don't know if pymods are in the python sys.path, but in order
to prevent future related issues, could you verify this?
... and that works.
Great!!! Now I can go to sleep pleased.
Cheers.
On Sep 28, 2010, at 5:03 PM, Giuseppe Sucameli wrote:
> > Hi all,
> > did you try to setup both python and pymods paths in the
> > "path to GDAL binaries"? You must separate them by :
> > /usr/bin:/Library/Frameworks/GDAL.framework/Versions/1.7/Python/
> > Try and let me know.
> > Cheers
> > 2010/9/28 Pierre Chevalier Géologue <pierrechevaliergeol at free.fr>
> > William Kyngesburye claviota:
> > /usr/bin/python* should already exist, they are part of the system.
> That's not the problem.
> > Ok; I thought you may have some strange python installation. Sorry!
> > The problem is that /usr/bin is NOT in the PATH in an OS X application.
> > Hm. Mac OS X's are weird sorts of unices, aren't they? (BIG TROLL
> DETECTED!) ;)
> > Applications have essentially no environment at all, but they do
> understand environment variables. Applications are in their own world, so
> to speak. There is a hidden mechanism for setting Application environment,
> but I don't want to spread that as it is cluncky to use (need 3rd party apps
> for a nice GUI front end), and is not well documented, if at all.
> > You got your symlinking idea backwards, but it does give me an idea for a
> workaround:
> > ln -s /usr/bin/python2.6 /Applications/Qgis.app/Contents/MacOS/bin/python
> > This puts a symlink to the system python in the Qgis application bin,
> which should be in the PATH in the Qgis environment.
> > Yes, it makes sense! So? Does it work?
> > Funny: in DOS and windows (another strange kind of OS, next troll), the
> current directory of any executable is in the path. And in unices (at least
> the ones I know), the current directory (.) is never in the path... I never
> figured it out on a Mac.
> > A stupid idea:
> > Yes, it was...
> > A+
> > Pierre
> ____________________________________________________________________________
> > Pierre Chevalier Géologue EI
> > Mesté Duran
> > 32100 Condom
> > Tél+fax : 09 75 27 45 62
> > 05 62 28 06 83
> > 06 37 80 33 64
> > Émail : pierrechevaliergeolCHEZfree.fr
> > icq# : 10432285
> > skype : pierre.chevalier1967
> > http://pierremariechevalier.free.fr/pierre_chevalier_geologue
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Giuseppe Sucameli
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
> that remind me of? Ah, yes - life."
> - Marvin
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100929/268cf850/attachment.html>
