[Qgis-user] qgis 1.7 on Microsoft server 2003 not launching
HAUBOURG
regis.haubourg at eau-adour-garonne.fr
Thu Aug 4 06:50:54 PDT 2011
Hi list,
Very happy with Qgis 1.7 for my own use, we are trying to deploy it for users working on a Citrix XenApp Network with Microsoft Server 2003.
The previous version 1.6 installed through the standalone windows installer worked fine.
We installed the 1.7 , with the standalone windows installer too, on two developpement servers with my system administrator.
We get a launch error message with the following error code "0xc06d007e" on both servers.
It looks like a conflict on a memory location but we found very few matching results on the web.
We checked updates on microsoft visual c++ redistributable 2005. it was correctly installed. We previously had the visual c++ redistributable 2010.
Does anyone has any idea or clue ?
We really count on that version to switch our users to qgis, and then be able to contribute (financially too) to the project.
Cheers,
Regis
Régis Haubourg
Administrateur de données Géographiques
Département des Systèmes d'Information (DCSI)
Agence de l'eau Adour Garonne
90 rue du Férétra,
31078 Toulouse Cedex4
Tél: 05 61 36 82 58
Mail: regis.haubourg at eau-adour-garonne.fr
-----Message d'origine-----
De : qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] De la part de qgis-user-request at lists.osgeo.org
Envoyé : jeudi 4 août 2011 18:01
À : qgis-user at lists.osgeo.org
Objet : Qgis-user Digest, Vol 66, Issue 7
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: free DEM data in QGis (Saber Razmjooei)
2. Re: free DEM data in QGis (Torsten Lange)
3. Re: 1.7 upgrade problem (William Kyngesburye)
4. Added alaska region shape from GADM to the sample dataset
(Otto Dassau)
5. Re: 1.7 upgrade problem (Walter Ludwick)
6. Re: 1.7 upgrade problem (William Kyngesburye)
7. Identify/highlight in reprojected layer (Johannes Engel)
Message: 1
Date: Wed, 3 Aug 2011 11:47:28 +0100
From: "Saber Razmjooei" <razmjooeis at faunalia.co.uk>
Subject: Re: [Qgis-user] free DEM data in QGis
To: jonathanmoules at warwickshire.gov.uk
Cc: qgis-user at lists.osgeo.org
Message-ID:
<15a5e95daf96e75a09dd120c6287e055.squirrel at www.webmail.lutraconsulting.co.uk>
Content-Type: text/plain;charset=iso-8859-1
Globe plugin is already in the trunk version for 3d view.
Cheers
Saber
> Hi Torsten,
> If your question is how do you get the (SRTM) data, try
> something
> like:
> http://edcsns17.cr.usgs.gov/NewEarthExplorer/ - Earth Explorer from
> the USGS Or http://srtm.csi.cgiar.org/ - or various other places.
> If you just want to use it as a basemap then I'm guessing you
> just add it like a regular raster. If you want to use it to drape
> other data over so you can do 3D I'm not sure if QGIS could do that or
> if it would be the best solution - there are other open-source GIS's for that.
> Hope that helps.
> Jonathan
> From: Torsten Lange <tlange at gwdg.de>
> To: Qgis-user at lists.osgeo.org
> Date: 02/08/2011 23:55
> Subject: [Qgis-user] free DEM data in QGis
> Sent by: qgis-user-bounces at lists.osgeo.org
> Hi!
> I'm novice to use free DEM data. I work on a medium (~60km) scale area
> in Germany. It's basically about geology. As don't need accurate DEM
> data for the time being I read through google that gtopo30 or (even
> better ?) DTED data
> from German Aerospace Center may be utilized, which are all free of
> charge.
> Actually I don't know where to start. Could anyone please give some
> comments about how would be the general procedure to load those data
> into QGis?
> Useful
> links are appreciated.
