[Qgis-user] editable attribute tables
Aigars V aigarsv at gmail.com
Wed Aug 17 07:40:48 PDT 2011
you should look at this
http://www.qgis.org/wiki/Deleting_a_column_from_an_attribute_table
2011/8/17 Andreas Neumann <a.neumann at carto.net>
> Hi Andrew,
> With ESRI shapefiles you can edit the attribute table and add and delete
> columns. However, you cannot re-arrange the order of the columns, as far as
> I know. The table can be sorted - per default is is sorted by the primary
> key column.
> Andreas
> On Wed, 17 Aug 2011 09:00:20 -0500, Andrew Novak wrote:
>> Is it possible to create shapefiles with editable attribute tables? I
>> need to add multiple rows and have columns that I can delete and move
>> around.?.?
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110817/2d1b3b0f/attachment.html>
