[Qgis-user] Change CRS of WFS layer
Hilmy Hashim hilmyh at gmail.com
Tue Apr 26 12:18:57 PDT 2011
But isn't wfs suppose to allow you change the CRS and have it serve the
reprojected data? In any case, what is the purpose of the CRS Change button
in the plugin?
My problem is, qgis does not at the moment handle my projections (EPSG:3168
and 3375) correctly. This is my work-around using wfs from Geoserver,
Thanks and regards
*Hilmy*
On Wed, Apr 27, 2011 at 3:10 AM, Giovanni Manghi
<giovanni.manghi at gmail.com>wrote:
> Hi,
> > When I load a layer from Geoserver using the wfs plugin, how do I
> > change the declared layer srs to a different crs? The Change... button
> > in the plugin doesn't allow me to select other crs. Only the declared
> > srs of the wfs layer is available.
> you can't, a specific wfs layer can be served only in one CRS, at least
> on UMN Mapserver.
> Nevertheless you can reproject as you want the wfs layer as any other
> vector layer.
> Cheers
> -- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110427/6476ebb6/attachment.html>
