[Qgis-user] Tif too slow to show
Patrice Vetsel
ubuntu at kagou.fr
Fri Apr 29 05:08:00 PDT 2011
with an original raster (tif+tfw), from french cadastre, when I open it under qgis, it's unusable because QGis is horribly slow.
with the same raster, but after using georef extension (tif+aux.xml), QGis is responsive
here I put gdalinfo of the original (slow) and referenced :
What's the problem with the first ? I would prefer to not have to manually georeference all my original rasters ;)
In the same time, what's the most efficient raster type to use with QGis ?
Regards
Patrice Vetsel
SLOW :
MacBook-Pro-de-Patrice-Vetsel:~ Patrice$ /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/3004221146000AB010200001.tif
Driver: GTiff/GeoTIFF
Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
/Users/Patrice/Desktop/3004221146000AB010200001.tfw
Size is 12329, 8760
Coordinate System is `'
GeoTransform =
740551.2494, 0.078, 0.1506
189669.7013, 0.1506, -0.078
Metadata:
TIFFTAG_ARTIST=JBG-PYV-APIC
TIFFTAG_XRESOLUTION=300
TIFFTAG_YRESOLUTION=300
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=CCITTFAX4
INTERLEAVE=BAND
MINISWHITE=YES
Corner Coordinates:
Upper Left ( 740551.249, 189669.701)
Lower Left ( 741870.505, 188986.421)
Upper Right ( 741512.911, 191526.449)
Lower Right ( 742832.167, 190843.169)
Center ( 741691.708, 190256.435)
Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
NBITS=1
Color Table (RGB with 2 entries)
0: 255,255,255,255
1: 0,0,0,255
OK :
MacBook-Pro-de-Patrice-Vetsel:~ Patrice$ /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/testgeo/AB_georef.tif
Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
/Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
Size is 13446, 14968
Origin = (740550.783870017039590,191526.220101331215119)
Pixel Size = (0.169699598291267,-0.169699598291267)
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 740550.784, 191526.220)
Lower Left ( 740550.784, 188986.157)
Upper Right ( 742832.565, 191526.220)
Lower Right ( 742832.565, 188986.157)
Center ( 741691.674, 190256.188)
Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 255,255,255,255
1: 0,0,0,255
2: 0,0,0,255
3: 0,0,0,255
4: 0,0,0,255
5: 0,0,0,255
6: 0,0,0,255
7: 0,0,0,255
8: 0,0,0,255
9: 0,0,0,255
10: 0,0,0,255
11: 0,0,0,255
12: 0,0,0,255
13: 0,0,0,255
14: 0,0,0,255
15: 0,0,0,255
16: 0,0,0,255
17: 0,0,0,255
18: 0,0,0,255
19: 0,0,0,255
20: 0,0,0,255
21: 0,0,0,255
22: 0,0,0,255
23: 0,0,0,255
24: 0,0,0,255
25: 0,0,0,255
26: 0,0,0,255
27: 0,0,0,255
28: 0,0,0,255
29: 0,0,0,255
30: 0,0,0,255
31: 0,0,0,255
32: 0,0,0,255
33: 0,0,0,255
34: 0,0,0,255
35: 0,0,0,255
36: 0,0,0,255
37: 0,0,0,255
38: 0,0,0,255
39: 0,0,0,255
40: 0,0,0,255
41: 0,0,0,255
42: 0,0,0,255
43: 0,0,0,255
44: 0,0,0,255
45: 0,0,0,255
46: 0,0,0,255
47: 0,0,0,255
48: 0,0,0,255
49: 0,0,0,255
50: 0,0,0,255
51: 0,0,0,255
52: 0,0,0,255
53: 0,0,0,255
54: 0,0,0,255
55: 0,0,0,255
56: 0,0,0,255
57: 0,0,0,255
