[Qgis-user] RE: Qgis-user Digest, Vol 62, Issue 17
edinelson saldanha edinelson_saldanha at hotmail.com
Tue Apr 12 11:20:12 PDT 2011
-----Original Message-----
Sent: abril 11, 2011 1:01
To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 62, Issue 17
Send Qgis-user mailing list submissions to
 To subscribe or unsubscribe via the World Wide Web, visit
         http://lists.osgeo.org/mailman/listinfo/qgis-user
 or, via email, send a message with subject or body 'help' to
         qgis-user-request at lists.osgeo.org
 You can reach the person managing the list at
         qgis-user-owner at lists.osgeo.org
 When replying, please edit your Subject line so it is more specific
 than "Re: Contents of Qgis-user digest..."
 Today's Topics:
    1. Re: error with r.cost (ambijat)
    2. point displacement renderer pluggin (s.lazarescu)
    3. Re: point displacement renderer pluggin (Marco Hugentobler)
    4. Re: [GRASS-user] Re: [Qgis-user] error with r.cost (Hamish)
 Message: 1
 Date: Mon, 11 Apr 2011 13:41:11 +0530
 Subject: Re: [Qgis-user] error with r.cost
 To: Markus Neteler <neteler at osgeo.org>,  GRASS user list
         <grass-user at lists.osgeo.org>,   qgis-user <qgis-user at lists.osgeo.org>
 Message-ID: <BLU0-SMTP4C321DDFECDC8272D13AFB7A80 at phx.gbl>
 Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
 Hi! Markus,
 I am using a mask so as to limit my operation. The only improvisation I
 did was this time to run the set on Fedora14 as I have my dual boot
 machine. Luckily I have now my r.cost raster built. But, before going
 for that I reduced the SRTM altitude values to range between 0-255. So,
 some economizing on bit size was possible.
 But,
 But, now I am stuck with a new thing and this is with r.walk. I am still
 performing this operation on F14. But, there is a crash everytime. The
 input rasters are the two one the same rescaled raster for base values
 and r.cost generated raster for friction values. But, it is crashing
 every time. I am not getting a headway. I need to generate a route
 between two cities cross the Hindukush mountain ranges in Afghanistan.
 Any, ideas to this issue. I am thinking of using r.slop.aspect raster
 for friction values what do you suggest.
 Thanks and regards,
 Ambrish Dhaka
 On 4/11/2011 1:37 AM, Markus Neteler wrote:
 > Ambrish Dhaka,
 > you need to check the region extent + resolution, probably
 > you are exceeding the available RAM if you are having too
 > many rows and columns.
 > Get the information with:
 > g.region -p
 > or the respective menu entry.
 > Markus
 > On Sun, Apr 10, 2011 at 10:57 AM, ambijat<ambijat at hotmail.com>  wrote:
 >> Ramon says,
 >> I'm afraid I don't - but given the current situations, I'd suggest anyone
 >> that could help would also be wondering which version of QGIS you were using
 >> and on which operating system.
 >> The Qgis version is 1.6.0 also, the result is same on GRASS (tcl/tk) 6.4
 >> RC1, performed on WinXP SP3 on a core2Duo machine.
 >> regards,
 >> Ambrish Dhaka
 > On 10/04/2011, at 13:19 , ambijat wrote:
 >> Hi All,
 >> I am trying to create shortest path between two raster points (converted from v.to.rast) and I use the STRM data for the input values between the two points. This is the error I get.
 >> r.cost input=afg_rast at user1 output=salroute start_rast=salang at user1 max_cost=0 -k
 >> G_malloc: unable to allocate 524288 bytes at setup.c:64
 >> Finished with error
 >> Any idea why I am getting this?
 >> Thanks and regards,
 >> Ambrish Dhaka
 Message: 2
 Date: Mon, 11 Apr 2011 01:48:54 -0700 (PDT)
 From: "s.lazarescu" <stanca.lazarescu at gmail.com>
 Subject: [Qgis-user] point displacement renderer pluggin
 Message-ID: <1302511734498-6260654.post at n2.nabble.com>
 Content-Type: text/plain; charset=us-ascii
 Hello,
 I am addressing you all regarding the QGIS plugin "point displacement
 renderer".
 I am presently working with QGIS for my internship project and I have
 encountered the problem of overlapping point features, representing the
 entreprises that were geolocated according to their postal address and often
 at the street level.
 The functionnality of this plugin could be the solution. Since it doesn't
 seem to be part of the core plugins of QGIS I am looking for a link allowing
 me to download its sources. I tried the link proposed by Marco Hugentobler
 (www.hugis.net/point_displacement_renderer.tgz) but it is no longer valid.
 I would highly appreciate your helping me out.
 Thank you
 Cheers
 Stanca
 View this message in context: http://osgeo-org.1803224.n2.nabble.com/point-displacement-renderer-pluggin-tp6260654p6260654.html
 Sent from the qgis-user mailing list archive at Nabble.com.
 Message: 3
 Date: Mon, 11 Apr 2011 11:01:43 +0200
 From: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
 Subject: Re: [Qgis-user] point displacement renderer pluggin
 Message-ID: <201104111101.43506.marco.hugentobler at sourcepole.ch>
 Content-Type: Text/Plain;  charset="iso-8859-1"
 Hi Stanca
 The point displacement plugin is in QGIS svn now. You could checkout the
 sources with subversion (svn co https://svn.osgeo.org/qgis). The plugin code
 is in the folder ssrc/plugins/point_displacement_renderer.
 Regards,
 Marco
 Am Montag, 11. April 2011, um 10.48:54 schrieb s.lazarescu:
 > Hello,
 > renderer".
 > often at the street level.
 > allowing me to download its sources. I tried the link proposed by Marco
 > Hugentobler (www.hugis.net/point_displacement_renderer.tgz) but it is no
 > longer valid.
 > Thank you
 > Cheers
 > Stanca
 > -tp6260654p6260654.html Sent from the qgis-user mailing list archive at
 > Nabble.com.
 Dr. Marco Hugentobler
 Sourcepole -  Linux & Open Source Solutions
 Churerstrasse 22, CH-8808 Pf?ffikon SZ, Switzerland
 marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
 Technical Advisor QGIS Project Steering Committee
 Message: 4
 Date: Mon, 11 Apr 2011 06:19:05 -0700 (PDT)
 Subject: Re: [GRASS-user] Re: [Qgis-user] error with r.cost
 To: GRASS user list <grass-user at lists.osgeo.org>,       qgis-user
         <qgis-user at lists.osgeo.org>, ambijat <ambijat at hotmail.com>
 Message-ID: <286096.45501.qm at web110010.mail.gq1.yahoo.com>
 > > g.region -p
 > r.walk. I am still performing this operation on F14. But,
 is it the the same G_alloc() error message? if not, what does
 the crash report say? if so it means you do not have enough
 memory, which usually happens when the raster region/resolution
 is set to crazy values.
 As Markus asked, what does the region information from
 "g.region -p" say? Is it more than ~ 40000x40000 rows and
 columns?
 Hamish
 End of Qgis-user Digest, Vol 62, Issue 17
