[Qgis-user] Tif too slow to show
Kris Nackaerts knackaerts at gmx.net
Fri Apr 29 05:21:51 PDT 2011
Dear,
I would start trying gdaladdo to create overviews. Does wonders for speed.
I'm working right now with a global Landsat dataset, vrt, +4000 tiles, roughly 700k by 300k pixels in total, and even this can be handled efficiently once you've overviews.
I mainly use uncompressed geotiffs.
Kris
-------- Original-Nachricht --------
> Datum: Fri, 29 Apr 2011 14:08:00 +0200
> Von: Patrice Vetsel <ubuntu at kagou.fr>
> An: qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Tif too slow to show
> Hi,
> with an original raster (tif+tfw), from french cadastre, when I open it
> under qgis, it's unusable because QGis is horribly slow.
> with the same raster, but after using georef extension (tif+aux.xml), QGis
> is responsive
> here I put gdalinfo of the original (slow) and referenced :
> What's the problem with the first ? I would prefer to not have to manually
> georeference all my original rasters ;)
> In the same time, what's the most efficient raster type to use with QGis ?
> Regards
> Patrice Vetsel
> SLOW :
> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$
> /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/3004221146000AB010200001.tif
> Driver: GTiff/GeoTIFF
> Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
>        /Users/Patrice/Desktop/3004221146000AB010200001.tfw
> Size is 12329, 8760
> Coordinate System is `'
> GeoTransform =
>   740551.2494, 0.078, 0.1506
>   189669.7013, 0.1506, -0.078
> Metadata:
>   TIFFTAG_ARTIST=JBG-PYV-APIC
>   TIFFTAG_XRESOLUTION=300
>   TIFFTAG_YRESOLUTION=300
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>   COMPRESSION=CCITTFAX4
>   INTERLEAVE=BAND
>   MINISWHITE=YES
> Corner Coordinates:
> Upper Left  (  740551.249,  189669.701)
> Lower Left  (  741870.505,  188986.421)
> Upper Right (  741512.911,  191526.449)
> Lower Right (  742832.167,  190843.169)
> Center      (  741691.708,  190256.435)
> Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
>     NBITS=1
>   Color Table (RGB with 2 entries)
>     0: 255,255,255,255
>     1: 0,0,0,255
> OK :
> /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/testgeo/AB_georef.tif
> Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
>        /Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
> Size is 13446, 14968
> Origin = (740550.783870017039590,191526.220101331215119)
> Pixel Size = (0.169699598291267,-0.169699598291267)
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  740550.784,  191526.220)
> Lower Left  (  740550.784,  188986.157)
> Upper Right (  742832.565,  191526.220)
> Lower Right (  742832.565,  188986.157)
> Center      (  741691.674,  190256.188)
> Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
>   Color Table (RGB with 256 entries)
>     0: 255,255,255,255
>     1: 0,0,0,255
>     2: 0,0,0,255
>     3: 0,0,0,255
>     4: 0,0,0,255
>     5: 0,0,0,255
>     6: 0,0,0,255
>     7: 0,0,0,255
>     8: 0,0,0,255
>     9: 0,0,0,255
>    10: 0,0,0,255
>    11: 0,0,0,255
>    12: 0,0,0,255
>    13: 0,0,0,255
>    14: 0,0,0,255
>    15: 0,0,0,255
>    16: 0,0,0,255
>    17: 0,0,0,255
>    18: 0,0,0,255
>    19: 0,0,0,255
>    20: 0,0,0,255
>    21: 0,0,0,255
>    22: 0,0,0,255
>    23: 0,0,0,255
>    24: 0,0,0,255
>    25: 0,0,0,255
>    26: 0,0,0,255
>    27: 0,0,0,255
>    28: 0,0,0,255
>    29: 0,0,0,255
>    30: 0,0,0,255
>    31: 0,0,0,255
>    32: 0,0,0,255
>    33: 0,0,0,255
>    34: 0,0,0,255
>    35: 0,0,0,255
>    36: 0,0,0,255
>    37: 0,0,0,255
>    38: 0,0,0,255
>    39: 0,0,0,255
>    40: 0,0,0,255
>    41: 0,0,0,255
>    42: 0,0,0,255
>    43: 0,0,0,255
>    44: 0,0,0,255
>    45: 0,0,0,255
>    46: 0,0,0,255
>    47: 0,0,0,255
>    48: 0,0,0,255
>    49: 0,0,0,255
>    50: 0,0,0,255
>    51: 0,0,0,255
>    52: 0,0,0,255
>    53: 0,0,0,255
>    54: 0,0,0,255
>    55: 0,0,0,255