58: 0,0,0,255
59: 0,0,0,255
60: 0,0,0,255
61: 0,0,0,255
62: 0,0,0,255
63: 0,0,0,255
64: 0,0,0,255
65: 0,0,0,255
66: 0,0,0,255
67: 0,0,0,255
68: 0,0,0,255
69: 0,0,0,255
70: 0,0,0,255
71: 0,0,0,255
72: 0,0,0,255
73: 0,0,0,255
74: 0,0,0,255
75: 0,0,0,255
76: 0,0,0,255
77: 0,0,0,255
78: 0,0,0,255
79: 0,0,0,255
80: 0,0,0,255
81: 0,0,0,255
82: 0,0,0,255
83: 0,0,0,255
84: 0,0,0,255
85: 0,0,0,255
86: 0,0,0,255
87: 0,0,0,255
88: 0,0,0,255
89: 0,0,0,255
90: 0,0,0,255
91: 0,0,0,255
92: 0,0,0,255
93: 0,0,0,255
94: 0,0,0,255
95: 0,0,0,255
96: 0,0,0,255
97: 0,0,0,255
98: 0,0,0,255
99: 0,0,0,255
100: 0,0,0,255
101: 0,0,0,255
102: 0,0,0,255
103: 0,0,0,255
104: 0,0,0,255
105: 0,0,0,255
106: 0,0,0,255
107: 0,0,0,255
108: 0,0,0,255
109: 0,0,0,255
110: 0,0,0,255
111: 0,0,0,255
112: 0,0,0,255
113: 0,0,0,255
114: 0,0,0,255
115: 0,0,0,255
116: 0,0,0,255
117: 0,0,0,255
118: 0,0,0,255
119: 0,0,0,255
120: 0,0,0,255
121: 0,0,0,255
122: 0,0,0,255
123: 0,0,0,255
124: 0,0,0,255
125: 0,0,0,255
126: 0,0,0,255
127: 0,0,0,255
128: 0,0,0,255
129: 0,0,0,255
130: 0,0,0,255
131: 0,0,0,255
132: 0,0,0,255
133: 0,0,0,255
134: 0,0,0,255
135: 0,0,0,255
136: 0,0,0,255
137: 0,0,0,255
138: 0,0,0,255
139: 0,0,0,255
140: 0,0,0,255
141: 0,0,0,255
142: 0,0,0,255
143: 0,0,0,255
144: 0,0,0,255
145: 0,0,0,255
146: 0,0,0,255
147: 0,0,0,255
148: 0,0,0,255
149: 0,0,0,255
150: 0,0,0,255
151: 0,0,0,255
152: 0,0,0,255
153: 0,0,0,255
154: 0,0,0,255
155: 0,0,0,255
156: 0,0,0,255
157: 0,0,0,255
158: 0,0,0,255
159: 0,0,0,255
160: 0,0,0,255
161: 0,0,0,255
162: 0,0,0,255
163: 0,0,0,255
164: 0,0,0,255
165: 0,0,0,255
166: 0,0,0,255
167: 0,0,0,255
168: 0,0,0,255
169: 0,0,0,255
170: 0,0,0,255
171: 0,0,0,255
172: 0,0,0,255
173: 0,0,0,255
174: 0,0,0,255
175: 0,0,0,255
176: 0,0,0,255
177: 0,0,0,255
178: 0,0,0,255
179: 0,0,0,255
180: 0,0,0,255
181: 0,0,0,255
182: 0,0,0,255
183: 0,0,0,255
184: 0,0,0,255
185: 0,0,0,255
186: 0,0,0,255
187: 0,0,0,255
188: 0,0,0,255
189: 0,0,0,255
190: 0,0,0,255
191: 0,0,0,255
192: 0,0,0,255
193: 0,0,0,255
194: 0,0,0,255
195: 0,0,0,255
196: 0,0,0,255
197: 0,0,0,255
198: 0,0,0,255
199: 0,0,0,255
200: 0,0,0,255
201: 0,0,0,255
202: 0,0,0,255
203: 0,0,0,255
204: 0,0,0,255
205: 0,0,0,255
206: 0,0,0,255
207: 0,0,0,255
208: 0,0,0,255
209: 0,0,0,255
210: 0,0,0,255
211: 0,0,0,255
212: 0,0,0,255
213: 0,0,0,255
214: 0,0,0,255
215: 0,0,0,255
216: 0,0,0,255
217: 0,0,0,255
218: 0,0,0,255
219: 0,0,0,255
220: 0,0,0,255
221: 0,0,0,255
222: 0,0,0,255
223: 0,0,0,255
224: 0,0,0,255
225: 0,0,0,255
226: 0,0,0,255
227: 0,0,0,255
228: 0,0,0,255
229: 0,0,0,255
230: 0,0,0,255
231: 0,0,0,255
232: 0,0,0,255
233: 0,0,0,255
234: 0,0,0,255
235: 0,0,0,255
236: 0,0,0,255
237: 0,0,0,255
238: 0,0,0,255
239: 0,0,0,255
240: 0,0,0,255
241: 0,0,0,255
242: 0,0,0,255
243: 0,0,0,255
244: 0,0,0,255
245: 0,0,0,255
246: 0,0,0,255
247: 0,0,0,255
248: 0,0,0,255
249: 0,0,0,255
250: 0,0,0,255
251: 0,0,0,255
252: 0,0,0,255
253: 0,0,0,255
254: 0,0,0,255
255: 0,0,0,255
