[Qgis-user] Tif too slow to show
Luca Lanteri mescal72 at gmail.com
Fri Apr 29 23:17:01 PDT 2011
yes, in the 1st tiff header the
GeoTransform =
 740551.2494, 0.078, 0.1506
 189669.7013, 0.1506, -0.078
it means
GeoTransform =
  <lon offset> <scale related> <nonzero rotation>
  <lat offset> <nonzero rotation> <scale related>
if you transform the N-S oriented image in a NS oriented image I think the
image will be magically displayed faster.
Of course, adding tiled and overview with gdal should improve the
performance.
I think the problem isn't in the GDAL drivers because I try to open the same
"slow" image with others OS GIS and the it's is displayed well.
2011/4/29 Patrice Vetsel <ubuntu at kagou.fr>
> Is it because the original is not Nort-South oriented and must be rotated
> by QGis ?
> Le 29/04/11 14:08, Patrice Vetsel a écrit :
>  Hi,
>> with an original raster (tif+tfw), from french cadastre, when I open it
>> under qgis, it's unusable because QGis is horribly slow.
>> with the same raster, but after using georef extension (tif+aux.xml), QGis
>> is responsive
>> here I put gdalinfo of the original (slow) and referenced :
>> What's the problem with the first ? I would prefer to not have to manually
>> georeference all my original rasters ;)
>> In the same time, what's the most efficient raster type to use with QGis ?
>> Regards
>> Patrice Vetsel
>> SLOW :
>> MacBook-Pro-de-Patrice-Vetsel:~ Patrice$
>> /Library/Frameworks/GDAL.framework/Programs/gdalinfo
>> ~/Desktop/3004221146000AB010200001.tif
>> Driver: GTiff/GeoTIFF
>> Files: /Users/Patrice/Desktop/3004221146000AB010200001.tif
>>        /Users/Patrice/Desktop/3004221146000AB010200001.tfw
>> Size is 12329, 8760
>> Coordinate System is `'
>> GeoTransform =
>> Metadata:
>>   TIFFTAG_ARTIST=JBG-PYV-APIC
>>   TIFFTAG_XRESOLUTION=300
>>   TIFFTAG_YRESOLUTION=300
>>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> Image Structure Metadata:
>>   COMPRESSION=CCITTFAX4
>>   INTERLEAVE=BAND
>>   MINISWHITE=YES
>> Corner Coordinates:
>> Upper Left  (  740551.249,  189669.701)
>> Lower Left  (  741870.505,  188986.421)
>> Upper Right (  741512.911,  191526.449)
>> Lower Right (  742832.167,  190843.169)
>> Center      (  741691.708,  190256.435)
>> Band 1 Block=12329x1 Type=Byte, ColorInterp=Palette
>>     NBITS=1
>>   Color Table (RGB with 2 entries)
>>     0: 255,255,255,255
>>     1: 0,0,0,255
>> OK :
>> ~/Desktop/testgeo/AB_georef.tif
>> Files: /Users/Patrice/Desktop/testgeo/AB_georef.tif
>>        /Users/Patrice/Desktop/testgeo/AB_georef.tif.aux.xml
>> Size is 13446, 14968
>> Origin = (740550.783870017039590,191526.220101331215119)
>> Pixel Size = (0.169699598291267,-0.169699598291267)
>>   INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (  740550.784,  191526.220)
