[Qgis-user] Inconsistent projection parameters for EPSG:3168
Richard Duivenvoorde richard at duif.net
Fri Apr 8 06:05:45 PDT 2011
Hilmy Hashim wrote:
> I checked the srs.db in OSGeo4W/apps/qgis-dev/resources/ and it has the
> correct parameter values (except for the missing +gamma parameter.
> It looks like the GdalTools plugins is looking elsewhere for its EPSG
> definitions. None of the gdal pcs.csv files I checked (there are many)
> has the correct values except for OSGeo4W/share/proj/epsg which has all
> correct values including the gamma parameter. So I wonder if gdalinfo is
> correctly printing the (pretty) WKT definition.This looks like a gdal issue.
> I am able to add the gamma parameter in the srs database, but I assume
> this would be overridden in the next version update, and I have other
> users as well. Where do I request for the +gamma parameter to be
> included permanently in the srs database?
> Thanks for your help.
Not sure, but for what I know the srs.db is generated with a script
using the same as or maybe the proj-db.
We discussed about changing stuff but I thought we came to the
conclusion to not let users/devs change this workflow. Otherwise we
would end up with non-compatible definitions by different tools.
Don't know about how gdal uses proj-info. Best to ask on the gdal list.
Richard
ps please reply to list
