[Qgis-user] QGIS 1.7 Does not load after installation
Nomeneta Saili nome.saili at gmail.com
Tue Aug 9 05:40:37 PDT 2011
Hi Duarte,
In both cases the QGIS just dosent load/launch. Double click on the
desktop shortcut or launch from the start menu but they just don't
launch like there is nothing installed. I did try reinstallation and
still dosen't work.
 For our windows 7 PC we did install version 1.6 before and perhaps it
is indeed a previous dll. So should i try deleting qtcore4.dll?. Any
other i need to delete?. I am currently at home and will try to follow
any instructions once i get back to work tomorrow. Its currently 1:46
am here in my part of the world.
Thanks for the help.
Nome
On Mon, Aug 8, 2011 at 9:42 PM, Duarte Carreira <DCarreira at edia.pt> wrote:
> Nome,
> Maybe it's because there are some older dll's in your system32 folder? what's the error message? We've seen this happening with qtcore4.dll and a few other qt dll's hanging around.
> Duarte
> -----Mensagem original-----
> De: Nomeneta Saili [mailto:nome.saili at gmail.com]
> Enviada: terça-feira, 9 de Agosto de 2011 04:09
> Para: qgis-user at lists.osgeo.org
> Assunto: [Qgis-user] QGIS 1.7 Does not load after installation
> Hi people,
> QGIS 1.7 after installing on my Windows 7 does not load when i try to
> launch. This is also the case on my XP netbook that i installed QGIS
> on. It is however working fine on my PC with XP as well as my Server
> with Windows 2008 Server. I used the same installation file.
> Any help is appreciated.
> Thanks,
> Nome