>> Lower Left  (  740550.784,  188986.157)
>> Upper Right (  742832.565,  191526.220)
>> Lower Right (  742832.565,  188986.157)
>> Center      (  741691.674,  190256.188)
>> Band 1 Block=13446x1 Type=Byte, ColorInterp=Palette
>>   Color Table (RGB with 256 entries)
>>     0: 255,255,255,255
>>     1: 0,0,0,255
>>     2: 0,0,0,255
>>     3: 0,0,0,255
>>     4: 0,0,0,255
>>     5: 0,0,0,255
>>     6: 0,0,0,255
>>     7: 0,0,0,255
>>     8: 0,0,0,255
>>     9: 0,0,0,255
>>    10: 0,0,0,255
>>    11: 0,0,0,255
>>    12: 0,0,0,255
>>    13: 0,0,0,255
>>    14: 0,0,0,255
>>    15: 0,0,0,255
>>    16: 0,0,0,255
>>    17: 0,0,0,255
>>    18: 0,0,0,255
>>    19: 0,0,0,255
>>    20: 0,0,0,255
>>    21: 0,0,0,255
>>    22: 0,0,0,255
>>    23: 0,0,0,255
>>    24: 0,0,0,255
>>    25: 0,0,0,255
>>    26: 0,0,0,255
>>    27: 0,0,0,255
>>    28: 0,0,0,255
>>    29: 0,0,0,255
>>    30: 0,0,0,255
>>    31: 0,0,0,255
>>    32: 0,0,0,255
>>    33: 0,0,0,255
>>    34: 0,0,0,255
>>    35: 0,0,0,255
>>    36: 0,0,0,255
>>    37: 0,0,0,255
>>    38: 0,0,0,255
>>    39: 0,0,0,255
>>    40: 0,0,0,255
>>    41: 0,0,0,255
>>    42: 0,0,0,255
>>    43: 0,0,0,255
>>    44: 0,0,0,255
>>    45: 0,0,0,255
>>    46: 0,0,0,255
>>    47: 0,0,0,255
>>    48: 0,0,0,255
>>    49: 0,0,0,255
>>    50: 0,0,0,255
>>    51: 0,0,0,255
>>    52: 0,0,0,255
>>    53: 0,0,0,255
>>    54: 0,0,0,255
>>    55: 0,0,0,255
>>    56: 0,0,0,255
>>    57: 0,0,0,255
>>    58: 0,0,0,255
>>    59: 0,0,0,255
>>    60: 0,0,0,255
>>    61: 0,0,0,255
>>    62: 0,0,0,255
>>    63: 0,0,0,255
>>    64: 0,0,0,255
>>    65: 0,0,0,255
>>    66: 0,0,0,255
>>    67: 0,0,0,255
>>    68: 0,0,0,255
>>    69: 0,0,0,255
>>    70: 0,0,0,255
>>    71: 0,0,0,255
>>    72: 0,0,0,255
>>    73: 0,0,0,255
>>    74: 0,0,0,255
>>    75: 0,0,0,255
>>    76: 0,0,0,255
>>    77: 0,0,0,255
>>    78: 0,0,0,255
>>    79: 0,0,0,255
>>    80: 0,0,0,255
>>    81: 0,0,0,255
>>    82: 0,0,0,255
>>    83: 0,0,0,255
>>    84: 0,0,0,255
>>    85: 0,0,0,255
>>    86: 0,0,0,255
>>    87: 0,0,0,255
>>    88: 0,0,0,255
>>    89: 0,0,0,255
>>    90: 0,0,0,255
>>    91: 0,0,0,255
>>    92: 0,0,0,255
>>    93: 0,0,0,255
>>    94: 0,0,0,255
>>    95: 0,0,0,255
>>    96: 0,0,0,255
>>    97: 0,0,0,255
>>    98: 0,0,0,255
>>    99: 0,0,0,255
>>   100: 0,0,0,255
>>   101: 0,0,0,255
>>   102: 0,0,0,255
>>   103: 0,0,0,255
>>   104: 0,0,0,255
>>   105: 0,0,0,255
>>   106: 0,0,0,255
>>   107: 0,0,0,255
>>   108: 0,0,0,255
>>   109: 0,0,0,255
>>   110: 0,0,0,255
>>   111: 0,0,0,255
>>   112: 0,0,0,255
>>   113: 0,0,0,255
>>   114: 0,0,0,255
>>   115: 0,0,0,255
>>   116: 0,0,0,255
>>   117: 0,0,0,255
>>   118: 0,0,0,255
>>   119: 0,0,0,255
>>   120: 0,0,0,255
>>   121: 0,0,0,255
>>   122: 0,0,0,255