>    56: 0,0,0,255
>    57: 0,0,0,255
>    58: 0,0,0,255
>    59: 0,0,0,255
>    60: 0,0,0,255
>    61: 0,0,0,255
>    62: 0,0,0,255
>    63: 0,0,0,255
>    64: 0,0,0,255
>    65: 0,0,0,255
>    66: 0,0,0,255
>    67: 0,0,0,255
>    68: 0,0,0,255
>    69: 0,0,0,255
>    70: 0,0,0,255
>    71: 0,0,0,255
>    72: 0,0,0,255
>    73: 0,0,0,255
>    74: 0,0,0,255
>    75: 0,0,0,255
>    76: 0,0,0,255
>    77: 0,0,0,255
>    78: 0,0,0,255
>    79: 0,0,0,255
>    80: 0,0,0,255
>    81: 0,0,0,255
>    82: 0,0,0,255
>    83: 0,0,0,255
>    84: 0,0,0,255
>    85: 0,0,0,255
>    86: 0,0,0,255
>    87: 0,0,0,255
>    88: 0,0,0,255
>    89: 0,0,0,255
>    90: 0,0,0,255
>    91: 0,0,0,255
>    92: 0,0,0,255
>    93: 0,0,0,255
>    94: 0,0,0,255
>    95: 0,0,0,255
>    96: 0,0,0,255
>    97: 0,0,0,255
>    98: 0,0,0,255
>    99: 0,0,0,255
>   100: 0,0,0,255
>   101: 0,0,0,255
>   102: 0,0,0,255
>   103: 0,0,0,255
>   104: 0,0,0,255
>   105: 0,0,0,255
>   106: 0,0,0,255
>   107: 0,0,0,255
>   108: 0,0,0,255
>   109: 0,0,0,255
>   110: 0,0,0,255
>   111: 0,0,0,255
>   112: 0,0,0,255
>   113: 0,0,0,255
>   114: 0,0,0,255
>   115: 0,0,0,255
>   116: 0,0,0,255
>   117: 0,0,0,255
>   118: 0,0,0,255
>   119: 0,0,0,255
>   120: 0,0,0,255
>   121: 0,0,0,255
>   122: 0,0,0,255
>   123: 0,0,0,255
>   124: 0,0,0,255
>   125: 0,0,0,255
>   126: 0,0,0,255
>   127: 0,0,0,255
>   128: 0,0,0,255
>   129: 0,0,0,255
>   130: 0,0,0,255
>   131: 0,0,0,255
>   132: 0,0,0,255
>   133: 0,0,0,255
>   134: 0,0,0,255
>   135: 0,0,0,255
>   136: 0,0,0,255
>   137: 0,0,0,255
>   138: 0,0,0,255
>   139: 0,0,0,255
>   140: 0,0,0,255
>   141: 0,0,0,255
>   142: 0,0,0,255
>   143: 0,0,0,255
>   144: 0,0,0,255
>   145: 0,0,0,255
>   146: 0,0,0,255
>   147: 0,0,0,255
>   148: 0,0,0,255
>   149: 0,0,0,255
>   150: 0,0,0,255
>   151: 0,0,0,255
>   152: 0,0,0,255
>   153: 0,0,0,255
>   154: 0,0,0,255
>   155: 0,0,0,255
>   156: 0,0,0,255
>   157: 0,0,0,255
>   158: 0,0,0,255
>   159: 0,0,0,255
>   160: 0,0,0,255
>   161: 0,0,0,255
>   162: 0,0,0,255
>   163: 0,0,0,255
>   164: 0,0,0,255
>   165: 0,0,0,255
>   166: 0,0,0,255
>   167: 0,0,0,255
>   168: 0,0,0,255
>   169: 0,0,0,255
>   170: 0,0,0,255
>   171: 0,0,0,255
>   172: 0,0,0,255
>   173: 0,0,0,255
>   174: 0,0,0,255
>   175: 0,0,0,255
>   176: 0,0,0,255
>   177: 0,0,0,255
>   178: 0,0,0,255
>   179: 0,0,0,255
>   180: 0,0,0,255
>   181: 0,0,0,255
>   182: 0,0,0,255
>   183: 0,0,0,255
>   184: 0,0,0,255
>   185: 0,0,0,255
>   186: 0,0,0,255
>   187: 0,0,0,255
>   188: 0,0,0,255
>   189: 0,0,0,255
>   190: 0,0,0,255
>   191: 0,0,0,255
>   192: 0,0,0,255
>   193: 0,0,0,255
>   194: 0,0,0,255
>   195: 0,0,0,255
>   196: 0,0,0,255
>   197: 0,0,0,255
>   198: 0,0,0,255
>   199: 0,0,0,255
>   200: 0,0,0,255
>   201: 0,0,0,255
>   202: 0,0,0,255
>   203: 0,0,0,255
>   204: 0,0,0,255
>   205: 0,0,0,255
>   206: 0,0,0,255
>   207: 0,0,0,255
>   208: 0,0,0,255
>   209: 0,0,0,255
>   210: 0,0,0,255
>   211: 0,0,0,255
>   212: 0,0,0,255
>   213: 0,0,0,255
>   214: 0,0,0,255
>   215: 0,0,0,255
>   216: 0,0,0,255
>   217: 0,0,0,255
>   218: 0,0,0,255
>   219: 0,0,0,255
>   220: 0,0,0,255
>   221: 0,0,0,255
>   222: 0,0,0,255
>   223: 0,0,0,255
>   224: 0,0,0,255
>   225: 0,0,0,255
>   226: 0,0,0,255
>   227: 0,0,0,255
>   228: 0,0,0,255
>   229: 0,0,0,255
>   230: 0,0,0,255
>   231: 0,0,0,255
>   232: 0,0,0,255
>   233: 0,0,0,255
>   234: 0,0,0,255
>   235: 0,0,0,255
>   236: 0,0,0,255
>   237: 0,0,0,255
>   238: 0,0,0,255
>   239: 0,0,0,255
>   240: 0,0,0,255
>   241: 0,0,0,255
>   242: 0,0,0,255
>   243: 0,0,0,255
>   244: 0,0,0,255
>   245: 0,0,0,255
>   246: 0,0,0,255
>   247: 0,0,0,255
>   248: 0,0,0,255
>   249: 0,0,0,255
>   250: 0,0,0,255
>   251: 0,0,0,255
>   252: 0,0,0,255
>   253: 0,0,0,255
>   254: 0,0,0,255
>   255: 0,0,0,255
> Qgis-user mailing list
Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
