[Qgis-user] editable attribute tables
Andrew Novak novak.andj at gmail.com
Wed Aug 17 07:55:25 PDT 2011
The table manager plug-in seems to be the tool for me, but it is not listed
in the python plugin  installer.?.?
On Wed, Aug 17, 2011 at 9:40 AM, Aigars V <aigarsv at gmail.com> wrote:
> you should look at this
> http://www.qgis.org/wiki/Deleting_a_column_from_an_attribute_table
> 2011/8/17 Andreas Neumann <a.neumann at carto.net>
>> Hi Andrew,
>> With ESRI shapefiles you can edit the attribute table and add and delete
>> columns. However, you cannot re-arrange the order of the columns, as far as
>> I know. The table can be sorted - per default is is sorted by the primary
>> key column.
>> Andreas
>> On Wed, 17 Aug 2011 09:00:20 -0500, Andrew Novak wrote:
>>> Is it possible to create shapefiles with editable attribute tables? I
>>> need to add multiple rows and have columns that I can delete and move
>>> around.?.?
>> Andreas Neumann
>> Böschacherstrasse 10A
>> 8624 Grüt (Gossau ZH)
>> Switzerland
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110817/def4c034/attachment.html>