> Thanks in advance,
> Torsten
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Message: 2
Date: Wed, 3 Aug 2011 13:45:07 +0200
To: qgis-user at lists.osgeo.org
Message-ID: <201108031345.07351.tlange at gwdg.de>
Content-Type: Text/Plain; charset="iso-8859-1"
Thank all for the infos! I'll go through it...
Cheers, Torsten
Am Mittwoch 03 August 2011, 12:47:28 schrieb Saber Razmjooei:
> Cheers
> Saber
> > Hi Torsten,
> > something
> > like:
> > the
> > USGS
> > just
> > add it like a regular raster. If you want to use it to drape other
> > data over so you can do 3D I'm not sure if QGIS could do that or if
> > Hope that helps.
> > Jonathan
> > Hi!
> > area in Germany. It's basically about geology. As don't need
> > accurate DEM data for the time being I read through google that
> > gtopo30 or (even better ?) DTED data
> > charge.
> > into QGis?
> > Useful
> > Thanks in advance,
> > Torsten
> > may contain sensitive or protectively marked material up to
> > RESTRICTED and should be handled accordingly. Unless you are the
> > named addressee (or authorised to receive it for the addressee) you
> > may not copy or use it, or disclose it to anyone else. If you have
> > received this transmission in error please notify the sender
> > immediately. All email traffic sent to or from us, including
> > without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Message: 3
Date: Wed, 3 Aug 2011 08:41:25 -0500
From: William Kyngesburye <woklist at kyngchaos.com>
Subject: Re: [Qgis-user] 1.7 upgrade problem
To: Walter Ludwick <wludwick at mac.com>
Message-ID: <1DE6C741-C710-4DAE-A072-0CED8E393F22 at kyngchaos.com>
Content-Type: text/plain; charset=us-ascii
You probably had QGIS 1.6.0-1, which used GDAL 1.7. QGIS 1.6.0-2 was recompiled to use GDAL 1.8, and then so was QGIS 1.7. Just install GDAL Complete 1.8 as it says in the readme. It will leave the older GDAL alone so you can go back to QGIS 1.6 (or you can download 1.6.0-2 to use GDAL 1.8).
Updating GRASS is also a good idea.
QGIS 1.6 and 1.7 run 64bit, if available. From your crash report for QGIS 1.7, your Mac is 64bit (only the very first Intel Mini and MacBook models were 32bit).
On Aug 3, 2011, at 3:00 AM, Walter Ludwick wrote:
> Following on upgrade advice received here, i downloaded version 1.7.0 (tho i still don't know why "check QGIS version" command from Help menu told me i was up-to-date with 1.6.0) for Mac OS X and threw it into my apps folder, thereby replacing the old app.
> I goofed! -obviously, by not reading the "ReadMe" file (which i did consider for a moment doing, but i was in a rush and figured it would be trivial, so...), also by not installing a test instance, while preserving my 1.6.0 install (for this, on top of previous mistake, there is no excuse!).
> Result: QGIS will not launch -apparently (based on exception report below) because i don't have the GDAL library it wants installed (tho i thought, since i was running 1.6.0, i must have GDAL installed, along with GRASS, right?)... But also, i am guessing i may have a problem running 64-bit native code on this machine, which i believe is running in 32-bit mode, tho i don't know how i can confirm this.
> Now: before i go installing GDAL, i was just wondering, if anyone can tell me:
> - is that all i will need to install? is my machine even compatible? can i switch to 64-bit mode somehow? might that cause other apps i have to fail?
> - what if i just want to roll-back to 1.6.0 (which, on reflection, was making me perfectly happy!), do any of the steps associated with upgrade break compatibility with the 1.6.0 code?
> /w
>> Process: QGIS [14565]
>> Path: /Applications/QGIS.app/Contents/MacOS/QGIS
>> Identifier: org.qgis.qgis
>> Version: ??? (???)
