[Qgis-user] Tif too slow to show
Patrice Vetsel ubuntu at kagou.fr
Fri Apr 29 06:57:07 PDT 2011
Is it because the original is not Nort-South oriented and must be
rotated by QGis ?
Le 29/04/11 14:08, Patrice Vetsel a écrit :
> Hi,
> with an original raster (tif+tfw), from french cadastre, when I open it under qgis, it's unusable because QGis is horribly slow.
> with the same raster, but after using georef extension (tif+aux.xml), QGis is responsive
> here I put gdalinfo of the original (slow) and referenced :
> What's the problem with the first ? I would prefer to not have to manually georeference all my original rasters ;)
> In the same time, what's the most efficient raster type to use with QGis ?
> Regards
> Patrice Vetsel
> SLOW :
> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$ /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/3004221146000AB010200001.tif
> Driver: GTiff/GeoTIFF
> Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
>         /Users/Patrice/Desktop/3004221146000AB010200001.tfw
> Size is 12329, 8760
> Coordinate System is `'
> GeoTransform =
>    740551.2494, 0.078, 0.1506
>    189669.7013, 0.1506, -0.078
> Metadata:
>    TIFFTAG_ARTIST=JBG-PYV-APIC
>    TIFFTAG_XRESOLUTION=300
>    TIFFTAG_YRESOLUTION=300
>    TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>    COMPRESSION=CCITTFAX4
>    INTERLEAVE=BAND
>    MINISWHITE=YES
> Corner Coordinates:
> Upper Left  (  740551.249,  189669.701)
> Lower Left  (  741870.505,  188986.421)
> Upper Right (  741512.911,  191526.449)
> Lower Right (  742832.167,  190843.169)
> Center      (  741691.708,  190256.435)
> Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
>      NBITS=1
>    Color Table (RGB with 2 entries)
>      0: 255,255,255,255
>      1: 0,0,0,255
> OK :
> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$ /Library/Frameworks/GDAL.framework/Programs/gdalinfo ~/Desktop/testgeo/AB_georef.tif
> Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
>         /Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
> Size is 13446, 14968
> Origin = (740550.783870017039590,191526.220101331215119)
> Pixel Size = (0.169699598291267,-0.169699598291267)
>    INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  740550.784,  191526.220)
> Lower Left  (  740550.784,  188986.157)
> Upper Right (  742832.565,  191526.220)
> Lower Right (  742832.565,  188986.157)
> Center      (  741691.674,  190256.188)
> Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
>    Color Table (RGB with 256 entries)
>      0: 255,255,255,255
>      1: 0,0,0,255
>      2: 0,0,0,255
>      3: 0,0,0,255
>      4: 0,0,0,255
>      5: 0,0,0,255
>      6: 0,0,0,255
>      7: 0,0,0,255
>      8: 0,0,0,255
>      9: 0,0,0,255
>     10: 0,0,0,255
>     11: 0,0,0,255
>     12: 0,0,0,255
>     13: 0,0,0,255
>     14: 0,0,0,255
>     15: 0,0,0,255
>     16: 0,0,0,255
>     17: 0,0,0,255
>     18: 0,0,0,255
>     19: 0,0,0,255
>     20: 0,0,0,255
>     21: 0,0,0,255
>     22: 0,0,0,255
>     23: 0,0,0,255
>     24: 0,0,0,255
>     25: 0,0,0,255
>     26: 0,0,0,255
>     27: 0,0,0,255
>     28: 0,0,0,255
>     29: 0,0,0,255
>     30: 0,0,0,255
>     31: 0,0,0,255
>     32: 0,0,0,255
>     33: 0,0,0,255
>     34: 0,0,0,255
>     35: 0,0,0,255
>     36: 0,0,0,255
>     37: 0,0,0,255
>     38: 0,0,0,255
>     39: 0,0,0,255
>     40: 0,0,0,255
>     41: 0,0,0,255
>     42: 0,0,0,255
>     43: 0,0,0,255
>     44: 0,0,0,255
>     45: 0,0,0,255
>     46: 0,0,0,255
>     47: 0,0,0,255
>     48: 0,0,0,255
>     49: 0,0,0,255
>     50: 0,0,0,255
>     51: 0,0,0,255
>     52: 0,0,0,255
>     53: 0,0,0,255
>     54: 0,0,0,255
>     55: 0,0,0,255
>     56: 0,0,0,255
>     57: 0,0,0,255
>     58: 0,0,0,255
>     59: 0,0,0,255
>     60: 0,0,0,255
>     61: 0,0,0,255
>     62: 0,0,0,255
>     63: 0,0,0,255
>     64: 0,0,0,255
