[Qgis-user] Inconsistent projection parameters for EPSG:3168
Richard Duivenvoorde richard at duif.net
Fri Apr 8 00:40:11 PDT 2011
Hilmy Hashim wrote:
> So where is Gdal in QGis getting it's parameters from?
Hi Hilmy,
I'm not sure if qgis, when using gdal is using gdal's proj definitions
or it's own.
But:
- for gdal's do a search for a file called epsg in your osgeo4w dir
(probably in proj dir).
- qgis get's it's parameters for a sqlite db called srs.db (somehwere in
 the qgis dirs in a dir called resources).
You can also define your own defintion in qgis and call it
'hilmysRight3168' and use that.
Or edit the srs.db with a tool like
https://addons.mozilla.org/en-us/firefox/addon/sqlite-manager/ for firefox.
A good source for all the different projection definition formats:
www.spatialreference.org
Hope this helps,
Regards,