>> Code Type: X86-64 (Native)
>> Parent Process: launchd [179]
>> Date/Time: 2011-08-03 08:44:10.527 +0100
>> OS Version: Mac OS X 10.6.8 (10K540)
>> Report Version: 6
>> Interval Since Last Report: 251819 sec
>> Crashes Since Last Report: 5
>> Per-App Crashes Since Last Report: 3
>> Anonymous UUID: A3B4FAD8-70A5-420F-A0E1-E02624B493A5
>> Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes:
>> 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0
>> Dyld Error Message:
>> Library not loaded: /Library/Frameworks/GDAL.framework/Versions/1.8/GDAL
>> Referenced from: /Applications/QGIS.app/Contents/MacOS/QGIS
>> Reason: image not found
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com> http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
Message: 4
Date: Wed, 3 Aug 2011 16:18:09 +0200
Subject: [Qgis-user] Added alaska region shape from GADM to the sample
dataset
To: qgis-community-team at lists.osgeo.org
<qgis-community-team at lists.osgeo.org>
Cc: qgis-user at lists.osgeo.org, qgis-developer
<qgis-developer at lists.osgeo.org>
Message-ID: <20110803161809.1c93d301 at nature.speedport.ip>
Content-Type: text/plain; charset=US-ASCII
I added a regions.shp shape to the Alaska dataset and rename the folder vmap0_shapefiles to shapefiles. This gives some more possibilities to analyse vector data.
You find a README.html and the updated dataset here:
http://download.osgeo.org/qgis/data/
Regards,
Otto
Message: 5
Date: Wed, 03 Aug 2011 15:43:28 +0100
Message-ID: <6613EE04-CFB6-408D-8F17-76A4A57D713B at mac.com>
Content-Type: text/plain; CHARSET=US-ASCII
Hey, William: Cool -i have installed GDAL Complete 1.8, and now QGIS 1.7 runs apparently OK.
Am a bit concerned (based on the install warning, and what i have read here in the thread about backward compatibility) that i may be rendering project files unusable by colleagues (esp. one i work closely with, a Windows guy) still on 1.6... But will cross that bridge if/when i i come to it, by urging one & all to updgrade.
About GRASS: looks like i have 6.4 installed, and upgrade to 6.4.1 is not required (obviously), but i will now proceed to upgrade that one too (seeing as how you've been right about everything else so far :)
Thanks, William! /wl
> QGIS 1.6 and 1.7 run 64bit, if available. From your crash report for QGIS 1.7, your Mac is 64bit (only the very first Intel Mini and MacBook models were 32bit)...
Message: 6
Date: Wed, 3 Aug 2011 10:10:34 -0500
Message-ID: <F6F7950F-C5F3-4A28-AF6B-18F72154AA95 at kyngchaos.com>
They probably also have to upgrade - while there may or may not be actual compatibility problems from one version to the next, I think QGIS will refuse to open newer version files on older QGIS versions.
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
Message: 7
Date: Wed, 03 Aug 2011 23:41:15 +0200
Subject: [Qgis-user] Identify/highlight in reprojected layer
Message-ID: <j1cf9t$hgi$1 at dough.gmane.org>
Content-Type: text/plain; charset=ISO-8859-15
just noticed that the highlighting of features with the identify-tool doesnt works in reprojected layers.
Example:
Project-CRS is 31467 (gk3), Shape is in 4326 (wgs84) I can identfiy features, but no highlighting occurs. Even if i use right mouse and select "Highlight all" or "Highlight layer".
When i change Project-CRS to same as Shape (4326) everything works as expected.
I'm using the following Osgeo4w-Builds of QGIS on win7 (64bit):
qgis 1.7.0-2 and
qgis-dev 1.8.0-54 (4d56f98)
Searched the web, qgis bugtracker and the mailinglist but couldnt find a reference to this problem. Closest i could find is:
http://hub.qgis.org/issues/3689
But in my case its just the highlighting that isn't working.
Ist this a bug or a just problem with my installation?
Thanks,
Johannes
End of Qgis-user Digest, Vol 66, Issue 7
