[Qgis-user] Pan/Zoom to co-ordinates
Alister Hood alister.hood at synergine.com
Tue Aug 2 16:06:07 PDT 2011
There are also two zoom-to-point plugins, which allow you to enter a
scale factor (rather than an actual scale, which you can enter in the
status bar.
> Date: Tue, 02 Aug 2011 16:10:57 +0100
> From: Saber Razmjooei <razmjooeis at faunalia.co.uk>
> Subject: Re: [Qgis-user] Pan/Zoom to co-ordinates
> To: jonathanmoules at warwickshire.gov.uk
> Cc: qgis-user at lists.osgeo.org
> Message-ID: <1312297857.2115.1.camel at ioio>
> Content-Type: text/plain; charset="UTF-8"
> You can type the coordinate in the status bar (hit enter) and it
centres
> your map there. After that, you can save it as a bookmark.
> Cheers
> Saber
> On Tue, 2011-08-02 at 16:04 +0100, jonathanmoules at warwickshire.gov.uk
> wrote:
> > Simple question - Does QGIS have a Pan/Zoom to coordinates feature?
> > There are a number of pan/zoom tools but I've not found anything
that
> > can do that.
> > Thanks,
> > Jonathan
> > This transmission is intended for the named addressee(s) only and
may
> > contain sensitive or protectively marked material up to RESTRICTED
and
> > should be handled accordingly. Unless you are the named addressee
(or
> > authorised to receive it for the addressee) you may not copy or use
> > it, or disclose it to anyone else. If you have received this
> > transmission in error please notify the sender immediately. All
email
> > traffic sent to or from us, including without limitation all GCSX
> > traffic, may be subject to recording and/or monitoring in accordance
> > with relevant legislation.