>>   123: 0,0,0,255
>>   124: 0,0,0,255
>>   125: 0,0,0,255
>>   126: 0,0,0,255
>>   127: 0,0,0,255
>>   128: 0,0,0,255
>>   129: 0,0,0,255
>>   130: 0,0,0,255
>>   131: 0,0,0,255
>>   132: 0,0,0,255
>>   133: 0,0,0,255
>>   134: 0,0,0,255
>>   135: 0,0,0,255
>>   136: 0,0,0,255
>>   137: 0,0,0,255
>>   138: 0,0,0,255
>>   139: 0,0,0,255
>>   140: 0,0,0,255
>>   141: 0,0,0,255
>>   142: 0,0,0,255
>>   143: 0,0,0,255
>>   144: 0,0,0,255
>>   145: 0,0,0,255
>>   146: 0,0,0,255
>>   147: 0,0,0,255
>>   148: 0,0,0,255
>>   149: 0,0,0,255
>>   150: 0,0,0,255
>>   151: 0,0,0,255
>>   152: 0,0,0,255
>>   153: 0,0,0,255
>>   154: 0,0,0,255
>>   155: 0,0,0,255
>>   156: 0,0,0,255
>>   157: 0,0,0,255
>>   158: 0,0,0,255
>>   159: 0,0,0,255
>>   160: 0,0,0,255
>>   161: 0,0,0,255
>>   162: 0,0,0,255
>>   163: 0,0,0,255
>>   164: 0,0,0,255
>>   165: 0,0,0,255
>>   166: 0,0,0,255
>>   167: 0,0,0,255
>>   168: 0,0,0,255
>>   169: 0,0,0,255
>>   170: 0,0,0,255
>>   171: 0,0,0,255
>>   172: 0,0,0,255
>>   173: 0,0,0,255
>>   174: 0,0,0,255
>>   175: 0,0,0,255
>>   176: 0,0,0,255
>>   177: 0,0,0,255
>>   178: 0,0,0,255
>>   179: 0,0,0,255
>>   180: 0,0,0,255
>>   181: 0,0,0,255
>>   182: 0,0,0,255
>>   183: 0,0,0,255
>>   184: 0,0,0,255
>>   185: 0,0,0,255
>>   186: 0,0,0,255
>>   187: 0,0,0,255
>>   188: 0,0,0,255
>>   189: 0,0,0,255
>>   190: 0,0,0,255
>>   191: 0,0,0,255
>>   192: 0,0,0,255
>>   193: 0,0,0,255
>>   194: 0,0,0,255
>>   195: 0,0,0,255
>>   196: 0,0,0,255
>>   197: 0,0,0,255
>>   198: 0,0,0,255
>>   199: 0,0,0,255
>>   200: 0,0,0,255
>>   201: 0,0,0,255
>>   202: 0,0,0,255
>>   203: 0,0,0,255
>>   204: 0,0,0,255
>>   205: 0,0,0,255
>>   206: 0,0,0,255
>>   207: 0,0,0,255
>>   208: 0,0,0,255
>>   209: 0,0,0,255
>>   210: 0,0,0,255
>>   211: 0,0,0,255
>>   212: 0,0,0,255
>>   213: 0,0,0,255
>>   214: 0,0,0,255
>>   215: 0,0,0,255
>>   216: 0,0,0,255
>>   217: 0,0,0,255
>>   218: 0,0,0,255
>>   219: 0,0,0,255
>>   220: 0,0,0,255
>>   221: 0,0,0,255
>>   222: 0,0,0,255
>>   223: 0,0,0,255
>>   224: 0,0,0,255
>>   225: 0,0,0,255
>>   226: 0,0,0,255
>>   227: 0,0,0,255
>>   228: 0,0,0,255
>>   229: 0,0,0,255
>>   230: 0,0,0,255
>>   231: 0,0,0,255
>>   232: 0,0,0,255
>>   233: 0,0,0,255
>>   234: 0,0,0,255
>>   235: 0,0,0,255
>>   236: 0,0,0,255
>>   237: 0,0,0,255
>>   238: 0,0,0,255
>>   239: 0,0,0,255
>>   240: 0,0,0,255
>>   241: 0,0,0,255
>>   242: 0,0,0,255
>>   243: 0,0,0,255
>>   244: 0,0,0,255
>>   245: 0,0,0,255
>>   246: 0,0,0,255
>>   247: 0,0,0,255
>>   248: 0,0,0,255
>>   249: 0,0,0,255
>>   250: 0,0,0,255
>>   251: 0,0,0,255
>>   252: 0,0,0,255
>>   253: 0,0,0,255
>>   254: 0,0,0,255
>>   255: 0,0,0,255
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110430/225bdc3f/attachment.html>
