[Qgis-user] QGIS 1.7 Does not load after installation
Frank Sokolic sokolic at worldonline.co.za
Tue Aug 9 08:58:25 PDT 2011
Hi Nome,
Have you tried installing QGIS with administrator rights? Right-click on
the installation file and select 'run as administrator'. Install the
program that way and see if it solves your problem.
Another thing you can try: I once had a problem where QGIS wouldn't load
and eventually tracked the problem down to the program nircmd.exe which
is used to run the batch file that launches QGIS. The antivirus software
on the computer in question was flagging nircmd as a virus and
preventing it from running. Maybe this is the cause of your problem? Try
double-clicking the qgis.bat file in the qgis folder to see if you can
run it that way.
Frank.
On 09/08/2011 14:40, Nomeneta Saili wrote:
> Hi Duarte,
> In both cases the QGIS just dosent load/launch. Double click on the
> desktop shortcut or launch from the start menu but they just don't
> launch like there is nothing installed. I did try reinstallation and
> still dosen't work.
>   For our windows 7 PC we did install version 1.6 before and perhaps it
> is indeed a previous dll. So should i try deleting qtcore4.dll?. Any
> other i need to delete?. I am currently at home and will try to follow
> any instructions once i get back to work tomorrow. Its currently 1:46
> am here in my part of the world.
> Thanks for the help.
> Nome
> On Mon, Aug 8, 2011 at 9:42 PM, Duarte Carreira<DCarreira at edia.pt>  wrote:
>> Nome,
>> Maybe it's because there are some older dll's in your system32 folder? what's the error message? We've seen this happening with qtcore4.dll and a few other qt dll's hanging around.
>> Duarte
>> -----Mensagem original-----
>> De: Nomeneta Saili [mailto:nome.saili at gmail.com]
>> Enviada: terça-feira, 9 de Agosto de 2011 04:09
>> Para: qgis-user at lists.osgeo.org
>> Assunto: [Qgis-user] QGIS 1.7 Does not load after installation
>> Hi people,
>> QGIS 1.7 after installing on my Windows 7 does not load when i try to
>> launch. This is also the case on my XP netbook that i installed QGIS
>> on. It is however working fine on my PC with XP as well as my Server
>> with Windows 2008 Server. I used the same installation file.
>> Any help is appreciated.
>> Thanks,
>> Nome
> Qgis-user mailing list