>     65: 0,0,0,255
>     66: 0,0,0,255
>     67: 0,0,0,255
>     68: 0,0,0,255
>     69: 0,0,0,255
>     70: 0,0,0,255
>     71: 0,0,0,255
>     72: 0,0,0,255
>     73: 0,0,0,255
>     74: 0,0,0,255
>     75: 0,0,0,255
>     76: 0,0,0,255
>     77: 0,0,0,255
>     78: 0,0,0,255
>     79: 0,0,0,255
>     80: 0,0,0,255
>     81: 0,0,0,255
>     82: 0,0,0,255
>     83: 0,0,0,255
>     84: 0,0,0,255
>     85: 0,0,0,255
>     86: 0,0,0,255
>     87: 0,0,0,255
>     88: 0,0,0,255
>     89: 0,0,0,255
>     90: 0,0,0,255
>     91: 0,0,0,255
>     92: 0,0,0,255
>     93: 0,0,0,255
>     94: 0,0,0,255
>     95: 0,0,0,255
>     96: 0,0,0,255
>     97: 0,0,0,255
>     98: 0,0,0,255
>     99: 0,0,0,255
>    100: 0,0,0,255
>    101: 0,0,0,255
>    102: 0,0,0,255
>    103: 0,0,0,255
>    104: 0,0,0,255
>    105: 0,0,0,255
>    106: 0,0,0,255
>    107: 0,0,0,255
>    108: 0,0,0,255
>    109: 0,0,0,255
>    110: 0,0,0,255
>    111: 0,0,0,255
>    112: 0,0,0,255
>    113: 0,0,0,255
>    114: 0,0,0,255
>    115: 0,0,0,255
>    116: 0,0,0,255
>    117: 0,0,0,255
>    118: 0,0,0,255
>    119: 0,0,0,255
>    120: 0,0,0,255
>    121: 0,0,0,255
>    122: 0,0,0,255
>    123: 0,0,0,255
>    124: 0,0,0,255
>    125: 0,0,0,255
>    126: 0,0,0,255
>    127: 0,0,0,255
>    128: 0,0,0,255
>    129: 0,0,0,255
>    130: 0,0,0,255
>    131: 0,0,0,255
>    132: 0,0,0,255
>    133: 0,0,0,255
>    134: 0,0,0,255
>    135: 0,0,0,255
>    136: 0,0,0,255
>    137: 0,0,0,255
>    138: 0,0,0,255
>    139: 0,0,0,255
>    140: 0,0,0,255
>    141: 0,0,0,255
>    142: 0,0,0,255
>    143: 0,0,0,255
>    144: 0,0,0,255
>    145: 0,0,0,255
>    146: 0,0,0,255
>    147: 0,0,0,255
>    148: 0,0,0,255
>    149: 0,0,0,255
>    150: 0,0,0,255
>    151: 0,0,0,255
>    152: 0,0,0,255
>    153: 0,0,0,255
>    154: 0,0,0,255
>    155: 0,0,0,255
>    156: 0,0,0,255
>    157: 0,0,0,255
>    158: 0,0,0,255
>    159: 0,0,0,255
>    160: 0,0,0,255
>    161: 0,0,0,255
>    162: 0,0,0,255
>    163: 0,0,0,255
>    164: 0,0,0,255
>    165: 0,0,0,255
>    166: 0,0,0,255
>    167: 0,0,0,255
>    168: 0,0,0,255
>    169: 0,0,0,255
>    170: 0,0,0,255
>    171: 0,0,0,255
>    172: 0,0,0,255
>    173: 0,0,0,255
>    174: 0,0,0,255
>    175: 0,0,0,255
>    176: 0,0,0,255
>    177: 0,0,0,255
>    178: 0,0,0,255
>    179: 0,0,0,255
>    180: 0,0,0,255
>    181: 0,0,0,255
>    182: 0,0,0,255
>    183: 0,0,0,255
>    184: 0,0,0,255
>    185: 0,0,0,255
>    186: 0,0,0,255
>    187: 0,0,0,255
>    188: 0,0,0,255
>    189: 0,0,0,255
>    190: 0,0,0,255
>    191: 0,0,0,255
>    192: 0,0,0,255
>    193: 0,0,0,255
>    194: 0,0,0,255
>    195: 0,0,0,255
>    196: 0,0,0,255
>    197: 0,0,0,255
>    198: 0,0,0,255
>    199: 0,0,0,255
>    200: 0,0,0,255
>    201: 0,0,0,255
>    202: 0,0,0,255
>    203: 0,0,0,255
>    204: 0,0,0,255
>    205: 0,0,0,255
>    206: 0,0,0,255
>    207: 0,0,0,255
>    208: 0,0,0,255
>    209: 0,0,0,255
>    210: 0,0,0,255
>    211: 0,0,0,255
>    212: 0,0,0,255
>    213: 0,0,0,255
>    214: 0,0,0,255
>    215: 0,0,0,255
>    216: 0,0,0,255
>    217: 0,0,0,255
>    218: 0,0,0,255
>    219: 0,0,0,255
>    220: 0,0,0,255
>    221: 0,0,0,255
>    222: 0,0,0,255
>    223: 0,0,0,255
>    224: 0,0,0,255
>    225: 0,0,0,255
>    226: 0,0,0,255
>    227: 0,0,0,255
>    228: 0,0,0,255
>    229: 0,0,0,255
>    230: 0,0,0,255
>    231: 0,0,0,255
>    232: 0,0,0,255
>    233: 0,0,0,255
>    234: 0,0,0,255
>    235: 0,0,0,255
>    236: 0,0,0,255
>    237: 0,0,0,255
>    238: 0,0,0,255
>    239: 0,0,0,255
>    240: 0,0,0,255
>    241: 0,0,0,255
>    242: 0,0,0,255
>    243: 0,0,0,255
>    244: 0,0,0,255
>    245: 0,0,0,255
>    246: 0,0,0,255
>    247: 0,0,0,255
>    248: 0,0,0,255
>    249: 0,0,0,255
>    250: 0,0,0,255
>    251: 0,0,0,255
>    252: 0,0,0,255
>    253: 0,0,0,255
>    254: 0,0,0,255
>    255: 0,0,0,255
> Qgis-user mailing list
