[Qgis-user] editable attribute tables
Aigars V aigarsv at gmail.com
Wed Aug 17 08:06:09 PDT 2011
http://www.youtube.com/watch?v=JQUxinzqj00
2011/8/17 Andrew Novak <novak.andj at gmail.com>
> The table manager plug-in seems to be the tool for me, but it is not listed
> in the python plugin  installer.?.?
> On Wed, Aug 17, 2011 at 9:40 AM, Aigars V <aigarsv at gmail.com> wrote:
>> you should look at this
>> http://www.qgis.org/wiki/Deleting_a_column_from_an_attribute_table
>> 2011/8/17 Andreas Neumann <a.neumann at carto.net>
>>> Hi Andrew,
>>> With ESRI shapefiles you can edit the attribute table and add and delete
>>> columns. However, you cannot re-arrange the order of the columns, as far as
>>> I know. The table can be sorted - per default is is sorted by the primary
>>> key column.
>>> Andreas
>>> On Wed, 17 Aug 2011 09:00:20 -0500, Andrew Novak wrote:
>>>> Is it possible to create shapefiles with editable attribute tables? I
>>>> need to add multiple rows and have columns that I can delete and move
>>>> around.?.?
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110817/6846bbd9/attachment.html>
