[Qgis-user] Pan/Zoom to co-ordinates
Saber Razmjooei
razmjooeis at faunalia.co.uk
Tue Aug 2 08:10:57 PDT 2011
You can type the coordinate in the status bar (hit enter) and it centres
your map there. After that, you can save it as a bookmark.
Cheers
Saber
On Tue, 2011-08-02 at 16:04 +0100, jonathanmoules at warwickshire.gov.uk
wrote:
> Simple question - Does QGIS have a Pan/Zoom to coordinates feature?
> There are a number of pan/zoom tools but I've not found anything that
> can do that.
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Qgis-user mailing list
