[Qgis-user] Composer crashes qgis
custard custard at westnet.com.au
Wed Apr 6 17:46:56 PDT 2011
----- "custard" <custard at westnet.com.au> wrote:
> Hi,
> Wondering if someone could make some suggestions on this?
> I've a project that was originally set up in 1.6 and has 10 different
> composers attached to it.
> I've loaded it up and resaved it into 1.7 (trunk). Now when I try and
> print from any of these composers one of these two things happens:
> 1. QGIS crashes.
> 2. QGIS and the printer fail to complete talking to each other (the
> printer says spooling and QGIS behaves like it's already finished
> sending the data). At which point I usually get impatient and I try to
> print a second time which causes 1.
> I've updated my osgeo install.
> I've recreated one of my composers in the problem project (it doesn't
> work).
> I've attempted to replicate with a simple 1 shape project (it works
> fine).
> The other workspaces that I've tried seem fine.
> A type 1. bug trace is here:
> http://www.members.westnet.com.au/ramon_et_al/QGISPrintErrorType1.txt
> A successful print (from the simple project) bug trace is here:
> http://www.members.westnet.com.au/ramon_et_al/QGISSImpleProjectSucessfulPrint.txt
> I can put up a type 2 but trace, when I get it happen again.
> I'm guessing, recreate the project and composers?
Type 2 here:
http://www.members.westnet.com.au/ramon_et_al/Type2Error.txt
(I think it reads as the first print is still active).
-ramon.
